Question about Toshiba DP2570 Printer
Black Spots all over my copies
I just recently began seeing black "blobs" on my copies, very random at first, but now they are all over the page. they are not always in the same spots, they will be anywhere from just one line down the page of spots to all over the page, to none. I can find no rhyme or reason. Any suggestions
  • Brady Cassidy Jun 15, 2007
    We broke down and had a guy come out and look at it and he said we need a new drum.
  • 31 Answers
There are lots of things that can cause this. Inspect the fuser assembly & verify that there isn't any teflon missing from the upper roller & that the lower roller is clean. The spots can also be caused by a build up of waste toner in the cleaning assembly, causing excess toner to be dropped on the copies as they pass under it. The cleaning assembly would need to be removed & cleaned to correct this. The spots are not always in the same place - but are they the same pattern? A worn drum assembly can cause spots that are usually a repeating pattern but located in different parts of multiple copies. Dirty corona wires can also cause random spots & rewiring the coronas would solve that.
Posted on Jun 11, 2007
I have random black spots on my paper, some flat, some raised. Looks like blobs of toner.
Drum was improperly cleaned; residual particles remain on drum.
Try to manually clean the drum and do a cleaning procedure as in your manual. Replacing the cleaning module is the last thing to do if nother else works.
Jul 07, 2011 | Oki Electric Industry OKIDATA 62428701...
I have a Cannon PC 140 copier. Recently, It began putting about a 1/4 inch thick black line on ever page I copy. What is wrong and how do I fix it?
Replace the drum/toner unit it should be sold as one complete cartridge.
rather expensive. you might check for a compatible or remanufactured cartridge
Mar 13, 2011 | Canon Office Equipment & Supplies
Having dark black blob spots along the side of every page
it sounds as if your computer screen is going bad replace it.
Jan 25, 2011 | IBM Infoprint 1552 Laser Printer
Printer sqeaks loudly when printing. Also there
Sqeaks are hard to fix over the computer but if the black spots are random change the toner cartridge. If they are 3 or 4 to the page change the drum.
Feb 04, 2010 | Brother HL 2140 Laser Printer
Leaving a wide black line in right hand side of transaction
Pop open the fax document feeder, and look for a glass strip about 1cm wide, that runs from left to right across the machine.
You will probably see a few spots of dirt, or more commonly, a blob of white liquid paper stuck on the glass, on the side of the machine that corresponds to the black lines on your fax.
Clean this glass strip gently, using a soft cloth dampened with a mild detergent. I often use diluted windex. You may need to scrape liquid paper gently with your fingernail. Close the cover.
Next, put a blank sheet into the feeder and make a copy of the blank page. If you have cleaned it properly, the copy will be blank as well. If you still have a line, align it with the feeder and use this as a guide to show you where the glass may still have some **** stuck on it.
Dec 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Hitachi rear projection LCD with yellow blobs on screen
I have the same tv and the same problem, but my yellow is a cloud around the outside of the screen. My tv was recently moved, and a repair shop told me that sometimes in a move these tvs light engine takes a shock and causes a yellow "band" on the screen. I am hearing that these light engines are not cheap either. Hope this helps you.
Dec 01, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Oce 3121 coping machine make random black line shadows
if you are getting copy quality issues on all aspects of the machine, IE, printing, copying, ADF, it looks like then you might need a new drum installed. please contact your local service department for service and make sure if you need supplies, to have those on hand before calling a tech to come service the machine. drums, developers, and toner are considered a supply item and are NOT carried by technicians unless otherwise stated in your local contract.
Jun 23, 2009 | OCE Office Equipment & Supplies
Can I fix this stuff without a service call?
black spots can also be caused by drum...
developer normally will cause blur print due to developer uneven or dirty (dust)...
Apr 17, 2009 | Office Equipment & Supplies
White spots with a black dot in the centre
pls check the ibt belt. its geting any hole are bunch its come like this, or u will check and clean ibt assemply transfer rolleres. and 2nd btr also.
Jul 23, 2008 | Xerox DocuColor 12 Color Copier
Toshiba DP2570 Printer Logo
987 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Adorjani Laszlo
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
