Heater trane xe 90 working iregular, set to 70 heats up to 64
The burner ignites and then it goes out when the fan comes on. i have already cleaned the flame sensor and replaced the thermostat.  I noticed the small blower motor is on all day and when the burners come on there is a red light that comes on on the ctrl. panel. do i still need to replace the flame sensor?  thank you for your help.
    Problem Solver:
  • 4 Answers
Possible problemis due to a thermo-couple that has seen better times. If I understand your system correct I would check that.
Posted on Jan 13, 2009
Trane xe 90 burner wont light
Bad igniter? Could be a safety control telling the furnace not to light. Check to see if the furnace has a diagnostic indicator. If so count the flashes and then check the diagnostics list inside the door or in the owners manual. This should narrow the problem down.
May 01, 2014 | Heating & Cooling
Trane xe 70 cycles through the gas release cycle but fails to ignite the burners, upon inspection it appears that the igniter isnt glowing
Either the circuit to the electronic ignitor is bad or the ignitor (electrode) itself has failed. Either are not difficult to replace, but you will need a circuit tester to troubleshoot which part(s) needs replacing.
Mar 27, 2011 | Heating & Cooling
Had my Trane XE 70 serviced and was told I need a new ignitor module. Then was told it can't be ordered and is no longer available. Also, that no generic replacement will work with my unit. Model number...
all furnaces by national code must be 80% eff or higher whitch negated the productions of th replacement parts for such units. I tried to find a burner for that model w no luck
Jan 22, 2011 | Heating & Cooling
I have a Trane xe 70. The Heat is not turning on. The ignitor will glow but NO gas or blower. I turn on the fan and the blower does work but not when HEAT is selected on the t-stat. Also the LED light...
Check to see if you get 24 volts AC at the gas valve from the circuit board when the igniter is glowing. If yes, bad gas valve or blockage in gas train. If no, bad circuit board or broken wire
Feb 07, 2010 | Heating & Cooling
Gas heater won't ignite
I agree. Either the pilot flame is dirty and is not making good contact to heat up the bi metal strip on the pilot assembly, or the pilot assembly is defective. 90% of the time if you clean the pilot orfice and the pilot burner it will take care of the problem
Nov 16, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
I get 4 blinks it say open limit switch what does that mean
Your induce fan motor senor is out. The little fan motor that take out the heat has a sensor that tells the furnace thats its working. Some time it get stuck. Try blowing and sucking into the tube. you should hear a click
www.fastacservice.com
Oct 16, 2009 | Goodman GMS90703BXA Heater
Central heater will not heat up to set temp on thermostac
pressure port is plugged pull hose off draft motor and clean port with a paper clip
Jan 13, 2009 | Omega Trane Furnace Draft Inducer Blower...
Question on a day and night gas forced air heater
it very well sounds like your fan switch , does your fan work at all, like in ac mode on by turning the fan on/auto switch on the thermostat to ON. If the fan does come on its the more and likely the limit switch. if it doesnt come on it could be the motor or the run capacitor. the limit switch has a dial on it that as it heats up it spins clicking on at a desired set temp ussually about 120 to 150 degrees F. turning on the fan if the fan doen't come in the the next setting clicks off the gas valve turning off the burners ussually set at about 220 degrees F. now if the fan is working when the heater is satisfied there is a setting at about 90 deegrees F. that shuts the fan off hope this helps
Jan 05, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Heating & Cooling Logo
219 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
