Question about Amana ARB8057CSL Bottom Freezer Refrigerator
Amana side by side
No longer cooling fridge or freezer compresser kicks on few seconde 30 goes off makes noise when on takes awhile to come on again fan in freezer compartment not coming on at all coils warm can not find model # at all have looked only # i find is on compressure was working fine yesterday got up everything thawing out some one please give me insight cant buy new fridge at this time
  • 27 Answers
Either compressor is jammed or the starting relay with capacity is faculty
Posted on Mar 06, 2009
Amana side by side stopped cooling and hearing clicking from compressor when I turn it back on
Compresser is low in coolent, Or a Problem with the (Compressor) From what i can make out from your info. How old is this (Fridge)?
Oct 08, 2012 | Amana 25.8 cu. ft. Side-by-Side...
Four year old amana side by side has stopped cooling. Sounds like compressors is not kicking on. what's wrong?
Unplug it for 30 minutes to an hour and it should start up again. Problem is your compressor is no good. Get ready for a new fridge in 3-6 months.
Jul 25, 2012 | Amana Refrigerators
Refrigerator is warm, but freezer is cold and still making ice. This is a 3 year old Amanna Bottom Freezer model. There is frost in the top of the freezer drawer when I putt it out.
you will need to defrost it. the freezer is what keeps your fridge cool. the vent where the cool air goes up to your fridge is sealed or frozen.
unplug the fridge and open the doors and let it defrost.
plug it back in after a few hours and it should be working again.
Mar 20, 2011 | Amana ABB2223DEQ Bottom Freezer...
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
Freezer and fridge not cooling properly
Clean it up. Check under it and behind, clean ,vacume and or blow out all dust and check the fins on the bottom, a soft brush and portable air compressor work really well but very dusty, take out side if possible, or just vacume really well.
Jan 26, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer problem
Have you checked the Heater element for the defrost to see if it's good? It sounds like the coils inside your freezer are freezing over into a solid block of ice which in turn will cause it to stop cooling.....efficiently. When you leave the unit unplugged, it gives the unit a chance to thaw and it work properly until the coils freeze over again. If heater is not the problem then Defrost Thermostat probably is. Both located in back of Freezer.
Nov 23, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Fridge and freezer not cooling properly!
Sounds like a problem with defrost system , It could be one of there components , timer, heater, or defrost thermostat. try advancing the timer, down at the lower area behind the grill. with a screw driver by putting it into the dial advance and turn it till it clicks and the unit shuts off. now you should see red glow at bottom of back panel in freezer or here sizzling . if this does not happen then it will be the heater or the thermostat.
Apr 27, 2017 | Amana 22.6 cu. ft. Side-By-Side...
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Amana bottom frezzer refrigerator
Gazzo, You are on the right track. I've been finding a lot of compressor failures on these Amana's. It's possible that the overload and relay for the compressor failed, but Im more inclined, from what I've seen, that the compressor is the problem. The compressor is covered under warranty, parts and labor for 5 years. I would call for warranty service...Catriver...post back.
Jan 04, 2007 | Amana ABB1927DE Bottom Freezer...
Amana ARB8057CSL Bottom Freezer Refrigerator Logo
182 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
