Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Manual GE outdoor timer 58170lo
Setting time
4 Suggested Answers
SOURCE: set timer for the 7-day outdoor timer i.e. 5:00 pm
Outdoor timers
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
HB88RC timer
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
HB88RC Manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
Timer takes AA battery installed from back
Instructions say: Set timer to AUTO using MODE button. This will let programs run.
To override current program, press MODE once for ON-or-OFF override.
Press MODE again to enter RDM or random mode. RDM shows on display.
Press MODE third time for AUTO. Usually, AUTO will show on display.
Posted on Dec 05, 2010
SOURCE: Set up Intermatic outdoor timer 7day/7event
I have misplaced and forgot how to set a Model HB65R timer, can you help, thanks, Murray
Posted on Dec 24, 2010
  • 5245 Answers
SOURCE: i have an intermatic indoor outdoor timer the
Open following link for Intermatic timer troubleshoot
http://waterheatertimer.org/Troubleshoot-Intermatic-timer.html
Posted on May 30, 2012
GE 6 outlet model 58170LO
Copy following link for GE timers and all brands power-strip timers:
http://waterheatertimer.org/GE-timers-and-manuals.html#powerstrip
For more outdoor timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
If you do not have timer, add comment and describe product in detail
Nov 27, 2012 | Hardware & Accessories
How to set the timer on a ge 58170LO
Timer is not fully identified;
Copy following links to help identify timer and read instructions:
http://waterheatertimer.org/How-to-set-timers.html
Dec 07, 2011 | GE Home
I have a woods 1510 outdoor timer. I do not have manual to program it. Can I get a manual somehow?
Timer is not identified.
1510 timer is not a Woods number, BUT new products come on the market all the time.
Many GE timers have prefix that starts with 15:
Open following links to find same-similar timer:
Add a comment for more information.
Jun 21, 2011 | Sport & Outdoor - Others
How do I set the woods outdoor timer model #59730
Woods 59730 is24-hour 6-outlet yard stake with dial located on top
This timer is identical to GE15107 yard stake
Manual.
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
If this is not your timer, look at following page to identify your timer
Add a comment any time
Timer instructions.
Set current time by rotating dial until time lines up with arrowhead located on inner dial
There are segments located around dial.
Look at inner dial > segments are located just outside the inner dial.
Timer comes with segments pushed inward.
To set timer to turn ON, pull segments outward for hours you want timer ON.
All 6 outlets are controlled by timer.
Last step:
There is override switch located on inner dial.
Move switch to TIMER for timer to operate.
Dec 09, 2010 | Woods Outdoor Lighting Timer
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
To override time and turn on Load, move override to ON position.
Dec 06, 2010 | GE 51587 MultiEvent Timer
I need instructions on how to use the GE Ge 15107 24Hour Yard Stake Timer
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15107-Manual-eng-spn.pdf
Above is link to GE 15107 manual
This is a 15amp timer that can handle up to 1440 watts
How to set timer
Rotate center dial to set current time
Line up current time with triangle on inner part of dial
The timer dial shows nighttime hours on dark part of dial, daytime hours show on light part of dial
The timer dial rotates like a clock after it's plugged in
The outside edge of timer dial has 48 segments
Lift up these segments for times you want timer OFF
Segments down for timer ON
5c24d6c.jpgSegments up, timer OFF. Segments down, timer ON.
Segments in photo are on the GE 15207 timer
Oct 21, 2010 | GE 15107 24Hour Yard Stake Timer
How do I set a general electric outdoor timer
If I understand you correctly, you have GE outdoor box-type timer, for example the GE-15087. If this is the wrong timer, please respond with model number and I'll look up the information.
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
http://waterheatertimer.org/How-to-wire-GE-15087-timer.html
6888635.jpgSegment up, timer on segment down, timer off
GE has additional manuals
http://www.jascoproducts.com/support/manual-downloads/index.asp?search=timer&submit=Search&offset=-1
Oct 19, 2010 | General Electric Hardware & Accessories
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
144 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
