Question about Fujitsu 18CL HALCYON Wall Mounted Single Zone Mini Split Air Conditioner
My 1 year old fujitsu inverter not blowing cold air
3 Suggested Answers
louislevel_2
  • 374 Answers
SOURCE: Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Posted on Apr 18, 2009
hvac1960
  • 2133 Answers
SOURCE: when the airconditioner is on,
Check the compressor is working with exact amps. If not short of gas or no gas. Check thermostat setting 23 degree with cool mode.
Posted on Dec 29, 2010
Fujitsu inverter ASTA34JFC NOT BLOWING COLD AIR TIMER LIGHT FLASHES AT TIMES
Count how many times the timer light flashes before it pauses and repeats. The number of flashes will give an error code to diagnose the problem. Confirm the number of flashes is correct because one flash number out will be a completely different problem.
Sep 25, 2016 | Fujitsu Heating & Cooling
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
Ihave a fujitsu air conditioner model asta18lcc about 2 yrs old when I turn it on fan works but room wont get cold or hot,red operation light does not stay on but green timer light flashes on. thanks...
The lights on the front panel indicate fault codes dependent on the amount & intervals of the flashes. Fujitsu units carry a 5 year warranty so check with your local Fujitsu store for the agent in your area.
Aug 13, 2010 | Fujitsu 24C1 Air Conditioner
Fujitsu Inverter ASTA09LCC Where is the drain tube located? The air con is leaking water and I believe drain may be blocked.
It is directly behind & thru the wall to outside next to the refer. piping.Everything goes outside thru a 3" hole. tube should b there.Blow it out.good luck
Mar 12, 2010 | Fujitsu 18C1 Air Conditioner
Fujitsu inverter; opens vents but no red light, no cold air
check that it is set to cooling sounds like it may be set to heat in cooling mode the indoor fan should at least run
Mar 10, 2010 | Heating & Cooling
My fujitsu inverter does not cool below 18deg C
Heya Mark,
Fujitsu air cons are factory set at 18degs you cannot change it without going through all the controller programs. Normally air cons are serpose to run around the 20deg point, is the air con not running effectually or do you just really like it cold.
I could check with tech help and see if I can send you the derictions of changing the minimum set point but it will not be good in the long run for your unit
Jan 07, 2009 | Fujitsu 36CS Air Conditioner
Fujitsu AOT30PMAL inverter outdoor unit not working
Sounds like your compressor is seized or a start fault. If the unit is under five years old it should be under warranty. Call Fujitsu warranty out to have a look at it for you.
Contact details as follows
http://www.fujitsugeneral.com.au/contact.php
Sorry but either way I think your going to need a part there is very little that I can do unless your in WA.
Hope this helps
Jan 05, 2009 | Fujitsu 18C1 Air Conditioner
We have a fujitsu air con model ast9lsbcw which blows cold air from the outside unit and the inside unit is not cooling the room.
Sounds like you have it in heating mode or it is low on charge. In cooling mode, the outside fan should blow hot air not cold.
Jul 30, 2008 | Heating & Cooling
Fujitsu 18CL HALCYON Wall Mounted Single Zone Mini Split Air Conditioner Logo
313 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
