Older model either 1979 or 1982
Repair or replace your corian countertop or use acrylic sheets to bring life back to kitchen Looking to update your kitchen and do some modeling? Chances are the old formica countertops are looking aged, worn, and stained. But thanks to new options in countertops, customers now have colorful options to choose from or supplement their favorite look by using acrylic sheets as a backsplash around the kitchen. These days acrylic sheets also come in every imaginable color, so finding something within a chosen color palette should not be difficult. Acrylic sheets are durable; they look nice, are non-porous, are extremely high-density and seem to copy the look of real marble countertops. Plus, acrylic sheets are cheaper than other countertop options.
http://www.plastic-craft.com/shop/raw-materials/sheets.html
SOURCE: the pump turns over real hard - it is an older IR with 5 hp motor dual head tag is missing
Bottom line if it is so hard to turn that it's blowing fuses it has to be disassembled. you will probably find a bad bearing on the crankshaft. However it could be a broke valve that has gotten between the cylinder and piston. either way a disassembly will be needed.
