Question about Mitsubishi WS-65807 65" Rear Projection Television
WS-65807 picture goes black when using HiDef Signal
Hello, The picture on my WS-65807 works great if I am watching a DVD....however, if I switch to my Direct TV receiver with high def picture....after a few minutes the picture goes black....every so often the picture comes back...then it disappears again. It also sometimes cycles through the PIP menus. The TV had seldom been used. All connections have been validated and the receiver ruled out by Direct TV (they charged me to come out & tell me this). In all the posts..this tv appears to be a good solid unit. I'd hate to purchase another without a good reason. Any help is appreciated before I go to the local Mitsu repair shop & beg for mercy$$$. Thanks
Tank, If the unit operates correctly on DVD then we can assume that the signal chain and display is operational. Can you substitute the Directv receiver to rule the box out as part of the problem? I know they came out and checked but how exhausting was the testing? Have you checked signal strength on the directv on screen setup? Low or marginal signal strength could cause intermittent blanking. When the screen goes dark does the audio continue? please let us know..
Posted on Jun 11, 2007
SOURCE:
I have a Mitsubishi WS-65807 Projection Tv and while I was watching a program the picture went to a black screen. The audio works fine and when I go to the Menu it shows up fine. Any input as to the...
Thats usually a vertical issue since the menu still works. I would check the solder on the vertical IC and also the Vertical yoke plug pins. Often solder can develop a small crack around the pins and resoldering will usually fix the issue in most cases. The other item could be a leaky CRT has dripped some coolant on some of the components in the vertical circuit so I always check the board for any sign of a clear sticky residule on the boards which indicate dripping CRT coolant.
Jun 07, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi ws-65807 v17 chassis
go to this websight leave an e-mail with your model number and let them know you need a signal board and they should be able to help you plus there prices are very reasonable and they also offer free online tech support to their customers
http://servicemanuals.vstore.ca/
Apr 29, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi ws-65807
I suggest to visit the website of manufacture to have both question answered . thanks
Apr 27, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi ws-65807 no sound or picture
Check for coolant spill in corner of signal PC board = from leaky
CRT seal = bad CRT...........................T.
Apr 24, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65807 + PS3 1080i Screen goes blank when bright white displayed
Go to PS3 / Display settings. Set superbright OFF, even if you don't have HDMI. Set Cross Color Reduction to OFF. Set Display to only one resolution, not all of them as you probably have it now. Set it ot the highest possible resolution and uncheck all other boxes. The 480i is always on by default. The issue, which was very annoying, was fixed for me. I have a mitsubishi 65 inch RP that is pretty bright on daytime/sunlight scenes, so I never thought it was the PS3, but only whet the PS3 was used did this occur. I scanned this site via google to find that nobody else appeared to have resolved this. So after some changes and testing this solution worked for me. Enjoy! - Dave Walz
P.S. I think the only real fix was to set just one display resolution, but I am now watching a movie and am not going to stop it to find out. :) That's for whomever follows this posting to find out for themselves. Either way, this is working great.
Apr 17, 2008 | Televison & Video
Mitsubishi WS-65807 and blue-ray compatibility
that tv set is only good enough to receive a 1080i signal at the DTV INPUT. unless you can change the output of the blue ray it will be outputting 1080p
Mar 01, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Can you connect to upconversion DVD Player for HDMI performance
The TV supports 1080i so if your hardware is plugged into the Component Cable Connection for Digital TV on the back the signal will come out 1080i as long as the hardware supports the size.
For example, my 360 is connected like this and when the dvd player is in use it upscales from the 480 format dvds use to 1080. More on the HD-DVD for the 360 and how it handles the sizes here:
http://www.engadgethd.com/2006/09/21/xbox-360-hd-dvd-playback-maximum-1080i-via-component-1080p-vga/
Kind of an old article since the newer 360s have hdmi and support 1080p that route.
Hopefully this helps.
Dec 16, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Scrolling lines
Try using a DVD though the component input (need a 480P out ). If the pix si ok I wouldsuspect the cable box. If the problem is still there I would suspect a video switching IC or a Leaky regulator.
Oct 15, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi ws 65807 RED CRT
What I usually find on sets like that is that there is a loose solder joint on the CRT board itslef. You must get to the bottom of the picture tubes, pull off the CRT board from the red CRT and examine all solder joints on that board. Chances are one or more will be cracked, and resoldering all joints on the board should clear up your problem.
Aug 04, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
112 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
