Question about Amana AER5515QA Electric Kitchen Range
Amana oven won't heat
My Amana oven model--AER5715QAW will not heat. After replacing the heating sensor and having upper heating element tested...fine. Found the lower element was bad. placed upper on the lower for a test and worked great. Next day bought a new lower elemet and once again nothing. what do we do now? Thank you
fridgetech
  • 473 Answers
SOURCE: From where do I access the lower oven element on a Amana ACF4215A
There should be two screws at the rear of the bottom panel inside the oven. Remove those and lift out that panel. The element is under there. If there is not enough wire to pull thru you may have to disconnect and reconnect the wires to the element from the back of the oven by removing the back panel. Hope this helps.
Posted on Nov 18, 2008
SOURCE: Amana Model ARGS7650E Oven Problem
No matter that the igniter glows you must measure the current... If the current is less than 3.2 or 3.6 you must change it (this current is for the igniters with rectangular white base).The current to open the valve is the same that passed through the igniter so if it doesn't reach the proper value it will never open (or sometimes open sometimes not).Mine is not opening and the current is 2.9 so I'm going to replace it tomorrow.
Posted on Dec 26, 2008
aborcass
  • 2651 Answers
SOURCE: amana gas range trouble with starting
not a sensor, but more likely a bad oven ignitor(glow bar) its located under the ovne floor and mounted to the side ofthe bake bar. simple emough to unscrew and unplug, replacethepart yourself
Posted on Mar 18, 2009
philbran
  • 242 Answers
SOURCE: Amana Self Clean oven Model # ARG7600LL is VERY
Replace the ignitor for the fix.
Phil
Posted on Apr 11, 2009
  • 12 Answers
SOURCE: Amana Electric Range Mod# AER5715QAW bake element not wokging
replaced the electronic control
Posted on Jun 14, 2009
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
We have Amana electric stove AER5735QAS that will not heat beyond approx 180-200 degrees when the stove setting on heat is set to 350. The stove is approx 4 years old. Impression is the problem may be...
If the heating element cycles off and on, it's probably not the problem but a thermostat or high limit. The thermostat should have a sensor wire, a part for sensing temperature and should not be placed or located anywhere near the heating element.
Oct 29, 2017 | Amana AER5735QAS Electric Kitchen Range
My aer5715qaw oven will not heat. I set the temp and the buzzer goes off immediatly to show it is hot then just makes a ticking sound. the oven does not heat
Hello & Welcome to FixYa
It indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 08, 2011 | Amana AER5515QA Electric Kitchen Range
I have an Amana stove model ART4002W. The oven will not heat above 250 degrees and the broiler element will not turn on. I replaced the broiler element and the heat sensor. No change.
if you have it on broil and the element doesn't heat up and you changed the element then you either have a loose or broken wire or a bad clock assy. part number 74009213 and it's around 166 dollars
Feb 11, 2011 | Amana AER5715QAS Electric Kitchen Range
My oven still doesnt work after replacing heating element
it could either be a hot spot in the element where it can no longer pass all the current needed for proper operation in heating(look for a discolored spot on it,it may be whitish and dimpled from heat) or secondly,it could be the oven thermocouple located on the inside top of the oven cavity
Feb 22, 2010 | Amana AEW3530DD Electric Single Oven
Oven Heating problem
hi, it is a minor fix you will have to replace the heat sensor in your oven
Apr 10, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana wall oven will not heat with new ERC
the heating element needs replacement.that the only solution.its common in this ovens as the heating element breaks down in between so it never heats up.
Mar 03, 2009 | Amana AOES3030 Electric Single Oven
F2 amana acf4215ac
F-2 is a "oven too hot" fault. says to replace sensor. that wouldnt make the unit heat with out being on though
Mar 14, 2008 | Amana ACF4215 Electric Kitchen Range
Amana Convection Wall Oven Model AOCS3040 Does Not Heat in any Mode
sure its possible, sounds like you've blown an over limit thermostat behind stove, gets too hot and for safety reasons cuts off unit untill replaced
Feb 11, 2008 | Amana AOCS3040 Electric Single Oven
Amana AER5515QA Electric Kitchen Range Logo
201 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
