No power going into power jack
How do I get to the Power Jack in my ACER TravelMate 2700. It seems the pin connection to the mother board is loose and I want to re-solder it back.
Any sugestions on how to take the laptop appart to resolder the power pin?
Thanks
Daniel
    Genius:
  • 1,102 Answers
You would be better off phoning small pc repair stores and getting the best price to replace it
not a good idea to fix it yourself
the cost usually runs between $60.00 - $100.00
I know people that fixed me themselves and believe me they have ended up with problems
Posted on Jan 13, 2009
Ard jack which iss it
If you can find a jack for that model then you can just see which hole on the board the center pin connects to. Positive is usually the biggest pin underneath in the center of the socket. The rest of the holes are usually
-ve / ground. Just paste this in Ebay search box.
acer travelmate 220 dc socket
Feb 14, 2012 | Acer Computers & Internet
Acer travelmate 2700 bios password and where is the CMOS battry on the mother board
your bios battery is soldered into the mainboard, its under the keyboard, next to the modem board and the bios chip itself.
In order to get to the battery you would first have to dissasemble the laptop, remove the keyboard, power buttons, and the top of the machine. You may also have to remove the display if its holding the top of the cover in place.
Removing the battery is no guarantee of reseting the password. You need to study the bios chip and find out which pins of it you need to short in order to reset its memory. In some cases the password might be stored on another chip.
Oct 09, 2011 | Acer TravelMate 2700 Notebook
Sir.
Open your laptop in back pannal and Remove CMOS battery (in mother board) then shote the CMOS socket in ternal two connections.then insert cmos and set your lap
Oct 07, 2011 | Acer TravelMate 2700 Notebook
Acer travelmate 5520 will not switch on when powered by battery or ac
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 22, 2010 | Acer TravelMate 5520 Notebook
The ac power plug was broken loose on my sony vaio vgn fw140e and finally the laptop failed to power up. I'm pretty sure the power adapter came loose from the mother board . I just don't know how to fix...
Sep 09, 2010 | Sony VAIO VGN-FW140E/W Laptop
How to replace D620 power jack? pwer jack is "loose" causing intermittent connection with power supply. the problem is "not" power cord.
The power jack is located on the motherboard. It is soldered to it. You have to remove the screws behind the laptop securing the back cover and disconnect the hard drive and GPU cables remove the keyboard so that you can pull out the motherboard. This is necessary since the solder joints are located under the motherboard and the jack is over it. There are 3 pins that are soldered. Remove the solder on all 3 and pull out the jack. Insert the pins of the new jack in the space vacated by the old pins and use a low diameter solder(2mm or less if available and lead free solder only) to solder the pins to the board and voila!
May 18, 2010 | eMachines eMD620-5133 Notebook
Acer travelmate 2480 the pin broke and is in the power plug
Don't try solder it. you will burn up *********** board. put some super glue on a tooth pick and pull out the pin and get a new power plug
Aug 01, 2009 | Acer TravelMate 2480-2968 Notebook
The dc power jack will not accept power. I have to wiggleit to get the blue light to show that the laptop is charging. My computer is the acer aspire 5920-6423. I dont know how to remove the key board to...
It's a little more involved than just removing the keyboard. You have to
Completely disassemble the laptop, until just the motherboard is in your
hand.
HOWEVER, for this Acer model it's a different installation, than the
normal one. This DC Power Jack uses a small wire harness. You just
unplug the old one, and install the new one. Let me explain,
I'm a tech who normally works on HP, Compaq, IBM, (Lenova now),
and Acer laptops. Acer's that are older than yours. All the DC Power
Jacks that I have replaced, are directly soldered to the motherboard,
and have no wire harness leading off of them. No plug connector on
the end of a harness, either.
In my search just now for a replacement power jack, my findings show
that the Acer Aspire 5920 series have a small wire harness.
Let me show you,
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=2977
Here the jack is offered minus the harness. You have to unsolder your old
harness from the defunct power jack, and solder it to the new one.
http://www.laptopjacks.com/view_part/Acer-Laptop-DC-Power-Jack-AC231916.html
You'll find the body of the DC jack is made of plastic. There is a metal
pin in the center. (This is the Positive post. + )
Some DC power jacks have a metal cylinder, or metal tube shape that surrounds the Positive metal center pin. This is the Negative connection.
Some just have a flat metal contact prong in the back for Negative.
If you have your AC adapter plugged in, and the plug is bumped, the metal
center pin can break loose from it's mount. Break loose from the plastic
body. Same thing for the metal 'shell' for the Negative connection, but this
doesn't happen as often.
Again, most DC Power Jacks have metal flat prongs that come out of the
power jack's body, go through the motherboard, and are soldered on the
backside. These solder connections can crack, and break, making an
intermittent connection. Doesn't seem to be the case for yours, IF the
jacks shown are the correct ones.
This may help you in your endeavor to disassemble your Acer Aspire.
(AND reassemble!) (TIP from me. DEFINITELY buy an ESD wrist strap
and connect the alligator clip to a good ground. They only cost about
$5 to $7 dollars. They are to relieve static from your body. Electro Static
Discharge wrist strap)
1.http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
2.http://repair4laptop.org/disassembly_acer.html
Jun 22, 2009 | Acer Aspire 5920-6727 Notebook
Acer Notebook 4330 No Power/No Charge
If the Notebook is only 1 month old i suggest you bring it back and see if they will replace it. Most likely the problem (for how you have explained it) is that the DC power pin (inside the notebook) is either broken or not soldered to the mother board correctly.
Being only one month old this is probably a faulty pin or installation from the manufacturer so this should not be a problem for the place you got it from to replace.
If you do have problems I suggest contacting the manufacture immediately to see if they will replace it.
I hope this helped
Have a great day.
Jan 28, 2009 | Acer TravelMate 2480-2968 Notebook
Reset bios password
just the jumper position on the mother board pin 1 and pin 2 will be occupied just unplug the power cord and remove the jumper and put the in 2 and 3 then wait for 5 sec then put the jumper to original position and power the laptop
Apr 26, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
124 people viewed this question
David Payne
David Payne
