Question about Dell 2350dn Laser Printer
200.32 paper jam
I deal with a lot of these failed printers. Looking for a quick fix for Del-2350DN 200.32 paper jam error message
pineworks
  • 4041 Answers
SOURCE: paper jam on Dell Photo 926
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
SOURCE: Dell 944 All-in-One Printer - printhead carrier jam
I used the menu on the printer to select change print cartridge and pretended to change the cartridge. Then I aligned the cartridge and that seemed to work for me. I wish Dell would have elaborated on how to clear a "carrier jam." I'm glad others have had this problem and were able to fix it too!
Posted on May 30, 2008
SOURCE: Paper Jam Error
lift up the scanner to reveal the cartridge compartment; under the chrome rod on which the cartridges run there are two small gaps about 8cm apart. In the right one should sit the paper sensor which is a small black rod that hooks downwards; the problem I had was my sensor had bent up and out of the gap so all I had to do was bend it gently back into position using a small screwdriver and now everthing works fine!
Posted on Jun 23, 2008
  • 5 Answers
SOURCE: Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Posted on Jan 09, 2009
SOURCE: Dell 3010cn paper jam 075-134 cannot get rid of error
The reason Dell said this problem was almost impossible to fix is because it is. There is a lift mechanism inside the housing for the MPF paper tray that lifts the paper to the roller to pull off the top sheet. The lift mechanism in this printer model is flimsy at best. There is a roller cam with a knuckle attached to it to does eventually break, causing a failure of the lift mechanism. The components to repair this problem are unavailable from Dell, and can only be salvaged from another printer. Here's the kicker... You have to disassemble the ENTIRE printer in order to replace this assembly. This took me 2 and a half hours to accomplish, and you're going to have to do it on 2 printers, as well as reassemble the fixed one. DO grease the cam assembly with some white grease to get the longest life possible if you choose this option. Best option? Either purchase another printer off eBay with a different problem and use yours to fix that one, or, as Dell so lovingly suggested, purchase a new one. The cost of today's color laser solutions make purchasing one of these printers a much more viable option than fixing your 3010cn.
Posted on Aug 31, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Tip
Paper Jams
The most common error message is the notorious paper jam message. You do a quick look and then determine there is no jam. What next? Well here is a tip that will save you possible a service call. If you find a sheet of paper that has jammed, look at it closely. It is all together as one piece or is there the tinest of pieces missing? It only takes a tiny piece to cause a jam error. Pull the print cartridge out and with a flashlight look inside the printer and especially at each roller and see if there is any hint of a piece of paper. Look closely because you can miss something. Next open the paper tray and make sure the paper guide is firm against the paper. This will cause a jam. Just drove an hour and a half this week for this issue. The paper guide was not up against the paper causing the jam. If you have a small vacuum I suggest you vacuum out the printer because there are times that the sensors can get covered with paper dust causing them to fail. Hope this helps!
on Oct 26, 2011 | HP Office Equipment & Supplies
Paper jam error
could be a stuck, failed, or out of place sensor. recheck all sensors in paper path(s) carefully
Sep 19, 2013 | Kyocera Office Equipment & Supplies
What does the error message "out bin full" means
This error indicates that the sensor that detects when too much paper is stacked in the output bin to allow more paper to exit. This flag sometimes sticks and a quick check is to make sure that nothing has become jammed where the paper exits the printer. Most common cause is the flag getting jammed because someone has remove the paper the wrong way. I have never seen the actual sensor fail.
Jul 06, 2011 | HP LaserJet 8000n Printer
Printer says jammed , cleared printer completely, still says jammed , no evidence of jam,disconnected printer, reconnected, ,still says jammed,
The possible reasons for this could be
  1. (For Laser Printers Only) Toner sediment in the fuser unit. This specially occurs if you constantly use smaller paper sizes than the paper tray size. To resolve this you should disassemble the printer, take out the fuser unit and clean the toner sediment. The sediment can get rock solid so clean it carefully. If you are not accustomed with electronic components better visit a technician.
  2. The paper sensors pulling spring may be detached. In this case the sensor gets a message that some paper exists in the fuser unit so a paper jam message is triggered. Fix the spring and you are done.
Nov 27, 2009 | Office Equipment & Supplies
Lexmark x6575 printer error message clear paper jam
Success and relief at last!
Thanks to Dinky on another web site who had the same problem with his Lexmark X6575 printer (a similar printer). The resolution of the problem once I had read Dinky's explanation took less than 30 seconds!
Dinky's exact words on the issue are as follows:
" Dinky commented 5 months ago
Hooray!!!...after lots of hours trying to fix my printers 'Paper Jam' message, even tho' there was no paper jam in my lexmark x6575, but the message refused to go away...I have finally got it to work!!!...
WHAT I DID......
There is a long silver metal bar that the ink cartridges run along. Well just underneath this there is 8 little roller feet that sit on top of another silver/cream roller. Well in between these, in the very centre, you will see a little black plastic nib like thingy...While the machine is turned on, press this little black thingy (best to use a pen or something like, as it's small) and what should happen is the silver/cream roller will make a quick rolling motion....Hey! presto the 'jam message' disappears and the lcdmag-glass_10x10.gif screen should show set-up options (like date, time, ect).
I hope these instructions are clear enough to follow, and I also hope this solves that dreaded 'Paper Jam' message for you all....Good Luck!
Regards, Dinky "
Sep 14, 2009 | Lexmark X6575 All-In-One InkJet Printer
Network Printer 12 paper jam
In order for a jam message to reset to READY, the printer logic is looking for an "06 COVER OPEN" message. The top cover of the machine must be opened to clear the jam message. If the top cover interlock switch is stuck closed, the printer logic never clears the jam message, even after all the paper has been removed. The printer appears hung with the paper jam message and can only be made READY by powering the printer Off and back On.
Jun 16, 2009 | IBM Network Printer 12 Laser
6110xi paper jam, or something worse?
Actually, the "paper jam" message can be displayed due to a variety of jam locations and other causes. Starting by looking in the back of the printer is a good first step, but you can have a jam in the front or even in the automatic document feeder (although that one should be apparent because it's sticking out the front end.
HP.com has a web page that goes into a lot of detail about where to look for a paper jam and what other conditions in your product might cause such a message to occur. The solutions are available as well. Take a look here:
Paper Jam error
Try those solutions and post back your results. Good luck.
Nov 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Dell 2350dn Laser Printer Logo
469 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
