Ruud Silhouette II Fails to Ignite
Hey Folks,
I have a Ruud Silhouette II Natural Gas Furnace. When the heather kicks on, the fan kicks on first, the igniter tries to light... 1 of the inshot burners comes on, and after about 3 seconds cuts off. it repeats this process 3 or 4 more times, and it seems completely random whether it'll actually stay lit or not. Sometimes it goes into lockout without igniting as it gets colder and colder in the house! Any suggestions? Thank you
  • 1 more comment
  • Anonymous Jan 14, 2009
    adam1619,
    Thank you for writing back. I see the flame sensor rod, it's at the leftmost inshot burner position, the igniter is at the rightmost inshot burner (this is the one that lights). It seems like it'll be tricky to remove but I can try to clean it I'm terrified about these attempts to light racking up my heating bill..
    I do know that if it fails to ignite, the OK light blinks once.. does that indicate a problem or a lockout? Thanks :)
  • davilalj98 Mar 14, 2009
    I turned off the knob to the gas then turned it back on as the instructions say to do but when i turn it back on the fans turn on and it looks like it is trying to ignite but it doesn't catch and the house is getting colder and colder.
  • Anonymous Mar 13, 2014
    Is there and internal filter?
  • 3 Answers
Its possibly the board make sure the furnace is completely grounded before replacing the board Rudd furnaces have issues with when they are not completely ground they will blow the board.
Posted on Feb 11, 2012
Sounds like you have bad flame sensor or the sensor is in a bad postition. To get eliminate the lockout turn the power off to the unit and back on again. Look at the circuit board light and see what the troubleshooting code is.
Posted on Jan 13, 2009
My Ruud Silhouette gas furnace ugdg 07 model blower stays on. The heat and air both work but it is pricing my energy bill higher. Whats the cause and can I just turn off the power to the unit (what about...
Problem could be the thermostat setting in "fan on" mode. Thermostat could be shorted between Y,R and G. Fan relay points soldered together or main board shorted.
Nov 03, 2013 | Ruud Gas Furnace - Excellent Condition -...
Heater won't turn on even with a good HSI
Remove at least one of the wires going to that solenoid on the gas valve. Check for continuity between the 2 legs of the solenoid. If you cannot get a reading then you have a bad valve. If you indeed do have continuity start the furnace and see if voltage is going to the valve. If you have no voltage going to the valve then you could have a bad board. If voltage is going to the valve then the gas valve has failed internally or you ain't paid the gas bill. LOL.
Jan 06, 2012 | Heating & Cooling
Hello, I have a Ruud Silhouette II Plus 2 gas furnace installed in my garage. This is the first time that I've had a gas furnace (living on my own) so I am unsure of how it actually works. One thing...
If you have gas furnace, the outside unit will not come on unless you have dual fuel/ gas and heat pump. If you can look at wires in thermostat, if you have no wires going to O or B then you don't have heat pump. Normal tstat wiring for gas furnace and air conditioner. R,W,G,Y and maybe C.
Jan 24, 2011 | Heating & Cooling
My ruud silhouette II gas furnace starts up and runs for 15 mins. or so and shuts off. just replace thermosta and filter. ??
are all the vents in the house full open?
is the flue vent pipes clean and un obstructed?
be sure none of your ductwork on the air return side is collapsing restricting airflow when the blower tries to run.
Is the draft inducer fan coming on?
could be a bad high limit switch.
Jan 05, 2011 | Heating & Cooling
I HAVE A RUUD SILHOUETTE II GAS FURNACE. The glow rod glows bright, the fan whirrs for 30 seconds there is a click and nothing happens...the fan stops. No flame...nothing.??
this can be a few things. tonight, i fixed one with the same symptoms and it ended up being the gas valve was bad and the gas pressure on the outlet side was only 1 in water column on an LP furnace. That is one thing and would have to be checked with a manometer. The other is the board may not be sending 24volts to the gas valve telling it to open. hope this helps
Jan 05, 2010 | Ruud UBHC Air Conditioner
Gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Dec 21, 2009 | Heating & Cooling
Sticky manual gas valve
Sounfds like the thermostat is on the blink.?
Oct 17, 2009 | Heating & Cooling
Heating & Cooling Logo
1,825 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
