Question about Lexmark X2350 All-In-One InkJet Printer
Failed to open or initialize the FaxMan Database
2 Suggested Answers
  • 684 Answers
SOURCE: HAVING PROBLEMS FAXING, I GET
Clear NV RAM.....
Unplug the Power Supply from the Printer....
Press and Hold the #5 button on the Printer and plug in the Power Supply.......
Don Release the #5 button till the Printer turns on completely....
After releasing the #5 button........
Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM.....
Now as soon as the Printer is Restarted.......
U will be able to send and recieve faxes.....
Thanku.............
Posted on Jan 22, 2009
I can not open the letter in any way
Resolution:
Follow the given steps to resolve the error:
1) Restore the data from recent database backup
2) R fixup -f", then "compact -c -i" command to recover the corrupt database.
Note: If the inbuilt Lotus repair doesn't help you to repair the corrupt database then, you require some alternative Lotus Notes Recovery software to Lotus Notes repair tool
Jan 26, 2018 | Lotus Computers & Internet
Failed to Rebuild Outlook 2016 Mac database
This is a sign of corrupt Outlook Mac database. This can be resolved by rebuilding the database. Try out these steps:
    1.Quit all applications
    2.Determine the size of your identity
    3.Backup Current identity
    4.Rebuild the database
    5.Create new identity
    In case if this does not resolve your problems then you can fix this issue by using third party software like Stellar Phoenix OLM Repair. I suggest you to try its demo version first: https://www.stellarinfo.com/email-repair/outlook-mac-repair.php
Apr 28, 2017 | The Computers & Internet
Toshiba e-studio 356SE error code f 121 Database abnormality user information management database
user management database is corrupted.
Delete the log in the following procedure:[5] + [C] +
[POWER] ? 4. Initialize database ? 1. LDAP database
(to delete user database) (Note that all user, role, group
and accounting data will be deleted.)
If the error is not recovered, reinstall the system software.
([4] + [9] + [POWER] -> 4. System Software(HD data))
Jul 14, 2016 | Toshiba E-Studio 356 Multifunction Copier
On our Dynamics RMS POS system, the database appears to be full. In the system administrator, under database properties, available space is 0kb and usage is 100%. I cannot find any function to allocate...
are you using MS SQL 2005? if so,
try this one:
1.open your MS SQL Server Management Studio,
2. connect to your data server and locate the database that has an issue on disk space
3. Right click that DB and select properties,
4. a new window will open, on the upper left part, select Files, now you may notice the settings for initial size of your DB.
5. on the autogrowth column, click the button corresponds to your database.
6. a new window will appear and displays options for your database autogrowth settings,
7. set your desired configuration, apply and your done,.
or you may check this blog:
http://blog.sqlauthority.com/2007/08/08/sql-server-2005-ssms-enable-autogrowth-database-property/
thanks
Sep 03, 2011 | Microsoft DYNAMICS RMS STORE OPERATION...
Screen is frozen, can be turned on and off but wont go passed initial stage
1. Connect Navman GPS to PC viamini-usb cable. 2. Go to 'Start' 3. Go to 'My Computer' 4. Open the 'Navman' folder 5. Open the 'Database' folder 6. Delete the following file only- 'dababase.db' 7. Close the folders 8. Disconnect the mini-USB cablethen restart the Navman GPS by sliding the switch to 'Restart' then back to'On' after 10 seconds. The unit shouldstart & the database.db file will be re-generated automatically.
May 17, 2010 | CaseCrown Navman S50 Portable GPS...
Verify database
If your database is located on a mapped drive, then check your drive letter for the mapped drive. If it is "X:" for example, then your software will need to be pointing to the X: drive within the SetDBStr.exe setup tool.
That tool can be accessed by exploring your C: drive as follows:
c:\program files\asureid\program
You should run SetDBStr.exe and specify "Custom Configuration" (second choice) and then browse to the database on your mapped drive. Hope that helps!
May 18, 2009 | Synercard Asure ID Enterprise (932011001)...
HAVING PROBLEMS FAXING, I GET A MESSAGE AFTER I SCAN SOMETHING TO FAX THAT READS "FAILED TO OPEN OR INITIALIZE THE FAXMAN DATASE"
Clear NV RAM.....
Thanku.............
Jan 19, 2009 | Lexmark X5470 All-In-One InkJet Printer
Oracle Error
if it occurs after imported, it's because ctx'preferences was not imported. Try to get preferences from source (by reverse engeneriing or see with ctx_report.create_index_script package).
You will get severals scripts to execute on target db
Sep 08, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Faxman.comm win error
i have a x3450 printer i can't get faxman.comm off my computer. i can't use it please tell me how to remove.it is causing me a promblem.
Apr 15, 2008 | Lexmark X3350 All-In-One InkJet Printer
Original sync worked all others failed with 650 and Outlook 2003
I was ready to give up completely. Uninstalled, reinstalled, nothing worked. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now. This worked for me. I hope it helps with your errors.
Sep 12, 2005 | Palm Treo 650 Handheld
Lexmark X2350 All-In-One InkJet Printer Logo
1,165 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
