How do I connect a pre amp to a kenwood KR-V7070 receiver
  • 319 Answers
SOURCE: problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Posted on Aug 14, 2008
  • 4234 Answers
SOURCE: I have an old Kenwood receiver that does not power up
If the voltage was 110, the polarity should not have made a difference. In all probability, the input power transformer has an open primary. This can happen with a power surge or just because of age. If you have an Ohmmeter, with the unit unplugged, measure across the 2 input pins for the main transformer. It should read about 3 ohms or less. If it reads infinity, it is open and must be replaced.
Keep us posted,
Dan
Posted on Mar 12, 2009
dunnbiker
  • 8546 Answers
SOURCE: My TV has audio (left & right) & video
Audio can usually go either way to a TV. In or Out. Why someone would want to hear external audio through a TV's marginal audio electronics and speaker(s) is beyond me, but sometimes that is what they want.
Take the audio from the receiver via whatever unused Tape or Video function connectors you like to the TV's Audio L & R IN. Anything the receiver processes will be audible through the TV as long as you DON'T select that function for listening on the receiver.
Listening to TV-related audio through the receiver and its (presumably better) speakers makes much more sense, but again, the TV's marginally audio capabilites place a serious limitation on sound quality expectations. In your case, stereo is as good as it could be.
If your TV has Audio Out jacks, just run them to any convenient Line Level input (NOT Phono). If your TV has internal audio controls for volume, set it to Fixed so the TV's volume control doesn't affect the sound going out to the Kenwood.
A better TV-related audio solution would be to connect the BEST audio of whatever source you're watching directly from that source to the receiver. Cable, DVD/BD, SAT always have 2-channel analog RCA connectors as well as (unusable on the Kenwood) digital audio outputs.
VIDEO from the Kenwood to the TV:
You describe your TV having Composite (3 -RCA-style cables). The Kenwood is limited to Composite (Lower-quality, single Video RCA-style cable). Check your TV for a single Video In connection and run THAT from the Kenwood's Monitor Out so you can pass other video through the receiver.
In its day this receiver was pretty high-end but to really enjoy modern multichannel audio from video sources you might consider an upgrade to a true multichannel Audio Video Receiver. For one thing it would support digital audio and probably Component and HDMI video. You could still use the Kenwood's amplifiers to drive speakers or as a secondary system.
Posted on Apr 30, 2010
SOURCE: I have a Kenwood KR-A4010 Am/Fm Stereo Receiver. Every five seconds the sound fades in and out. Can anyone find a solution to this problem?
i have a kenwood kr-a4010 it works no sound in speakers
Posted on Jun 02, 2010
  • 3 Answers
SOURCE: Yesterday, I connected two speakers to my Kenwood
Always always always unplug the electrical cord before you change any speaker connections. One tiny ground-fault can fry the circuitry.
Posted on Dec 08, 2011
How to hook up a pioneer 7 band gr 470 equalizer to a Kenwood kr-v6030 receiver
Connect one pair of RCA cables between the receiver and equalizer. Connect one pair of cables to the pre-amp output channels on the receiver and the other end of the cable to the left and right channel inputs on the equalizer. You will usually find these channels on the rear of the equalizer.
May 09, 2016 | Pioneer Audio Players & Recorders
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Aug 10, 2011 | Kenwood Audio Players & Recorders
Where on the Kenwood KR-V5580 do I connect a sub woofer
Wherever the unidentified subwoofer's manual recommends. As there are no volume-controlled pre-amp outputs it would have to be a model that accepts full-range speaker level input if you want to control its volume locally.
Jul 02, 2011 | Kenwood KR-V5580
Yesterday, I connected two speakers to my Kenwood KR-V7070 Receiver and it worked fine but today I can't hear anything coming out of the speakers. I may have pressed a wrong button on the remote. Also,...
Tell us some details about the speakers.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-KR-V7070-Receivers-manual/id/479bh947/t/2/
Familiarize yourself with the controls. Understand every indicator on the front. There may be a clue there. Turn the volume to a medium or low level before changing any settings or you may be in for a BIG (and costly) surprise when you find the one that was in the wrong position.
Let
Mar 02, 2011 | Kenwood Audio Players & Recorders
Where can I download an owners manual for a Kenwood KR-V8080 tuner/amp. Thanks
You can download at:
http://www.kenwoodusa.com/z_Support/Home_Electronics_Owners_Manuals/
Select your product number from the list and the download link will appear below. Four thumbs, please.
Jan 05, 2010 | Kenwood KR-V8080 Receiver
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Jan 01, 2010 | Onkyo M-282 2-Channel Amplifier
I'm just trying to find out if the Kenwood KR-V7050 has an optical input for an adio connection for a Blu-ray player.
Sorry, no digital inputs at all. It's a stereo receiver from the 80's.
I have the KR-V9020 and it is probably among the most feature-laden pre-digital surround receivers built. I still use it in a bedroom even though I have a full-blown 7.1 rig in the living room.
Dec 26, 2009 | Audio Players & Recorders
I have an old Kenwood receiver that does not power up anymore. Not even the red standby light glows. I have power to the unit but that is it. I have checked the fuses on the inside but after that I am no...
Keep us posted,
Dan
Mar 12, 2009 | Kenwood Audio Players & Recorders
Problem with playing my Kenwood KR-X1000
Nov 19, 2007 | Kenwood KR-X1000
37 people viewed this question
 Grubhead
Grubhead
