Question about Jura Capresso Impressa S9 Coffee Maker/Espresso Machine
Malfunction 4 wont work - Jura Capresso Impressa S9 Coffee Maker/Espresso Machine
  • aaaa Dec 12, 2012
    waste of time
On standby mode the display shows 4 dashes,when power button is depressed display reads good-bye and returns to 4 dashes.why wont amp switch on
seems like the amp could be malfunctioning with its logic board having some issues i cant say much since most logic boards arent always easy to repair...
Feb 23, 2017 | The Audio Players & Recorders
What os code 12
The FI light on our Yamaha is much like the check engine light on your car. If it comes on it is real easy to check the code, and for the bike to tell you what is up. Just ground the diagnostic wire and it will start reading them out. Mine just had one code, but it will read out as many as you have. Then you can know what to address to potentially fix issues with the bike. There are more than this, but below are some basic codes to work with. Service Codes FI Indicator Light (LED) Problems
11 Main throttle sensor malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or short
13 Inlet air temperature sensor malfunction, wiring open or short
14 Water temperature sensor malfunction, wiring open or short
15 Atmospheric pressure sensor malfunction, wiring open or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor malfunction, wiring open or short
24 Speed sensor malfunction
31 Vehicle-down sensor malfunction, wiring open or short
32 Sub throttle sensor malfunction, wiring open or short
34 Exhaust butterfly valve sensor malfunction, wiring open or short
35 Immobilizer amplifier malfunction
36 Blank key detection
51 Stick (Ignition) coil #1 malfunction, wiring open or short
52 Stick (Ignition) coil #2 malfunction, wiring open or short
53 Stick (Ignition) coil #3 malfunction, wiring open or short
54 Stick (Ignition) coil #4 malfunction, wiring open or short
62 Sub throttle valve actuator malfunction, wiring open or short
63 Exhaust butterfly valve actuator malfunction, wiring open or short
May 01, 2016 | 2005 Yamaha FZ6 Fazer
My bike will crank for a split second and wont start again and flashes f1 but I put wire to ground on battery and will not get a code
Hi Keith, The link below is a short youtube video explaining the fault codes(worth watching)..... CHEERS
https://www.youtube.com/watch?v=eW7hnCLEA1M
The FI light on our Kawasaki is much like the check engine light on your car. If it comes on it is real easy to check the code, and for the bike to tell you what is up. Just ground the diagnostic wire and it will start reading them out. Mine just had one code, but it will read out as many as you have. Then you can know what to address to potentially fix issues with the bike. There are more than this, but below are some basic codes to work with.
32 Subthrottle sensor malfunction, wiring open or short
62 Subthrottle valve actuator malfunction, wiring open or short
Apr 01, 2016 | 2009 kawasaki Ninja 650R
How can I repair a malfunctioning left front signal light?
The flasher unit for the four ways is separate from the turn signal.
If the rear light is flashing fast means the front light is malfunctioning. Check all wiring from the dash to the light itself. I had one a wire was pinched and had broken
Jul 19, 2015 | Cars & Trucks
My 1993 Toyota 4 runner 2wd wont work but my 4wd does .. in 2wd the drive or reverse wont go but will in 4wd
Hi do check gear linkages or cable adjustments.otherwise possible gearbox malfunction.
Jan 05, 2015 | 1993 Toyota 4Runner
F4i honda 2001 light is flashing 7 times on diagnostic code {fi light} then staying on does anybody know what 7 blinks mean
7 = Coolant Temp sensor or wiring.
A long blink = "10"
A short blink = "1"
DNS = Engine does not start
EON = Engine operates normally
BLINKS : PROBLEM, SYMPTOMS
No blinks: ECM malfunction, DNS
No blinks: ECM power / ground circuit malfunction, DNS
No blinks: ECM output line malfunction, DNS
No blinks: MIL circuit malfunction, EON
Stays lit: Data link circuit malfunction, EON
1 blink: MAP sensor circuit malfunction, EON
2 blinks: MAP sensor performance problem, EON
7 blinks: ECT sensor circuit malfunction, Hard start at low temp
8 blinks: TP sensor circuit malfunction, Poor performance on quick throttle operation
9 blinks: IAT sensor circuit malfunction, EON
11 blinks: Vehicle speed sensor circuit malfunction, EON
12 blinks: No. 1 Primary injector malfunction, DNS
13 blinks: No. 2 Primary injector malfunction, DNS
14 blinks: No. 3 Primary injector malfunction, DNS
15 blinks: No. 4 Primary injector malfunction, DNS
16 blinks: No. 1 Secondary injector malfunction, DNS
17 blinks: No. 2 Secondary injector malfunction, DNS
18 blinks: Cam pulse generator, no signal, DNS
19 blinks: Ignition pulse generator, no signal, DNS
21 blinks: No. 1 O2 sensor circuit malfunction (California only) , EON
22 blinks: No. 2 O2 sensor circuit malfunction (California only), EON
23 blinks: No. 1 O2 sensor heater malfunction (California only), EON
24 blinks: No. 2 O2 sensor heater malfunction (California only), EON
33 blinks: E2-PROM in ECM malfunction, EON
48 blinks: No. 3 Secondary injector malfunction, DNS
49 blinks: No. 4 Secondary injector malfunction , DNS
Aug 30, 2014 | 2001 Honda CBR 600 F(4)i
Obo scanner gave me these codes p0171, p0201, p0202, p0203, p0204, p0321 and it wont start? please help i noe what the codes mean just dont noe what to go for
I will give you what the codes mean and you can then work out what to replace.
code p0171 refers to system too lean--bank 1===causes intake / exhaust leak---AIR system---MAF/VAF sensor---fuel pressure/pump---injector/s---HO2s
code p0201 refers to injector 1--circuit malfunction===causes--- wiring--injector ---ECM
code p0202 refers to injector 2 --circuit malfunction===causes --wiring---injector--ECM
code p0203efers to injector 3 --circuit malfunction===causes---wiring--- injector --ECM
code p0204 refers to injector 4 --circuit malfunction===causes ---wiring ---injector ---ECM
code po321 refers to crank shaft position (CKP) sensor/engine speed (RPM) sensor---range / performance problem===causes---air gap---metal particle contamination---insecure sensor /rotor --wiring---CKP/RPM sensor.
Jan 05, 2014 | Audi TT Cars & Trucks
The transmission wont shift and reverse wont work. It also bucks and tries to die.
Check Engine Light? When a 'check engine light' (MIL=Malfunction Indicator Lamp) is turned on, there is a DTC (Diagnostic Trouble Code) set/stored in the ECM/PCM (Engine Control Module/Powertrain Control Module). This code identifies which engine management system component/function experienced a malfunction. Once you pull/read this code, you may begin diagnosis.
Sep 07, 2011 | Hyundai Accent Cars & Trucks
Whats does b_9d mean. My mixer wont start to mix. The power is good but it tels me b_9d.
that fault is a b_gd.there are 10 things that can cause this.1.start sw.momentary contacts not closing. 2.stop sw. contacts open. 3.bowl guard sw. open or malfunction(b_gd)displayed on timer.4.contactor 1con malfunction.5.timerboard malfunction.6.wiring incorrect from sr drive to motor or 1con.7.sr drive malfunction 8.1 con monitor from control drive disconnected from contactor coil9.encoder malfunction 10.motor malfunction. hopefully just your bowl guard switch is no good. hope this helps, dont forget to vote, monomoy
Feb 01, 2010 | Hobart HL600 Legacy Stand Mixer
Jura Capresso Impressa S9 Coffee Maker/Espresso Machine Logo
18 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
