Question about Sharp 32U-S610 32" TV
Lower volume button wont work - Sharp 32U-S610 32" TV
    Top Expert:
  • Sharp Master
  • 14,553 Answers
Replace the keypad or get an original remote.
Posted on Dec 12, 2012
Why isnt my tv volume not working?
make sure you have tried the volume with the remote and the buttons on the set, if the buttons on the set work then their is a problem with the remote. if neither work then the sound circuit is bad in the set.
May 05, 2014 | Coby Televison & Video
Sony walkman volume
spray 90% rubbing alcohol from a spray bottle into the volume button area push the button reapeatedly or, turn the knob back and forth then: let it dry for about an hour then try to use it the control should be clean and working again.
Dec 03, 2013 | Audio Players & Recorders
Volume button on tv doesnt work no remote
two choices, get the keyboard on the set repaired or get an original sharp remote which among remotes is not too expensive.
Dec 12, 2012 | Sharp 32U-S610 32" TV
The volume on my plasma tv goes up to 100 and when i lower the volume it will take a second volume for the volume to go up to 100 how can i fix my tv to lower the
The tact switch is most likely defective which is keeping the volume up engaged. Replace the tact switch should fix the issue. If not the button assembly pcb will need replacement. You can get replacement boards from www.tvcircuitboards.com
Dec 10, 2012 | LG 60PC1D 60 in. Plasma Television
DNX7120 issue with VOL increase button. When this button is pressed once, the volume skyrockets to max, VOL decrease button does not work right away to lower the volume, nor does the ATT button. Unit...
I had the same issue. You can use the on screen volume buttons on screen to stop issue and don't use the physical buttons anymore. Watch out about a month after the volume problem started all physical buttons on my DXN7120 stopped working. There are a few reports of this online, I have not found a fix yet.
Dec 15, 2010 | Kenwood DNX7120 Car GPS Receiver
Volume is stuck, buttons on tv wont lower it and the remote will not lower it..anything i can check??
Sometime if a button is stuck it can lock up the processor and cause all the buttons connected to it to not function. Insure all buttons press and release normally. If all buttons appear to press and release in a normal fashion a trip to the repair center may be call for.
Jul 03, 2010 | Initial HDTV-320 32 in. LCD TV
Can not get volume to lower
On my player you have to push the A-B button first then use the button your describing to adjust the volume.
Dec 04, 2009 | Jensen SMP-115 MP3 Player
Volume buttons won't work, camera button wont work, and speakerphonew button wont work. Happened out of nowhere. Cannot lower/raise volume on side of phone, only vibrate works.
Hello.
Welcome to Fixya's Community.
These problems HAve been related to a damaged flex cable.
This is the cable which in the U700 connect the lower part of the phone to the lcd part (with the screen, speaker, camera and touchscreen buttons). All the data such as screen images, camera pictures, speaker sounds pass through this cable from the main board which is located in the lower part of the phone.
Unfortunately, each time one opens the phone, the cable slides between the two part of the phone. In the long term, as the cable is thin and soft and this movement causes frictions between the cable and the parts, the cable consumes itself. the damage of the cable could results in weird effects on the phone.
In order to fix that you need to replace that part.
its easy.
just take the phone apart and locate the flex cable and replace it.
believe me you can do it yourself.
  • The Flex cable of your phone cost 3 $
  • A phone repair shop will fix that for 25 $
see if you can find it on eBay.
remember its SCH-U700 Not SGH-U700 there is a big difference.
Additional Help:
Learn more about Flex Cables.
Good Luck
Nov 10, 2009 | Samsung Gleam (SCH-u700) Cellular Phone
Volume button wont work only to lower volume works
Are you talking about the Amp working in lower volumes or the cd player? If it is the amp do you have the speakers bridged.
Mar 06, 2009 | Eclipse Premium 34230 Car Audio Amplifier
Volume won't go up
CAMBIALE EL IC02 EEPROM 24C02 O EL 24C04 Y TE GARANTIZO QUE SALDRAS DE ESE PROBLEMA...
Aug 07, 2008 | Samsung TXG2548 TV
Sharp 32U-S610 32" TV Logo
18 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
