Question about Bosch B36ET71SNS Bottom Freezer French Door Refrigerator
HOw do I reset the water filter light on a Bosch B36ET71SNS Bottom Freezer French Door Refrigerator
  • 833 Answers
SOURCE: Dodgy fridge light
Generally, these doors drop from excessive weight, a warn part or loose fittings. Unload the door and investigate. You may also want to check that the unit is levelled...the box may be warping/sagging...although this is unlikely.
Posted on Dec 24, 2007
SOURCE: bosch fridge leaking water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have the same problem,warranty just ran out but its been leaking on and off for ages,must be this model.This much Ive figured out,what happens is the drain hole gets blocked from ice freezing over the hole at the back of freezer, the drain water has to go somewhere, since it cant leak out of the drain hole where it suppose to it ends up pooling under the vege compartment before ending up on the kitchen floor.Now if this is your only problem,someone suggested to me to run a piece of copper wire from the defrost heater to the drain hole so no ice can build up there,hence no more leakage.To do this you'll have to take the back panel off and see for yourself,I did this and Im a novice.Make sure you turn off and unplug the fridge first and wait for it to defrost.
Now I think I have other things wrong with mine,after leakage problem the refrigeration compartment wont cool anymore but the freezer part remains working as usual.Ive nailed this down to one of the following not working... Thermostat / timer / defrost heater.So one or more of these needs replacing.Im just trying to look for a manual which shows the nuts and bolts or the refrigerator (not the "How to use" type manual which I have).
Posted on Apr 05, 2009
  • 118 Answers
SOURCE: Hi . My questionis: Ive got a freezer /
probably defrost problem check for ice behind panel where fan at. defrost t-stat bad is most common
Posted on Oct 27, 2009
heatman101
  • 43501 Answers
SOURCE: Formation of ice in freezer compartment
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 20, 2010
SOURCE: Hello, My Bosch B22CS50SNS Side by Side
Same thing just happened to mine. Was a solution found for this or did you call for a repair?
Posted on Jan 19, 2011
Have changed water filter, but indicatot panel calls for order h2o filter, and comes on every time we dispence water. why?
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
Oct 16, 2012 | KitchenAid KBFA25ER Bottom Freezer French...
Have had Bosch refrigerator for about three weeks - love it - but, after about three days it started clicking or knocking - did this for about thee days and stopped for a week - now it is doing it again...
Well one of two things ,first is it could be the ice maker and those pops are the ice coming off the rack which I suspect and the other is a relay clicking coming in and out of defrost cycle for the ice maker. Get enough ice made and have the switch in the up position and see if it stops, if not try and locate it and tells us again
Apr 08, 2011 | Bosch B36ET71SNS Bottom Freezer French...
The reset filter light is red. I do not have an owners manual.
press and hold Reset Water Filter Button until it goes out, holding it to long will make it come back on.Please rate if it helps
Jan 20, 2011 | GE Profile PFSF5NJW Bottom Freezer French...
I have a red light that looks like something water dropplets?
Ok, That sounds like a water filter change light. The model number you gave is for an oven and if possible could you give me the true model number for your Samsung refrigerator. That way I can tell you more about how to change the filter and reset the red light, Thanks Sea Breeze
Dec 27, 2009 | Samsung RF265AA Bottom Freezer French Door...
How do I reset the lg water filter indicator light on the control panel of my lg lfx21971st bottom freezer french door refrigerator?
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
Oct 14, 2009 | LG LFX21971ST Stainless Steel Bottom...
Reset Filter Indicator Light is on
Look for your model number from the sticker inside the fresh foods section of the refrigerator, usually on the liner near the door opening. Now, go to http://www.geappliances.com/service_and_support/literature/ to download a use and care manual for your model, as the reset procedure may vary by model. The filter is usually located at the very back right upper side of the fresh foods compartment, but again, it may vary by model.
Apr 11, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Filter light won't go off
Did you press and hold the reset filter light for at least 3 seconds?
Jul 11, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Bosch B36ET71SNS Bottom Freezer French Door Refrigerator Logo
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
