Question about Kenmore Side by Side Refrigerator
What is the current value of Kenmore Refrigerator Freezer model 363.9565484 if it is in good working condition?
Bought new Kenmore Elite and would like to sell old one (purchased in 1997) to a neighbor, but do not know how much to ask for it. Can you tell me what it is worth if it is still in good working order and looks like new?
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
  • 2318 Answers
If this appliance is new, I would suggest to contact the vendor or manufacturer and ask them for in home service.
It could be the thermostat that might be not working properly or not set properly.
Check the user manual for more info on the thermostat settings.
Posted on Jul 08, 2008
  • 399 Answers
SOURCE: Refrigerator and freezer not cooling but lights are on and motor
It's not cool If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator
Posted on Dec 06, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
  • 363 Answers
SOURCE: replacement instructions for ice maker in
I have found service manuels at appliancesfactoryparts.com
Posted on Jul 17, 2009
Looking for a manual for Kenmore Elite Refridgerator MFG 2005 Model #106.74219400
http://www.managemylife.com/mmh/owner_manuals/5877
/KENMORE-ELITE-Top-Mount-Refrigerator-L0408620
Apr 20, 2011 | Kenmore Top Freezer Refrigerator
Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker: just bought a kenmore elite model 795. I t says i...
Look for a lever to select cube size right on the icemaker.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
New Fridge won't cool.
not a epert just trying to help you,, if you just bought it see if warranty is still good if so call the people you got it from to replace it,,, cause it sounds like the run start compassitor, or the compressor not working, hope this help you
Oct 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite refrigerator freezer won't close tight.
Head over to the manufacture's website. www.searspartsdirect.com
Enter your full model number in, and you can see expanded diagrams and part ordering information.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Just bought a kenmore elite bottom freezer trio model and display panel shows o ff. Expect this means whole unit is off but manual does not say how to turn ON in the setting the controls section of manual....
I just purchased a similar model and had the same frustration. Finally called the store and it was in DEMO mode. Open the freezer draw and hold down the Ultra Ice & Refrigerator Temp buttons simultaneously for 5 seconds. That worked for me and hope it will do the trick for you.
Jul 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
It sounds like the fan is not circulating the air from the freezer to the fridge. Since it's new then you should contact the store where you purchased it for exchange or repair immediately.
Jul 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Refrigerator side by side
These covers can be squeezed from the sides to release the tabs that hold it in place.
Jun 01, 2008 | Kenmore 57029 Side by Side Refrigerator
Kenmore elite refrigerator, model # 59676534500
May 29, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Trio Elite 596.75529400
Has anyone got you a solution? I think I have the same problem with mine!
KSheridan
Oct 27, 2007 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Kenmore Side by Side Refrigerator Logo
96 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
