Question about GE Profile PGS968SEPSS 30" Slide-In Gas Ranwith 4 Sealed Burners, 4.1 cu. ft. Two Speed Convection Oven, Self Clean, PowerBoil Burner, 3 Heavy Duty Oven Racks, StoraDrawer and ADA Compliant: Stainless Steel
Oven is not working Touch Pad, Broiler, and Top Range Burners ok
The exact model number is GE Profile PGS968SEM3SS 30" Slide-In Gas Range stopped working today. The touch pad seems to be working. The stove top range burners are all working. Even the broiler still seems to work. From my online research, it sounds like other people have had the same experience with other similar GE Profile Ranges. Some have mentioned switching the igniter may fix it. Does that sound right? Is that easy to do? How exactly?
5 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: Where do I find the model number of my GE Profile gas range?
on back of appliance near top behind control panel but should be on outside of rear cover
Posted on Jul 28, 2009
marka19
  • 1430 Answers
SOURCE: My GE Profile gas oven will not ignite. The
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on May 13, 2010
national_a_r
  • 148 Answers
SOURCE: I have a GE JGSP33
Yes, your oven igniter is bad here is the part#WB13T10001
Have a great day!
Posted on Dec 08, 2010
Testimonial: "g"
  • 2118 Answers
SOURCE: Our GE profile oven model
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
Posted on May 15, 2011
What is wrong with our GE Profile Gas Range? After using the broiler and two burners simultaneously, the electronic controls go black. We can manually light stovetop burners but oven does not work.
On the back of the stove are 2 blower fans just under the cooktop. They are cooling fans to keep the controls from overheating. They are a long tube type fan and are left and right side. My guess is one or both are not coming on. They are controlled by a round disk temp control also under the cooktop. At a preset temp these fans should come on and keep all the control area cool enough to stop any damage. The fans need tested and maybe the temp control needs replaced.
Mar 23, 2015 | GE Profile 30" Slide-In Gas Range -...
Gas burners & broiler work but oven won't bake
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 08, 2011 | GE Profile 30" Slide-In Gas Range -...
I have a GE Model JGBP265BEA1WH and the oven would not work. The broiler & stove top did. I replaced the ignitor and now both the oven and broiler do not work but the burners do. I tried to locate the...
The burners and its components are totally seperate from oven and there is no controlling shared between them. The problem can be many. Can be the timer control that is locked and not allowing any oven functions. Can be the electricline feeding the oven portion. Can be the oven temp control that tells bake and broil to begin functioning. Can be oven lockout. This is a function that you can turn off by holding the clock or other pad button for 3 seconds. Check your manual to see if I am correct about which touch pad to hold. This is a safety feature that sometimes gets activated and there's no flashing lights telling you about it. Goodluck<Macgivor
Jan 16, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
The oven on my magic chef range does not work..broiler and burners ok ,,,get a F1 code and beeping noise ...model number 3488VTV
Hi hockeyhoskin,
F1 error indicates a bad touch pad or clock (ERC). To fix this error code, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Thank you for using FixYa.
Dec 06, 2009 | Magic Chef 31000 Gas Kitchen Range
Jul 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
OVEN WON'T WORK
you need to replace the bottom oven ignighter take the racks out then remove lower oven bottom take it out then remove flame spreader and ignighter will be on burner bar get replacement from appliance repair store take model number with you just because it glowes don't mean its good it should light withen 30 seconds
May 24, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
JGBP79 GE Spectra XL44
Yes I had the same problem on my JGBBP79. Change the lower igniter. About $75. Keep the range for a few more years and get rid of it. The next problem you'll mostly likely have is the touch pad F1 error. That stupid thing is +$300 and nothing more than a membrane touch pad attached to some glass. :-(
Nov 08, 2007 | GE Profile Spectra JGBP79 Gas Kitchen...
GE Profile PGS968SEPSS 30" Slide-In Gas Ranwith 4 Sealed Burners, 4.1 cu. ft. Two Speed Convection Oven, Self Clean, PowerBoil Burner, 3 Heavy Duty Oven Racks, StoraDrawer and ADA Compliant: Stainless Steel Logo
43 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
