Question about Tascam CD-RW750 CD Recorder
CD-RW750 CD Recorder SHOWS SYSTEM ERROR and won't open
When the power is turned on, it cycles through its progressions before the display incates "System Error". Then it appears to be normal except that it won't allow me to open the disc drawer.
4 Suggested Answers
  • 3 Answers
SOURCE: will not read any disc
HWLO
Posted on Sep 27, 2009
  • 3 Answers
SOURCE: Problem with Tascam Cd-RW750. system error at
hello ,, how can i find optical pickup for TASCAM CD-RW 750 RECORDER ,,, what is the number of this optical please somebody help me ,, thanks ,ferr
dunnbiker
  • 8546 Answers
SOURCE: Tascam cd-rw750 - while recording from another CD
1. First problem: "like nothing is recorded". IS something recorded or has it been left in Pause Mode so long (instead of Recording) that it just got impatient and time out?
2. Get yourself a couple of CD-RW Digital Audio discs to play with until you're past this learning curve/problem scenario. That way you can always erase them and start over without having to discard the disc.
3. Dropouts on playback. Are they repeatable - always at the same place, even on different CD players? If so, the data is bad on the disc. If not, the data is probably marginal.
4. If you have a DVD player, try to play the failed recordings in it. Some DVD players can play back unfinalized CDR's. You may be able to recover the data by copying it back to the CD Recorder from the DVD player. Just be advised that an unfinalized CD-RW may not have 'silence' following the last recorded track due to old data remaining from a previous session, so be ready to pause or stop the recorder when the last track finishes.
5. "Scratches near the outside of the CD". Were these NOT present prior to entering the CD Recorder? Do they seem to coincide with about where the recording may have failed?
6. 20 vs 19 tracks: Is this a constant problem or only when there is a failure during CD creation? If the latter, it would make sense as the last track in isn't technically completed.
Posted on Apr 09, 2010
NOW OPC error my Tascam CD-RW750 Only using a cd-rw
All I can think of is to try other makes of blank discs. Also, if your machine ever comes up 'ERROR' and you have no control of any functions including powering it off or on-remove the plug from the wall and wait about a minute, then plug it back in.
Sep 04, 2014 | Tascam CD-RW750 CD Recorder
Why Tascam CD-RW750 Error recording?
I don't have experience with your model. I have the 1000 model and I would try a different brand of CD discs. You don't say what error message that you are getting.
Jul 18, 2014 | Tascam CD-RW750 CD Recorder
Bang & Olufsen Beosound 3200 CD Door won't open
Could be the PCB9 light and motor control have the problem its on the upper left side of the player.
Feb 25, 2013 | Audio Players & Recorders
CD changer won't open. Mechanical Error on display
There is a small hole just above the door on most CD changers. Unwind a small paper clip and GENTLY push it into the hole. This should release the door, and let you look inside. Don't force it because you could damage it more than it is already.
Jun 15, 2012 | Yamaha GX-700 Shelf System
Trying to record but when I push the "record"
Get the manual...
http://tascam.com/product/cd-rw750/downloads/
Record READY switches the unit into a Monitor mode so you can set your levels for when you finally initiate recording.
Jul 28, 2011 | Tascam CD-RW750 CD Recorder
It is no longer recording. What can I do to fix or reset this thing?
hi, i got the same problem and found a way to solve it. i used cd-rw´s and the tascam spit them out
with a -disc-error-. i formatted the discs with my cd-burner prog. each cd-rw takes about 15-20 min.
i use burn aware, but nero or any other prog should do the trick. have fun kelly
Oct 26, 2010 | Tascam CD-RW750 CD Recorder
Automatically advancing to next track while recording
Reset the machine.
Record a cd with no imput.
It worked like a charm.
Oct 06, 2009 | Tascam CD-RW750 CD Recorder
Will not read any disc
This problem is usually cause by a dirty lens of the player, so the first thing that you can do here to correct the problem is to run a CD cleaner to your player, you can get it to a nearest computer shop near you or electronic store...
Jun 11, 2009 | Tascam CD-RW750 CD Recorder
Problem with Tascam Cd-RW750. system error at start up after the "welcome". Then it opens the cd tray and does nothing else.
Jun 07, 2009 | Tascam CD-RW750 CD Recorder
Tascam CD-RW recorder
Get a cd lens cleaner. and clean the lens. This is a CD with a small brush on one of the tracks. Usually this will solve your problem.
Feb 18, 2008 | Tascam CD-RW750 CD Recorder
Tascam CD-RW750 CD Recorder Logo
27 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
