Question about Craftsman WeedWacker Gas Trimmer 29cc 4-Cycle Straight Shaft
33cc weedwacker full crank
Where are adjustment screws
2 Suggested Answers
  • 316 Answers
SOURCE: Craftsman 33cc weedwacker rep lace fuel lines
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Posted on Feb 21, 2012
What is the proper tool part number for carb adjustment on316.791190
If the screws are star shaped then the tool to adjust them is 530035560, check out the web to find one.
Jul 24, 2012 | Craftsman 27cc 2 Cycle Crank Straight...
What is H and L carb setting for a Poulan P3314
The "L" is your idle setting and the "H" is the wide open fuel setting. After the engine starts and runs a minute adjust the "L" to the smoothest run setting the go full throttle and adjust the "H" the same way.
Hope this helps.
Apr 20, 2012 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
How do I upload the manual? I want to see how to load the line
Hi and welcome to FixYa, I am Kelly.
Craftsman manuals are avalable for all models on this site:
http://www.managemylife.com/mmh/owner_manuals
You must have your model number
Note the model numbers on this page:
http://www.managemylife.com/mmh/owner_manuals/search/product_type.Line%20Trimmers:Weedwackers,%20Gas?query=27cc+Craftsman+trimmer
Once you enter your model number you click on "Get Manual" and then save as to your computer.
Thanks for choosing FixYa,
Kelly
Aug 07, 2011 | Craftsman 27cc 2Cycle Full Crank Curved...
My 29cc 4 cycle craftsman gas trimmer loses power when I increase the throttle
While Holding the Engine at Full Throttle, Adjust the High Air Mixture Screw In Until the Engine Revs Properly.
Jul 01, 2011 | Craftsman 29cc 4Cycle Straight Shaft...
My craftsman weedwacker 316.791190 bogs out at full throttle. i cleaned air filter, plug, carb, it runs great when i cover the air box with my hand though,
When you cover the air bos, you are in essence, enriching the air/fuel mixture that is entering the engine. The carburetor does this when it is needed and when it is functioning properly. For the bogging problem, it is evident you need a small carburetor adjustment. I suggest turning the L mixture screw (the one on the carb closest to the engine) out (counterclockwise) 1/8 to 1/4 of a turn. The heads of the L and H mixture screws are unconventional type and some improvising will have to be done to enable you to get ahold of them to adjust them. I use a small plastic (22 gauge) automotive-type wire connector with a ring terminal end on it. I tap it down onto the screw head with a small ball peen hammer until it stretches around it. I then am able to turn it. Try the suggested adjustment for your high-speed bogging problem. And to further tune and adjust the carburetor on your machine, I highly suggest you look at the following tutorial.
http://www.zamacarb.com/tipspage.html
May 22, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
How do I thread my Craftsman weedwacker?
How do I Re Tread my Craftsman 13"
4.0 amp electric weedwacker line trimmer?
May 29, 2010 | Craftsman 27cc 2Cycle Full Crank Curved...
Craftsman model 358.791042, gasoline weedwacker wont stay running
The high speed needle valve needs adjusting and it takes a special splined tool to adjust it. I currently am trying to find where I can purchase the tool to adjust the high and low carburator screws.
Mar 17, 2010 | Craftsman Garden
I have a craftmens 25 cc weedwacker thats about 3
it sounds like your carb is out of adjustment and you need to adjust it. Look at the carb on your weedwacker, there is an idle adjustment screw somewhere on it and using either phillips or strait screw head and then carefully turning it clockwise go 1/8 of a turn at a time until the engine idles smoothly.
Sep 05, 2009 | Craftsman Convertible 25cc. Gas Line...
Craftsman WeedWacker Gas Trimmer 29cc 4-Cycle Straight Shaft Logo
15 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
