Question about Watts 3/4 Pressure Relief Valve
Boiler keeps losing pressure when the heatings off
I have a gloworm copact combi boiler which keeps losing pressure once my heatings turned off, it seems to be fine when the heating is on. also all the hot water seems to be working fine downstairs but not in the bathroom upstairs is this problem related to the pressure problem?
  • Anonymous Jan 20, 2009
    gloworm compact keep losing pressure when heatings turned off
    Scholar:
  • 68 Answers
Hi Leehardcast,
Yes the problems are related. The system is low on water. So now instead of water you have air in radiators which is easily compressed when it heats up. Then pressure loss when it cools down.
Add some water to your system until you have 15lb pressure and bleed out upstairs radiators at the same time.
Please rate this response and Good luck, Phil
Posted on Jan 14, 2009
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Why does it take two bowls of water before water gets hot on combi boiler
The water isn't maintained hot (unless the central heating is on) in a combi boiler. you will, therefore have to turn the water on, which activates the burner. The burner will then have to heat up the heat-exchanger which then supplies the hot water through cold pipes. Once the pipes are warm, you will receive hot water.
Jan 29, 2015 | Water Water Heaters
I have a Potterton Combi Puma 80e When I use the shower the pressure seems to drop and shower goes cold! except when the central heating is on shower works fine
Does the red status led in the centre of the control board come on when hot water is drawn? You need to remove ONLY the front decorative cover to see the control board, two fixing screws at the base of it. If not the boiler won't fire when the CH is off.
The trigger for this is a pressure switch, replacement of which is beyond DIY scope.
FYV
Feb 11, 2013 | Water Heaters
I have an ideal standard he30 boiler instaled about 6 weeks ago. the boiler keeps losing presure about half a bar every 2 days if i dont top it up it will trip the fuse on the fuse board acording to the...
All the combis I've come across merely fail to fire if the pressure is not up. not only do they not fire, nothing else works including the pump and in any event the pump should not overheat just on low pressure.
water loss - try turning off the valves on the flow & return pipes [3/4 inch ones] 1 valve per pipe . This will isolate the rest of the system - rads etc Note pressure over a time period. In this mode the hot water circuit will still work but do NOT use the heating circuit
1/2 bar over 2 days is not serious but it should be found
Once you have either mended the leak in the rest of the system or found there is not one, insist on a replacement boiler
In any event having looked at the reasons given for the fuse blowing, I would definitely get a replacement.
These problems should not happen on a new boiler
I list Worcester.-Ariston-GlowWorm-Ideal- and many others who would confirm this
Dec 24, 2009 | Water Heaters
I keep having to top up with water every few days, but no leaks to be found, the pressure drops down to less than one and the boiler turns off, please can you help,
what kind of heater combi? if combi you may be pressurising boiler to high ie over 1 bar boiler may be blowing off through release valve check discharge pipe
Oct 28, 2009 | Water Heaters
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
I can't turn the bar pressure up on my Vaillant VCW 221 Boiler
on the pipework below there may be a silver braided hose with one or two valves on the end. turn the valve(s) so the handle is inline with the pipe this will allow water from the mains supply into the heating circuit , remember to keep an eye on the pressure gauge. fill the system to 1bar cold then shut down the valve(s). turn on the boiler and it should be ok, if you lose pressure again then you may have a leak somewhere which needs to be found.
Mar 25, 2009 | Water Heaters
Combi Boiler pressure gauge reading 0, and radiator half on!
The first thing you need to do is to put some more water into your heating system. This is usually done by allowing water from your (pressurised) domestic cold water supply to flow into the system: On older boilers, this is done with a connection (often made with a removable hose) on the pipework just outside the boiler. Newer boilers may have a built-in connection with some sort of removable link (sometimes looks like a plastic key).
Once you've got the boiler up to working pressure (typically about 1 bar - 15 psi), you should be able to bleed your upstairs radiator properly.
This may be all it takes, though the pressure excursions you're getting when you run the hot tap suggest there may be another problem. See what happens to the pressure as the boiler heats up and cools down. There really ought to be very little pressure difference between the two conditions. If you see significant changes, this usually means that the "pressure vessel" (or in hydraulic terms, system accumulaor) has lost its air charge.
The pressure vessel is a metal container inside the boiler, usually painted in red enamel. Somewhere near the top, you will find a schrader valve (like the one on a car tyre), and you can use this along with a tyre pump to replenish the air in the top of the vessel. This will reduce your pressure transients for a while, but you need to keep an eye on it. If the problem returns, you probably need to replace the pressure vessel (or clag another one into the plumbing alongside the boiler).
A.
Feb 03, 2009 | ACCO Brands Water Heaters
Watts 3/4 Pressure Relief Valve Logo
1,540 people viewed this question
Top Watts Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Watts Water Heater Expert? Answer questions, earn points and help others
