Question about Mitsubishi Televison & Video
Mitsubishi v5 50501a projection tv flickering
It is flickering after watching or a few hours and after a week it stops working then it works again after sitting
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Its a older set so most likely bad or poor solder connections may have developed on the circuit boards, it comes with age and is rather common and not too hard to fix.
Posted on Dec 12, 2012
  • 87 Answers
SOURCE: Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Posted on Nov 05, 2007
  • 52 Answers
SOURCE: TV Shuts off by itself
If you are lucky, it's only a blown fuse. Some tv's this large have more than one fuse, so look real hard and find all fuses. If fuses are good, then about 95% of the time, when you have no picture/no sound, the problem is a bad H.O.T. This is a large transistor with three pins soldered into the main board and is very easy to find because it is connected to a metal "heat sink". Look for a large red or black wire coming from the pic tube down to the main circuit board (sometimes it's blue, but it's the only wire coming from the GLASS part of the tube to the board. This wire goes to about the largest component on the board called the "flyback transformer". It is usually black and is about 3 or 4 inches tall, 2 inches wide, and 2 inches thick. The h.o.t. will usually be located in the area of the "flyback". The h.o.t. will be screwed with one screw or clamped onto a large piece of metal (usually silver). This piece of metal is usually about 2 inces square and is about 1/8 of an inch thick and is mounted perpendicular to the main board. Imagine a slice of bread standing on one side rather than lying flat and this is what the heat sink looks like. Sometimes you will see several heat sinks with transistors screwed into them, but the one you are looking for will always be the largest transistor with three pins. Don't forget to unplug the tv before you begin and stay away from the large wire coming out of the tube going to the "flyback". Do NOT unplug this wire from the tube. It can shock you very badly EVEN WITH THE TV OFF FOR SEVERAL DAYS. Just be careful and go ahead and give this a try. You can do it, and this is probably going to fix your set. If not, then replace the flyback transformer. The H.O.T. is about $10 or $15 and the flyback can be from $30 to $80. It is possible that none of this will fix your set, but you have about a 95% chance that it will and with such a big and nice and relatively new set, I would give it a shot. Keever
Posted on Mar 05, 2008
bestdarngood
  • 3037 Answers
SOURCE: Re: Mitsubishi WD62627 projection TV issues
This is the most common problem for rear projection tvs and it is known as the color convergence problem.You will need to replace or repair its ics to solve it.
Posted on Mar 26, 2008
  • 185 Answers
SOURCE: RCA P60921 60 in. Rear Projection not working
could be the flyback as some eat them depends on how old it is, and what model it is be more specific. also possible high voltage divider box
Posted on Nov 11, 2008
dave1645
  • 834 Answers
SOURCE: I have a 2000 Mitsubishi VS 60707 60
the DM board is failing and it is no longer avail sorry
Posted on Dec 04, 2009
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
I have a 65 inch DLP and when i turn it on i get no picture and just the sound of static comming out of the front tv speaker, no actual audio from the cable box. When looking near the bulb box i see the...
When was the last time u change the projection lamp?If u watches tv at lest 4 or 5 hours a day and the projection lamp has not been change the last 1 1/2 or 2 years.This problems happen alot,when the projection lamp life is over.Change the projection lamp.
Sep 03, 2010 | Mitsubishi WD-65731 65" HDTV
Mitsubishi WS-65907 rear projection TV HD goes blue.
I would look at the source for the Hd signal as being the problem--if you are using some kind of cable or sat box it will deliver the signal to the DTV input on the back of the set--this is the HD input for this set.
It is possible to have a problem like you describe be one in the set--but very unlikely----have you looked on that green signal board for any signs of Glycol?
Anything that will produce a 1080 signal to the DTV input should tell you if the problem is the set or the source of the HD signal that is causing the problem.
If you have questions or need advice let me know--I am here to help people.
if this information has helped you rate this solution as i do this here for free.
SD TECH
Dec 05, 2009 | Mitsubishi WS-65907 65" Rear Projection...
My tv screen keeps flickering on and off
  1. Need Model # of set and the brand so I know if its a plasma, LCD, or CRT set keep me posted
Aug 23, 2009 | Televison & Video
Mitsubishi vs-5041 -after a few hours on, the tv goes black
Get the projection bulb checked if fine its something internal in your tv but i think you need new bulb
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green power on light flickers
I can help if anyone with this problem lives in Anaheim CA.
Jan 12, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi VS-45607
Do self test first goto www.ctechnicians.com
Dec 08, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Please help
If its a rear projection TV. It sounds like the Lamp is shot on the projector, or is going. Look in the back and see if it is lit if it is flickering I would definitely suggest replacing it. If that doesnt repair it then I would ultimately suggest the optical engine which is the projector of the TV
Jan 30, 2007 | Mitsubishi VS-5075 50" Rear Projection...
Televison & Video Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
