Removing outer casing
I want to put more memory in but cant take outer casing off sytem
  • Anonymous Apr 09, 2009
    removing outer casing
  • James Hobden May 11, 2010
    What is the make of your computer? Is it a laptop or desktop computer. If i know this then i can help.
  • 68 Answers
If it is a desktop, there should be two thumbscrews in the back. Remove them and slide the side off.
If it is a laptop, then the RAM is probably underneath a cover plate on the bottom of the computer. Remove the screw and the cover should pop open.
Posted on Jan 16, 2009
Janome memory craft 6500 sewing machine...all of a sudden, the bobbin thread does not attach itself to the needle thread...i have taken off the plate, cleaned out the dust, rethreaded both top and bottom...
Has the bobbin case dislodged and moved? there should be two red marks one on the bobbin case and one on the outer holder, are they lining up? Sometimes as these cases are held by a magnet, they will get dislodged and move slightly, especially in a jam up.
Take out the bobbin case and clean under it, then replace it matching up the red marks.
If the bobbin case has actaully been struck by the needle during a dislodgement, it may well pierce the bobbin case plastic, look for burring or marks on the outer flange area. If this has occured, the thread may catch on the burr as it comes over the bobbin and jam again.
You can buy a new bobbin case if yours is damaged or maybe just file the burring with an emery board (remove it from the machine first of course).
Lastly, check your needle hasn't been bent, burred, or put in backwards, any of these can prevent a stitch from forming.
If all the above fails, then it is possible that the timing has been knocked out and you will need to get it serviced by a technician.
Oct 16, 2011 | Janome Memorycraft 6500P Computerized...
I erased all the songs off of it.but i cant put mp3 on it cause it still says that its no free space.how do i reset the memory?
if your PC can show the removable disk drive you should format it. In this case all the folders and media files will be erased on your player. Then copy the media files to the player.
I hope this action will be enough and the files can get to the memory of it
Bye, gylacz
Jan 30, 2011 | RCA Pearl TH1102 MP3 Player
What is the correct procedure to replace a radiator on 1986 mercedes 420 sel?
Ahh. These are very easy to do. 1. Drain the sytem througn either the petcock on the bottom of the radiator or just removing the lower hose 2. remove the outer shroud by spinning the round part of the housing until it unlocks(about 1 inch rotation)push the shroud forward over the fan and leave there 3. remove the inner shroud by removing the 2 metal side clips(with a screwdriver usually)and pull up 4. remove the 2 transmission cooler lines underneath(either 17 or 19mm) 5. remove the 2 radiator hoses. 6. remove the 2 metal clips on top of the radiator. That's it!! Put in your new radiator. Make sure you turn the heater on while you are filling the system so it help to bleed the entire system. I love these 126 body cars. Let me know if you need anything else!
Apr 29, 2010 | Mercedes-Benz 400-Class Cars & Trucks
I have an ACER 5000. When I check the max memory
The only thing you missed is if you have only 2 slots to put memory sticks it means that if you want to put 4 Gb of ram you need to buy 2 sticks of 2 Gb each, you have no other choice. you can't add memory but only change the existing ones.
Sep 08, 2009 | Acer Aspire 5100 Notebook
8 gb card unlock on canon elph screen
it should have a slide switch on the outer casing of the card... write protection lock.
Jan 22, 2009 | SanDisk 8GB microSDHC Memory Card with...
Cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
Nov 28, 2008 | Denon DCM-360 5-Disc CD Changer
Without warning or prfevious problem computer wont boot with any picture. I have been building gaming sytems for at least 10years and have trouble shooted without remobing from case. Sytems AMD Dualcore...
Went further in troubleshooting by removing the components one by one. Turned out that the soundblaster fx card needed to be reinstalled after a normal boot sequence was completed.
Remembering that Creative and vista have had problems in the past it was the first component removed and wala.
Jul 14, 2008 | Computers & Internet
No screen, no boot, only the power LED flash orange
In this case you should examine the motherboard and the processor.
verify the Mboard maybe maybe some part oversheat, if non then , Kindly remove the processor, then switch on for a while then shutdown: fix back the procesor and then switch on. still no beeps? try your Processor to other computer system with same socket on mainboard. if the processr work; then your mainboard is damage. u need to replace; if not work. processor is damage and need to replace.
Be sure to test all the pheriperals of your system before you buy a replacement to see if some other parts is no problem.
Like memory, VGA,
If all of the solution is not working its time u to assemble new computer system. i give you all the possible solution, or else tell me the working part i will help you seeking and speicy the replacemnet part.
thank you more power.
Jan 29, 2008 | Acer Aspire 3680 Laptop
My notebook is a Acer Aspire 1410... kapout ?
plase start the sytem without the memory, If the sytem beeps so therfore there is no problem in the board and in the processor, in this case youe should replace the memory, however there is no beeps it means that further test in the motehrboard and the processor.
Please notify me for further issue before you rate, Thanks.
Jan 27, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
