Question about KitchenAid Refrigerators
Water dispensor not working in KBFS22EWMS3
Making ice but not dispending water. Once in a while a small amount of water trickles out, some times a noise but usually nothing.
fridgetech
  • 473 Answers
SOURCE: Ice maker not making ice
Chances are it will be best to replace the ice maker but give me your complete model # from the sticker inside the fridge.  Also, make sure the fill tube to the ice maker isn't frozen up.  There should be a 3 digit # in front of the 52554100.
Posted on Oct 18, 2007
RescueTech
  • 145 Answers
SOURCE: GE Fridge Not Dispensing water
First place to start is in the fridge. Look behind the crisper drawers for the water tank. It may have frozen at the outlet line. Try thawing it out with a hair dryer or a heat gun, being careful of course not to melt anything.
Posted on Dec 13, 2008
itls
  • 17 Answers
SOURCE: GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Posted on Mar 16, 2009
  • 10865 Answers
SOURCE: Ice maker is not making ice
hello. i can help.
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly.
Posted on Jun 25, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Posted on Jul 27, 2009
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
GE REFRIGERATOR'S ICE DISPENSOR PROBLEM
CAN U TELL ME WHAT YOU DID TO FIX THIS PROBLEM. I AM NOW EXPERIENCING THAT EXACT PROB!
Nov 09, 2009 | GE Refrigerators
I have a Kitchenaid Side By Side model KSR25FKWH05. The ice maker is not working, but the water still comes out of the water dispensor on the door. I did have the water to the entire house off last weekend...
check to see if there is ice in the icemaker, if not, put a small amount of water, like 6 ounces in it with a glass. if it kicks out some cubes, you have a bad watervalve.
Nov 01, 2009 | Refrigerators
The water/ice dispensor not working
There is usually a button on the control panel to lock the the water and ice.  Since it is both this is the most likely cause.  If your controls are not locked the the control panel is probably lacking power somewhere and will need in depth troubleshooting.
Oct 25, 2009 | Amana DRS2462B Side by Side Refrigerator
The ice maker stopped making ice. Any solutions?
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
Oct 23, 2009 | Kenmore Refrigerators
Doors got to hot
Check the warrenty on fridge . Usually you have a 5 year warrenty on the compressor AND sealed system ( parts and labor ) . However , a service call charge may apply . Also check to see if something got sucked into the compressor cooling fan blade causing the noise , after you cleaned the coils .
From the description about dispensor leaking and ice getting stuck , sounds like the water valve needs to be replaced . Small ice cubes ( from not enough water ) will get caught between the rake and fingers . A leaking water dispensor , usually indicates that the water solenoid is not closing completely when letting off the water dispensor arm . Both solenoids come togather as the water valve ( located where the wall waterline connects to refrig ) .
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser suddenly not dispensing water
Remove the bottom kick plate . Follow the plastic line about 6" and you'll find a connector . Push in on one end of the connector and at the same time , pull the line out . Close the door and press for water . If no water comes out of the disconnented line , the water valve is probably bad . If water does come out , the line inside the freezer door is frozen . If this turns out to be so , you can lower the freezer temp for maybe days , or , put the food on the door, inside the freezer , tape the light switch down ( to keep the lite off and fan running ) and tape plastic over the freezer door opening so the freezer will continue to work . Reinstall the line back into the connector by pushing the hose firmly into place . Leave the freezer door open for maybe 1 or 2 days for thawing out , going by ocassionally and pressing the water dispensor . Important : lower the freezer temperature slightly to keep line from freezing again . ONLY CHANGE THE FILTER WHEN WATER FLOW SLOWS OR ICE CUBES GET SMALL . The change filter lite comes on by the amount of times water dispensor is used and to make money for the vendor .
Aug 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
No ice or water from dispensers
Womers, make sure there is not a lock-out on the dispensor panel. If there is, hold it in for 5 seconds and see if the dispensors come alive. Because both water and ice are not working, I would think you have a dispenser board issue. Catriver..post back.
Sep 26, 2006 | Whirlpool GS5SHAXN Side by Side...
Refrigerators Logo
20 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
