Question about Intel (C733) Celeron A, 700 MHz Processor
Can I put to much RAM in the motherboard for the Processor?
Motherboard is a Gateway D865GLC currently has 2-256MB DDR PC2700 and 2 open slots. Online diognostic Crucial memory stick thing says each slot can handle a max 1gb card. I am looking at put 2- 1GB DDR400 PC3200 or DDR333/PC2700 in the empties for a total of 2.5 GB. My Processor is a Pentium 4 2.60 GB 800 MHZ FSB w/ HT. Is quintupling the RAM like this outdoing what the processor is capable of, or should cause no problems? All of the RAM is Non-ECC and unbuffered. Intel 865G Chipset is on the motherboard. Thanks for the time and input.
  • dragonqueen7 Jan 13, 2009
    Sorry I put this in the wrong spot, not sure if someone can move it to either the Gateway motherboards or the Pentium Processors?
  • 6,487 Answers
That additional RAM will be good for your computer so it will be much faster and don't worry everything should work fine there after adding new RAM to your computer....
Posted on Jan 13, 2009
If i change the ram stick will my pc reconise it
Yes.
Provided,
1) It is no more than the maximum amount, for that ram memory slot.
2) Adding it, will not go over the Maximum Total Amount for the motherboard.
If this pertains to an Acer Aspire T135 desktop computer,
A) The Maximum Total Amount is 2GB.
B) The Maximum Amount for Each ram memory slot is 1GB.
C) PC3200 is the best you can use.
DDR Sdram at 400MegaHertz. (400MHz)
[It can also use PC2100, and PC2700.
DDR Sdram at 266MHz, and DDR Sdram at 333MHz, respectively ]
Once you install the ram memory, BIOS should automatically find it.
If you are only going to use one ram memory module, be sure to put it in Slot 1.
The Processor reads ram memory in Slot 1 first.
[Slot 1 is closest to the Processor.
It may have DIMM 1 printed on the motherboard, next to Slot 1 ]
Jun 21, 2010 | Acer Aspire T135 PC Desktop
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
Can you add to much Ram for the processor to handle?
That additional RMA will be good for your computer so it will be much faster and don't worry everything should work fine there after adding new RAM to your computer....
Jan 13, 2009 | Intel Computers & Internet
Can you have to much Ram for a processor?
You'll be fine. If you have been on crucial you know then whether the modules need to be in matched pairs, which is what it looks like you are doing. The only limitations on RAM are when you go to 4GB using 32-bit processing. It will most likely not all show. But with 2.5GB, you should be humming along quite nicely.
Jan 13, 2009 | Gateway Computers & Internet
Gigabyte GA-81EXW memory chips
Any 184-pin ddr ram should work on this. You can actually use pc3200 (ddr 400) ram as well. Pc2700 ram is ddr333, and a higher speed ddr ram like pc3200 will work just as well if not better than pc2700, it will simply go down to the speed that the processor requests the ram run at. It's all backwards compatible, faster ram can run slower if the computer needs it to run at the slower speed. Depending on the price you can find as long as you get 184 pin ddr ram either pc2700 or pc3200 with work fine with your motherboard. Peter
Oct 02, 2007 | Intel Motherboard
Asus A7V8X 1 gb sim
Have you tried the 1gb in the motherboard on its own but in different slots. i.e try slot 1 then slot 2 then slot 3 and see if you still get beeps.
Aug 23, 2007 | Abit BL7-RAID Motherboard
Intel (C733) Celeron A, 700 MHz Processor Logo
187 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
