Question about Canon imageRUNNER iR C2880 Color Copier
How to replace registration roller bushing
The bushin on a 3380 registration roller has a ramp the transfer roller unit pin rides up. It broke at the top and I need to replace it. I could not get it out. I got the registration clutch off but could not find a way to get the roller out to get to the bushing. Nothing in the service manual. Can you point me where to find the intstructions how to get the registration (metal) roller out of the machine?
3 Suggested Answers
SOURCE: REMOVING REGISTRATION ROLLER FOR CANON IR5000
open the duplex then take it out from the mechine and see the roller out side the edges you can find c look remove it then
Posted on Nov 01, 2008
  • 4 Answers
SOURCE: Canon PC 940. replaced
the heat element is not heating up check the connections at either end of upper fuser roller. unpluging copier for 20 minites should reset the error
Posted on Aug 19, 2010
How to Problem detect & Solution for Toshiba e-Studio 232 Error Codes E210
Lower drawer transport jam (Paper not reaching the
registration sensor): The paper does not reach the
registration sensor after it has passed the 1st transport
sensor.
Open the transfer cover. Is there paper in front of the registration sensor?
?? YES ?? Remove the paper.
NO
Is the registration sensor working?
(Perform the input check in the test mode: 03-[FAX]ON/[2]/[A]
llllllll
NO ?? 1) Check if the connector of the registration sensor is disconnected.
2) Check if the connector CN305 on the LGC board is disconnected.
3) Check if the connector pins are disconnected and the harnesses are
open circuited.
4) Check if the conductor pattern on the LGC board is short circuited or
open circuited.
5) Replace the registration sensor.
6) Replace the LGC board.
YES
Are the (lower/middle) transport clutches working?
(Perform the output check in the test mode: 03-203, 205)
lllllllll
NO ?? 1) Check if the connectors of the (lower/middle) transport clutches are
disconnected.
open circuited.
open circuited.
5) Replace the (lower/middle) transport clutches.
YES
1) Check the condition of the feed roller, separation roller and pickup roller of each paper
source, and replace them if they are worn out.
2) Check the transport roller. Replace it if it is worn out.
Nov 16, 2017 | Toshiba Office Equipment & Supplies
How do fix error Color registration could not performed
Possible remedies for weak images.
-Loose connection between transfer roller and high voltage supply unit.
-Dust in the laser beam path
-Transfer belt not contacting PCU.
Check the transfer unit.
Defective PCU. Replace the PCU.
Defective transfer roller. Repair the transfer roller.
Defective fusing unit. Replace the fusing unit.
Defective engine board. Replace the engine board.
Feb 02, 2016 | Ricoh Aficio SP C410DN Laser Printer
Iam getting p21 error what can i do?
Sir/ Mam,
The P- codes in general are giving you a heads up that something is going to go soon. Most time you can live with them.This code deals with the registration of colors on the transfer belt. The belt put image on the paper and rides above the drums shine item when you open the right side door paper goes between it and the sponge looking roller.Registration is like cyan on top of magenta for purple if not you get to see both colors. Any way to get to the sensors that monitor registration requires removing the transfer belt then opening the sensor covers to expose the sensors and clean them NO LIQUIDS. Mite want a tech to come out and do this
Apr 24, 2014 | Konica Minolta Compatible Bizhub C452 C552...
Color registration off
on the control panel, select "additional functions", then press "2" and "8" at the same time, and then press "additional functions" again. You should see a white screen with the words, copier, feeder, etc. Press "additional fuctions" and then press the "2" key. This will take you into level 2 of service mode. On the screen, select "copier", then "function", then "clear", and then select "reg clear", and then press "ok" in the lower left of the touchscreen. Press "reset" multiple times to get back out of service mode. Turn the machine off, and then back on. Press additional functions and go to "adjustment and maintenance". Select "auto gradation" and perform a "quick" adjust, and then a "full" adjust. This should bring your registration back. If you keep experiencing the problem, the secondary transfer roller located just before the fixing assy/fuser unit on the left side drawer that pulls out could have build-up in the bushings, or the transfer belt and drive rollers could be causing the problem too. Hope this helps.
Apr 12, 2011 | Canon imageRUNNER iR C4080 Color Copier
Im using ricoh 2045..Paper jam occurs at point A1 (the lever the drops to remove the paper) . I have noticed roller A1 and registration roller doesn't rotate. When i remove the paper and close the covers...
this is not a thought I am 100% sure and give you the correct solution:
problem with the paper feeding section is dusty or due to developer drooping
1. Open the developer unit and check the rear side developer unit bush one or two bush are faulty
and drop the developer.
2. remove all paper trays with remove the four each screws
3. Remove the toner collection bottle
4. Remove the right side cover.
5. Remove paper left roller plate.(show in the picture)
6. Now remove the first tray paper feeding section(is a complete unit included paper feed rollers motor and clutch and gear section)
7. Clean the drooped developer from all gears and roller and motor section
8. remove the second and third tray paper feeding section and doing the same.
9. now fix it all
10. replace developer unit bush witch are faulty or if you don't have yet cut a plastic sheet and past the upper side of first paper feeding unit gears witch are don't disturb the paper path and stop the developer drooping on the gear good_help.pnggood_help_0.png
Jan 27, 2011 | Ricoh Aficio 450 Copier
Canon 6551 copier-rollers are grabbing causing smear on the copy
check the paper path you need to control the main drive mecanism, and all bushing roller : registration roller, pickup, fixing and exit: you can see exemple of the bushing to check: mabroukmedal_41.jpg
the roller that you need to check and replace the bushing:
Dec 21, 2010 | Canon NP 6551 Black and White Copier
Kyocera fs 4000 how to replace drum, transfer roller and pickup roller
(1) Detaching and refitting the drum unit
Procedure
1. Remove the developer unit (See page P.1-5-
9).
2. Open the left side cover and then remove
the waste toner box.
3. Unlock the drum unit lock and then remove
the drum unit.
4. Check or replace the drum unit and refit all
the removed parts
(1) Detaching and refitting the transfer roller and separation charger brush unit
Procedure
9).
2. Remove the drum unit (See page P.1-5-10).
3. Slide the paper chute guide and unhook the
hooks.
4. Remove the paper chute guide.
5. Remove the shaft (transfer roller) from the
both bushes.
6. Release the four latches and then remove
the separation charger brush unit.
7. Check or replace the transfer roller and separation
charger brush unit and refit all the
removed parts.
CAUTION: Note the following, when refitting
A. The separation charger brush unit is
inserted into the two projections of the frame
and does not run on to the projections.
B. The separation charger brush unit is
firmly in contact with the separation charger
plate of the frame.
(1) Detaching and refitting the paper feed assembly (paper feed roller and pickup roller)
Procedure
1. Remove the paper cassette.
2. While pushing the lock and then slide the
paper feed roller pin.
3. While pressing the lever and then remove
the paper feed roller assembly.
4. Check or replace the paper feed assembly
and refit all the removed parts.
(2) Detaching and refitting the ****** roller
Procedure
2. Push the bottom plate down until it locks
(30/31 ppm printer [EUR/USA model] only).
3. Unlatch the two latches and then remove
the ****** guide.
4. Remove the ****** holder (roller) from the
****** guide.
5. Check or replace the ****** roller and refit all
the removed parts.
Feb 04, 2010 | Kyocera FS-4000DN Laser Printer
I need to know how to replace...
The transfer belt cleanning blade is under the transfer belt.Remove 2 screw and change it.The bias transfer roller is mounted in two bushings,remove the bushings and 2 springs.The fuser unit : upper fuser roller,lower fuser roller and the cleaning rollers.
Aug 25, 2009 | Office Equipment & Supplies
My Rico Aficio 200
Please open the front door and turn the blue lever in the middle,
remove the Transfer and Separation unit and check if the bushings of the transfer roller are damaged.
If OK, please give some oil on the shaft/bushings of the transfer roller. This unit may be replaced as a whole unit.
If SC401 re-occurs, please check the Photoconductor unit (drum).
Aug 27, 2008 | Ricoh Aficio 180 Laser Printer
ImageRunner c3200 Color Registraton
With my experience, it's not the registration nor calibration problem, it's either transfer belt is bad or inside the transfer belt is dirty or dusty as well as transfer rollers. here is what I do first
take the transfer belt unit out of the machine, take transfer belt out from the unit, clean inside of transfer belt with damp cloth and rubbing alch. clean all rollers and reinstall.
What it is if the transfer belt and transfer rollers are dirty and dusty, it slips and make it like it's not align. I think most of time it fix the problem with my exp. if not replace new transfer belt
Jan 15, 2008 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER iR C2880 Color Copier Logo
old marine
old marine
