Question about Toys
Train will not stay running
It will start rolling and then stop, doesnt even go around whole track. I have cleaned track and wheels and strong fresh batties
4 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: Set up this morning.
Hard to say what exactly is going on, but it's not good. Some part- a relay, transformer, or switch is failing, and if the unit's new, take it back for an exchange or your money back. Whatever is failing is going to most likely require parts to be replaced, which means servicing, and there's no sense in that if it's new and under warranty.
Good luck, and hope this helps.
Posted on Nov 20, 2010
  • 1015 Answers
SOURCE: tyco toy train does not
I would start by making sure all the connectors on the track are clean and locked together firmly.Wipe off track rails and all electrical connections with clean soft cloth such as a wash rag.Try to not touch electrical connections with bare hands as even small amounts of body oils or hand lotions can interfere with good connections. Check hook ups from transformer to track. Clean electrical pick up points on engine with pencil eraser and soft rag, you can use eraser to clean track surface also.
Hope this is helpful and have a good new year. Thanks
Posted on Dec 28, 2010
SOURCE: i just bought a playskool ride on (around) train
Hi Erin, I have the same train and tracks I am getting ready to sell. Yes, there is a black plastic box type thing under the main part (seat) of the train. If I remember correctly, it snaps off the train and there is a place for "D" batteries to go. The box comes apart from the train and there is a lid that comes off the box which holds the batteries. I hope this helps. My kids had lots of un with this train. Good luck!
Posted on Sep 24, 2011
Bachmann Emily
check all track connectors(squeeze lose ones with a needle nosed pliers..check wire from transformer to the track..and during assembly, the track gets any dust on it, the wheels wont make proper contact for the engine to run..) as for the locomotive.. sometimes you can clean the motor brush comutator with a simple pencils' erasure by rotating the motor armature by hand(small as it is) to clean the pickups on this..it will better help to transferr the electric into the motor..sometimes on these track layouts, you need fine grit sandpaper to run across the top of the rails as the manufaturer puts a protective coating on these.. it wont carry power to your train..you can also use the backside of a butterknife drug around the layout a few times with the electric off.. it helps you feel any rough spots on the track/layout..
Mar 08, 2014 | Bachmann Thomas Tank Emily's HO Train
Alaska Railroad #71 Problem
Before disassembling check the brushes (metal contacts) are making good contact with the loco wheels and are not blocked with fluff etc. Ensure the loco wheels are clean and shiny so that they pick up the track voltage ok. The brushes are made of sprung metal and transfer the voltage from the wheels via the track to the motor. Check that as well as clean and fluff free that they also have a strong springiness against the wheels for good electrical contact. If these appear ok then remove the loco bodywork and check the motor. You can apply a 12v supply directly to the motor contacts to test if it's running ok. If it does run ok then suspect the brushes and associated connections. If it does not run try moving the motor armature manually. If it is stuck it is probably time to replace it. If it moves apply a light machine oil and test again.
Jan 19, 2014 | Crafts & Hobbies
My 1941 Lionel train stops getting enough power to run all the way around the track. Voltmeter says 15 volts around all track and transformer says 15 volts. How do I test engine?
If your sure the loco contacts/wheels are clean and the track is ok then remove the loco bodywork and check the motor. You can apply a 12v supply directly to the motor contacts to test if it's running ok. If it does run ok then suspect and clean the brushes and associated connections. If it does not run try moving the motor armature manually. If it is stuck it is probably time to replace it. If it moves apply a light machine oil and test again.
Dec 16, 2013 | Lionel Trains Classic Freight Train Set
Have lights and animation, but not rolling around the track. Driving Wheels of locomotive do not move, even by hand
If the drivers do not rotate under any circumstances, the internal drive mechanism may be jammed.
Dec 10, 2013 | New Bright 384 Holiday Express Animated...
How do I clean the tracks & wheels to stop the short circuit?
Have you let the loco charge first? The instructions are a bit vague but the loco needs to charge before it runs. Not easily understood from the instructions and many have spent some frustrating minutes wondering why their train wouldn't move.
Nov 13, 2013 | Lionel Trains Holiday Express G Gauge...
Electric train set stop and goes when it goes over certain parts of the tracks do I need to clean the tracks or the wheels and what do I use to correct this issue?
1: make sure all track connections are tight.
2: clean the track using a Green 3M scratch pad
or a track eraser.
3: clean your wheels, some people use smoke fluid
on a cloth, I use alcohol prep pads,. A track eraser
can also be used. there are commercial wire brush
cleaners that connect to your power source.
Nov 05, 2011 | Bachmann Thomas the Tank Engine Train and...
I have power to the train and it runs but it moves extremely slowly and sommetimes comes to a stop.
I'm assuming the train is track powered with a power pack, and not battery powered, so there's actually a few possible solutions. I'll work from the easiest/cheapest, to the more advanced/expensive.
First, especially if the track is old or been in storage a while, the track may have a thin film of dirt, oil, or rust that is insulating the wheels from picking up the power they need from the track. Try cleaning the track with a mild soap but BE SURE TO DRY IT COMPLETELY before reattaching the power. Also, clean the wheels but use a cotton swab and very little water. One drop inside the motor might destroy it from the inside. You can also try a special track cleaning solution sold at your local hobby shop that has HO model train sets. That will work better, especially on lightly rusted parts. Also, make sure all the track connections are tight and free from contaminants.
Then, if you're feeling brave, you can check the motor of the train itself. Disassemble the locomotive and find the motor inside the housing. Check the wires leading from the wheel area to the motor for any corrosion, or loose/broken wires. If it's not the wires which are easy to solder back in place, I wouldn't recommend going any deeper into the motor as it's better and less frustrating to just buy a whole new set.
Finally, the problem may lay in the power pack (inverter) itself. I personally don't bother trying to fix a power pack, but if you know your electronics you could run some tests of the output voltage to the track, and the voltage on the track at various points. Again, it's not worth the time or effort to mess with the power pack unless you know what you're doing. You could get seriously injured or killed by the voltage/amperage running through those things. They even have enough stored electricity after they're unplugged to cause some nasty electrical burns from the capacitors.
Hope this helps and you're able to fix the problem so you can get back to enjoying the train set. I've always enjoyed watching them for hours, especially when I set up my track around the Christmas tree every year! Good luck!
Dec 19, 2010 | New Bright 384 Holiday Express Animated...
The train is not responding to the remote.
I had a similar problem with my 11000 Holiday Tradition Express. I cleaned the track with an eraser (pencil-type) and then used a soft cloth to clean any possible residue. After doing this twice, my train is now running.
Dec 04, 2009 | Lionel 11000 Holiday Tradition Express...
New Bright Holiday Express Animated Train - figures do not move
Make sure you the wheels on the cars are actually rolling and not sliding (being drug down the track) Most of the animation is down mechanically as the set moves.
Dec 22, 2008 | New Bright 384 Holiday Express Animated...
Toys Logo
19 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
