Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
Briggsandstratton 17hp ohv intek 31f707 vaive specs.chart
2 Suggested Answers
SOURCE: i have a 17hp briggs and stratton vertical intek
adjustment with 4000 feeler gauge
adjust top valve when the bottom valve is fully compressed and than with the top valve fully compressed adjust the bottom valve the same way.
very easy But remember to losen the center tork screw before adjusting the rocker arm nut
Posted on Apr 02, 2010
Looking to buy a yardworks riding mower 42" cut belt
take the old one to a mower repair shop and that will have all the details
if you don't have the belt go there anyway as they probably will have a catalogue
Aug 28, 2016 | Optics
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-series-v-twin
For single....the are in 1/2 HP ratings but the link is below....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-with-xrd-single-cylinder
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
17hp kohler ohv runs rough and muffler glows red hot
muffler full of carbon remove muffler heat up red hot throw in bucket of cold water remove and throw as hard as you can on pavement clean carbon out of exhaust part of headt make sure piston is all the way up you dont want carbon in your motor reinstall thank me
Oct 06, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs straton ohv on tiller , govener will not work, runs at high speed all the time, starter rope has become extremely hard to pull, will not spin engine.
The hard to pull, will not spin the engine issue could be because you need a valve adjustment. A valve adjustment is critical because it enables the built-in compression release on the Briggs OHV engine to function correctly and enable an easy start; plus of course, smoother running. Remove the valve cover and adjust those valves at 1/4" down past TDC on the power stroke. You WILL see a difference in the engine once you do the adjustment.. Here is a Briggs spec chart which has those values for their engines. Yours should be listed in the OHV engine section.
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/~/media/71BB9DA0BD4D4C19A0DA611923A0B80A.ashx
Here is the Briggs recommended tutorial on HOW to adjust those valves. Scroll down this page to "Adjusting Overhead Valves"
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/Servicing%20the%20valves/
May 22, 2011 | Garden
Head bolt torque for 16hp horizonal shaft engine
Anywhere from 35 lbs to 220 lbs, depending on the series of your engine. For your engine, the head bolt torque should be 190 lbs.
But I've attached a chart for you to utilize to make sure of your exact engine model series, just in case there was a transposed number, etc.
http://www.small-engines.com/torque.html
Here's the official Briggs & Stratton chart for all versions of their engines, which confirms the 190 lbs torque spec.
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
Hope you found this Very Helpful and best regards!
Aug 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Will not crank
sorry for not answering sooner but turns out it was the starter solenoid.
Sep 06, 2008 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
280 people viewed this question
Top Parks Optical Garden Experts
Roland W VanLue
Roland W VanLue
Renee Knafel-Bullock
Mike Squire
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
