Question about Lexmark T642 Laser Printer
Lexmark T642 Laser Printer error message922 02
My brand new printer is giving me an error code 922, Service fuser error. Any thoughts on why this would occur?
  • 3 Answers
Service fuser error requires a maintenance kit, this is approx $1000 + installed, if this is new, I would be taking it back because it shouldnt have this error. You possibly might be able tto fix it by replacing the fan in the back but thats only worked for me in approx 1 out of every 10 times.
Posted on Jan 30, 2009
What can i do when my lexmark T642 printer displays 922.02 service fuser error when the printer was never used?
It could be the connector to the fuser from the LVPS is not connected properly. It could also be the Thermistor on the fuser is bad.
Jan 31, 2017 | Lexmark T642 Laser Printer
922 SERVICE FUSER ERROR
922 means the fuser did not reach operating tempture. most likely the bulb in the fuser has gone out. Depending on how old your printer is, the fuser could need either rebuilt or replaced.
Feb 23, 2012 | Lexmark T630 Laser Printer
Marca error 922 service fuser lexmark t520
922 Fuser Error messages indicate that the fuser unit failed to reach the standby temperature.
  • If this is the first time you have seen the error, turn the printer off and on. Leave the printer off for at least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
  • If this is an intermittent error, you may want to check how the printer is plugged in, even if it has worked on this surge device for months. Make sure the printer is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer which can trigger a false fuser error.
  • If this does not help or if this error appears every time the printer is powered on, you will probably need service on the machine. I suggest you contact Lexmark Technical Support.
  • Aug 23, 2011 | Lexmark T520 Laser Printer
    922 service fuser error
  • 921 Fuser Error and 922 Fuser Error messages indicate that the fuser unit failed to reach the standby temperature.
    Nov 10, 2010 | Lexmark T522 Laser Printer
    I am getting a 922 service fuser error on my lexmark optra s 1855
    922 Fuser Error message indicates that the fuser unit failed to reach the standby temperature. This usually requires a service call but try to turn off the printer for 30 seconds before turning it back on to give the engine board a chance to reset. Make sure the printer is plugged in straight to the power outlet in the wall. Bypass any surge device or power strip as they can cause low amperage. If the problem continues or if the error appears every time the printer is powered on, you will probably need service on the machine.
    Aug 26, 2010 | Lexmark Optra S 1855 Laser Printer
    Message on screen reads: 920.26 Service Fuser Error. I've tried switching it on/off, still won't work and none of the buttons will cause the error message to dissapear.
    Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T642, the manual states you should power off the printer and power it back on, which you did, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
    If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
    Aug 22, 2010 | Lexmark T642 Laser Printer
    922 Fuser Error indicates that the fuser unit failed to reach the standby temperature. Leave the printer off for at least 10-15 seconds before turning it back on. This gives the printer's engine board a chance to reset. Make sure printer is plugged in straight to the wall, bypass any surge device or power strips as this can cause a low amperage problem in your printer which can trigger a false fuser error. If this does not help, you'll probably need service on the machine. A replacement might be needed for LVPS, the fuser or worse the system board.
    Jun 28, 2010 | Lexmark T522 Laser Printer
    E 352dn Mono Laser Printer: error 922 service fuser error...
    Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T632, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
    If the printer is out of warranty, your next option is to change the fuser which costs around $90 on Ebay.
    May 18, 2010 | Lexmark E 352dn Mono Laser Printer
    920.07 code on a t642
    a 920 error means your fuser is under temperature at standby. you should replace the thermistor it cycles the fuser on and off to maintain these temps
    Nov 06, 2009 | Lexmark T642 Laser Printer
    Fuser Error
    bought a new HP printer!
    Nov 04, 2008 | Lexmark T520 Laser Printer
    Lexmark T642 Laser Printer Logo
    421 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
