I have a Hampton Bay 300W transformer. I've attached a 12V bulb to it in the low voltage ports. the LED is covered and the unit is in the on position. About every ten seconds the units flashes the light, otherwise it is dark. Can you help?
the Hampton Bay 300W transformer requires that at least a 20 watt load for it to function. If you only have one bulb, say a 10 or 15 watt to test it, it wont work - sounds crazy, I know.
If you have an installation brochure it's under "Important Safety Feature". The first sentence reads "In order for this Transformer to operate, a minimum load of 20 watts MUST be installed before plugging the Transformer into the electrical outlet.
Hope that's it - by the way, these transformers can emit a high pitch when running - not sure why, but it's a common complaint.
I've lost my i-mate jaq3 cd software you can download all imate jaq3 related stuff from the below...
(More)
I've lost my i-mate jaq3 cd software you can download all imate jaq3 related stuff from the below website... https://www.imate.com/Support_DeviceSupport.aspx?key=7652a93a-9254-48f9-9c1e-4cd8dc78bda6 please help this link does not work. kindly send the softwares at nikugupta11@gmail.com or any link for i-mate JAQ3
I have a iPhone 2g 8gb that will only turn on when it is plugged in. It will however not charge when...
(More)
I have a iPhone 2g 8gb that will only turn on when it is plugged in. It will however not charge when plugged in. It turns on, flashes the pineapple logo for a couple seconds, turns off, and repeats. iTunes is not recognizing the phone. It will not do anything when it is not plugged in. Please HELP!
