Question about York Furnace Draft Inducer Blower Fasco # A224
York Diamond 80 Furnace Filter need the exact size
5 Suggested Answers
SOURCE: york diamond 80 hvac blower and comp wont start on automatic
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
Posted on Oct 11, 2009
SOURCE: My York Diamond 80 fires up, then after 10 seconds,
mine too
Posted on Dec 09, 2009
  • 3280 Answers
SOURCE: gas furnace
Hi check out the pressure switch clean the air filter and check out the fan control see if this is clean
Posted on Feb 16, 2010
SOURCE: york diamond 80 fan starts running blowing cold
OK so you replaced the Thermostat huh? OK well then did you also replace the Thermistor Temperature Sensor? or whatever is used? As often it's BOTH, also check the wiring from the sensor to the host, in any event if it's NOT that then all it can be is the controller board, most likely the Micro? Check any and all sensors first though.. try to get a service manual too, it's hard without one?
Posted on Oct 20, 2011
York diamond 80 - continuous flashing red
Is there a chart on it somewhere that describes what each mode of flashing means? Most of them do. Inside the front cover,,,somewhere on the inside of the panel that covers the filter? I've never seen one of these without that diafram.
Oct 24, 2013 | Tools & Hardware - Others
York diamond 80 manual
where is the air filter located on a York diamond 80?
May 03, 2013 | Dayton Gas Furnace Heater
Does a york diamond 80 furnace have a pilot light?
There is a diagnostic code flashed from a window in front panel of the furnace. What is it? From your description, I would bet on the ignitor as faulty. The vidoe shows this repair. Don't remove elements and sand them as this fixer did. it is destructive in many cases. York Diamond 80 furnace troubleshooting won start won light flame sensor...
Mar 08, 2018 | Heating & Cooling
York furnace won't ignite
Is the igniter receiving 120 volts after the pressure switch closes? If not, either the board is bad or the pressure switch is open
Nov 27, 2012 | Heating & Cooling
York "high Aux or spill limit switch open"
how can I fix the spill limit switch, also how do I found it
Mar 05, 2010 | York Furnace Draft Inducer Blower Fasco #...
Gas furnace
Feb 16, 2010 | York Furnace Draft Inducer Blower Fasco #...
York diamond 80 hvac blower and comp wont start on automatic
Jun 20, 2009 | York Furnace Draft Inducer Blower Fasco #...
Furnace Filter recommendation
measure the out side to outside most likley 20x20x1 or 20x25x1 depends on the size of unit
May 16, 2009 | Heating & Cooling
York  Furnace Draft Inducer Blower Fasco # A224 Logo
150 people viewed this question
Top York Tools & Hardware - Others Experts
vince
Paul Carew
Are you a York Tool and Hardware - Other Expert? Answer questions, earn points and help others
