Question about HP Color LaserJet 2550n printer + HP Color Training and extended warranty ;U4929E, Next-Day exhange...
How do you change the toner?
How do you change the toners?
  • mario443 Jan 13, 2009
    What's taking so long?
    New Friend:
  • 52 Answers
On the 2550 you have a door on top of the machine with a blue button next ot it. When you push the blue button, the door will open and you will see one of the toner cartridges. If that is not the one you want, close the door and follow the instructions on the panel. To remove toner, rotate back on the top of the toner and lift out.
Posted on Mar 06, 2009
How to change toner
Normally the procedure is indicated in the manual. Check the manual of your unspecified printer or copier.
Procedure is different on each device. Just for your illustration, enjoy some videos about how to replace toners on copier:
How to Replace Toner in your Ricoh Copier
SHARP COPIER How to replace toner cartridge
How to Replace Toner in Canon ImageRUNNER Copier
Toshiba copier 2006 toner change
Aug 07, 2015 | Office Equipment & Supplies
My ricoh mpc 2500 keep saying add black toner whereas there is toner in the toner bottle
If asking for black toner did you change rt toner pump should been one behind the black dev unit. Sometimes when you change it might have to open and close front door. A couple of times make sure you leave it open long enough that it think you change bottle
Feb 19, 2015 | Ricoh Office Equipment & Supplies
My machine is poblam out of toner change toner poblam change tha toner poblam as tis
Out of toner problem often happen when the sensor is blocked with waste or toner-dust-spill and recycled toner cartridge. If you can manage to air-dry-clean (using vacuum cleaner) the housing where the toner is inserted please do so. But it is advantageous to locate the toner sensor location for efficient cleaning. I may know the brand and model of the machine to help you locate the toner sensor. Goodluck!
Jan 05, 2015 | Office Equipment & Supplies
I change the toner in kyocera FS-1135MFP but still it is asking to change the toner why ?
clean the developer and add toner powder to it then try to print without putting a toner if fine then install the toner problem solved
May 28, 2014 | Kyocera Mita Toner 37085011 for DC-3060 &...
HL215ON changing toner How do I change the toner?
Its not very hard to replace toner cartridge on your brother laser printer. please click the link below and follow the instructions with diagram, to replace toner cartridge:---- http://technoanswers.blogspot.com/2011/06/how-to-replace-toner-cartridge-on.html ----------- this should help.thanks.helpmech,
Jun 01, 2011 | Brother HL 1240 Printer
Change toner cartridge , how do i
Open front cover, realese the blue toner handle, pull out toner unit, put toner crg. on top toner unit, so that arrow poits to copier. Press it and then will pop out tape wich you pull out, not to the end, when it does not go further it is OK, push back the plastic cover that got out, this will realese toner crg.Remove empty toner crg, push back toner unit and lift handle.
NOTE: when toner is empty machine guides you how to change toner on lcd display, you just need to look and press next.
Jun 30, 2010 | Canon imageRUNNER 2200
I would like to change the toner how to change it machine is toshiba e studio 45
You have to purchase genuine toner catridge from toshiba dealer . after purchasing the toner
1) Open the front toor
2) Toner catridge is there on above of the drum unit, there will be lock for toner catridge cover on the machine, it needs to be opened
3)Rotate the toner catridge in clock wise and pull the catridge ,it will come out
4)Insert the new catridge and rotate clockwise at a time it will get enhance with toner motor
5) close the toner cat cover, front door, TURN ON the machine it will get rotate for few seconds (adding toner) then it will becomes ready
May 20, 2010 | Toshiba e-Studio 45 Black and White Copier
Canon Ir2018 always indicating ''no toner, change toner''
Because you need to clean and shake the toner unit. When you say " ive been fixing" does it mean that you now what you are doing or?
If yes dismantle the toner unit and vacume it, it may be that toner stucked on "antena" for toner recognitions.
If not - call service
Pls. rate
Apr 27, 2010 | Canon Office Equipment & Supplies
Just changed TONER & it still flashes NEED TONER.
have you removed the plastic strip from the toner which secures your toner.
Feb 17, 2010 | HP LaserJet 1320 Printer
Can not get this to recongize toner?
did you change toner from printer menu or rotate toner rack manually ??? this printer toners must be changed from printer menu, because printer counts toner there is no chip on toner.
Oct 05, 2008 | Konica Minolta magicolor 2300DL Laser...
82 people viewed this question
Ben Johnson
