Question about Dymo DateMark Date/Time Stamper
Dymo dateMart date/time p.reset resolution
The P.RESET is flashing. I have change all the batteries. What will make this P.RESET clear?
SOURCE: My Dymo DateMark won't print.
open the back cover where the batteries are and press the pinter reset button
Posted on Sep 04, 2008
SOURCE: dymo datemark
Posted on Nov 05, 2008
  • 2692 Answers
SOURCE: dymo date marker instr manual
Fixya?
Posted on Apr 23, 2009
cq92
  • 184 Answers
SOURCE: Need to reset date and time after changing the
Here's the instructions on how to do that :
Quick Instructions on Setting the Date/Time:
  1. To set the current date and time, press and hold down the SET/EDIT button for a few seconds. Release the SET/EDIT button when the Month (M) and Day (D) indicators start flashing.
    Note: The unit will revert back to normal display if no other key is pressed for 10 seconds.
  2. While the Month (M) and Day (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
  3. Once you have chosen an appropriate date format press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR, and MINUTE fields. The field that is currently active will start flashing. To change the field's value press the LOCK button. Each stroke of the LOCK button moves one value up.
    Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189 and back up to the current year.
  4. Once you are finished setting the Date and Time press the Set/Edit button to return to the normal display. The Date/Time Stamper is now ready to print.
The manual for this device can be found here :
http://images.cableorganizer.com/dymo-label-printer/DateMark_Time-Manual.pdf
Posted on Oct 26, 2009
Testimonial: "Thank you!"
SOURCE: p reset keeps flashing and won't print
Open the battery compartment and use a paperclip to push the printer reset button
Posted on Dec 07, 2009
My dymo datemark stamp says "reset" but we have no idea how to do it?
Take off the back cover and insert the tip of a pen or paper clip in the little button between the 3.0 volt battery door and the AA batteries. It is "printer reset" around the little hole. This should work. It works unless something is wrong with the ribbon of letters that can get stuck. I'm trying right now to get my to reset using this solution (that has worked previously) but it is not. So it is a **** shoot!
Jan 28, 2010 | Dymo DateMark Date/Time Stamper
Oct 26, 2009 | Dymo DateMark Date/Time Stamper
DYMO DateMark has P.Reset flashing, how do I reset?
Jul 08, 2009 | Office Equipment & Supplies
How quickly do the AA batteries run down in the DYMO Datemark. I just started using a new one this morning and have stamped maybe 50 times and have now received the flashing p.reset
Mine usually last at least 6 months. But I am careful to lean it back slightly to make sure It's not touching the switch on the bottom, and I only use fresh energizer batteries.
Jul 02, 2009 | Dymo DateMark Date/Time Stamper
P reset keeps flashing and won't print
Jun 30, 2009 | Dymo DateMark Date/Time Stamper
Date/time stamper will not print correctly
mine is doing the same thing. I read that the 3V battery may need to be changed.... so I changed the 3V and all four AA batteries and hit reset and am still experiencing the same as you. Random **** printing when display seems okay. Never same stuff twice. Very frustrating.
Jun 18, 2009 | Dymo DateMark Date/Time Stamper
Dat stamp not stamping
I had the exact same problem. I took the back off of the stamper and like some others, I pushed the reset button with a pen. Surprise it worked!!! I am now able to date stamp my "stuff".
Hope this helps somebody.
Donna
Jan 19, 2009 | Dymo DateMark Date/Time Stamper
Dymo datemark
Oct 21, 2008 | Dymo DateMark Date/Time Stamper
Feb 20, 2008 | Dymo DateMark Date/Time Stamper
Reset time
Nov 05, 2007 | Dymo DateMark Date/Time Stamper
54 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
