Question about Whirlpool WDF530PAYW Dishwasher with Resource-Efficient Wash System -
New diswasher. Worked once when used 5 months ago. has not been used since. Water and power ok. Connections ok., but does not run.
Additional information: the washing light blinks, but there is no water coming in nor sound coming from the motor.
Amigaman
  • 248 Answers
SOURCE: Not Working at All
Check wire nutted connections where power cord connects underneath.
Posted on Nov 18, 2007
  • 351 Answers
SOURCE: error soak and scour light comes on wont wash
press and hols start button until it resets then try again.
Posted on Mar 09, 2008
  • 4 Answers
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
SOURCE: water not draining from dishwasher
1.attache the drain hose to the bottom of contertop.
2. drain back valve is not work properly.
Posted on Dec 20, 2008
  • 864 Answers
SOURCE: No water running through cycle once filled....making humming noise once clicks into cycle
Both problems sound like motor has failed or is failing.
Posted on May 29, 2009
Diswasher water isn't draining?
It is most likely the drain pump. If the drain pump passes a tech's test ok, have the drain passage checked for clogs.
Apr 17, 2012 | Dishwashers
I have Frigidaire FDB956RBC1 diswasher. I have to turn off the water to fix the faucet. When I turned the water back on, water did not go to the diswasher when I used it. The diswasher runs normal except...
FRIDG... EXPERT HERE
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 19, 2011 | Frigidaire FDB956RB Built-in Dishwasher
My samsung mobile had water damage 1 month ago.i bought it 6 months ago.it's display has gone.it worked for 20-25 days even after that.now what is the best possible reliable solution?what will be the...
hello,when it got damaged by dropping into water,did you try to dry up the panel before putting it on,if not that would have affected the panel and also the battery,does the phone still power on,if no,you will have to get a battery from a store or a friend who uses same kind of phone to run the test in powering it on.since the screen does not display any longer i suspect the screen is faulty or the pones flex,so you will have to get a new one
the assumed estimated cost for both the screen and flex is about 30-50 dollars,
please kindly rate the solution if it's helpful,
take care.
Jun 15, 2010 | Samsung Star GT-S5233 Cell Phone
Fridge running continuously
Another defective thermostat.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2010 | Refrigerators
Sishwasher not used for months. Now motor only
Disassembled dishwasher. Some plastic scraps had shredded and wound itself around the pump impeller axis. It was preventing the motor from turning. Upon removal diswasher again worked fine.
Oct 22, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
I can't hear others on Vent, but they can hear me.
I don't think the program is compatible with Vista. Were you running Vista when it worked a year ago ?
Sep 13, 2009 | Computers & Internet
My Hotpoint Aquarius diswasher won't dissolve the washing tablets
I don't have a solution, but the exact same problem is happening with my dishwasher. Nothing is getting cleaned properly.
Did you manage to get the problem fixed?
Jun 01, 2009 | Dishwashers
It sounds like you have a water supply issue. If you are on well water the screen in the water valve may be clogged. You can access this, remove it and clean it on most dishwashers. It is located in the valve where the water hooks up to the unit.
Apr 07, 2009 | Dishwashers
No power whatsoever to 2002 PT Cruiser, no lights, remote door lock doesn't work, nothing when I turn the ignition key. Just parked it yesterday and it worked fine. Had the battery replaced about a month...
Start by checking the battery even if it's new. If the alternator is not charging it, it will go dead even if it's new. If a recharge gets it started, then get the alternator checked. Once running a simple check of the Alt. is to put a voltmeter across the battery terminals and see if you have 14v which usually indicates it's OK. If the Alt. is OK look for a battery drain. Something staying on all the time even when the engine is off.
Mar 19, 2009 | Mitsubishi Diamante Cars & Trucks
I have a 24" Bosch diswasher - water does not drain
I have the same problem with my she58 water does not drain. only 4 months old and repair man replace 3 diff parts ...same thing happen. Bosch send another company to repair..replace parts by parts. not working....almost 5 months now I don't have dishwasher...i have to call almost everyday to Bosch..to fight for it....couple of days ago customer support told me with in 10 days somebody would call me for the replacement....i have to wait and be back if i don't have heart attack..to tell if they really would replace...gemtx
Jul 26, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Whirlpool WDF530PAYW Dishwasher with Resource-Efficient Wash System - Logo
21 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
