Question about Home
How to fix a kalevit toilet seat
Took broken seat of close coupled WC. internal fasteners have dropped into WC and now I cant fix a seat. The seat was a KAVELIT type. How do I replace? Thanks, Brian.
5 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: How to tighten the hinges on a slow close toilet seat?
You don't want to overtighten since you could crack the porcelain. Are your rubber washers in good shape? This will help. You should be able to do this w/out doing any damage.
Posted on Jan 28, 2009
  • 2976 Answers
SOURCE: slow closing toilet seat not working
It needs a new air shock on it. You might be able to take the old one apart and fix it but replacement would be best.
Posted on Feb 18, 2009
  • 268 Answers
SOURCE: Hello, I am looking for
Why do not not just contact Villeroy & Brock about your toilet. Or try These people at this email address: WWW.Toilets.Shopzilla.com they even sell your toilet still
Posted on Oct 07, 2010
  • 118 Answers
SOURCE: I have just brought a
the mechanism may be broken. call the manufacturer it should have a lifetime warranty.
Posted on Dec 05, 2010
How to tighten a vitro nupva toilet seat.
Christina, how to tighten or install hidden fasteners on your toilet seat. check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remove Vitra Shift toilet seat
Soft Close and Quick Release Toilet Seats Installation
How to fix loose toilet seat
http://vitraglobal.com/
Jun 27, 2016 | VitrA Home
How do I get a toilet seat off if it doesn't have the screws under the seat and it also doesn't have the little flap things at the back of the seat with the screws under.
You will have to remove the pan to access seat fitment as sounds like a back to wall lol.
Alternatively cut through bolts holding on seat with a hacksaw blade and go to plumb center and buy a new seat with drop through fasteners
Sep 01, 2015 | Home
How do i fix a soft closing toilet seat
some of these have bolts under seat...you turn seat to left or right by grabbing while in closed position...this will release the seat from the holding bolts...then tighten the bolts....then reset the seat on bolts then lock down by doing the opposite as you took off...
Oct 10, 2014 | Home
How do i remove a broken bolt which is embedded in the toilet, the bolt keeps the toilet seat lid fastened to the toilet?
There has to be either a nut and washer under the toilet, or if its reversed a bolt head with a washer under it holding it down. To remove it you can either use a hacksaw blade between the bowl and the bottom of the seat. Or use a dremel tool to slowly cut away the metal rod, etc., from the top. If using hacksaw put down some masking tape on the bowl so you don't scar up the enamel surfacr of the bowl. Work slowly and you will eventulaly cut through it.
Aug 16, 2014 | Crane Plumbing Home
Hinge on quiet close stopped working
A lot of these slow closing toilet seats don't work well, so I suggest an alternative, Drop-a-Seat cushions. They stick on to the bottom of the toilet seat, allow you to drop any toilet seat, gravity does all the work, and the cushions absorb the impact. They're non-absorbent, stick on for easy installation (permanent yet removable), and are only $4.99. Check them out at www.drop-a-seat.com
Aug 14, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
Dec 22, 2008 | Toto Aquia II Dual Flush Toilet
Home Logo
47 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
