Question about Gateway 310S (2900621) PC Desktop
CD drive trying to play CD when drive is empty
Ever since I put in a music CD, listened to it, shut it off, closed down the music program, and removed the CD, my Gateway Solo 1450 laptop continually makes this sound like it's trying to play a CD. Sounds like the needle at the end of a record album, click-click, fuzzzz, click-click, fuzzzzz. How do I make it stop? It's driving me crazy.
    Novelist:
  • 140 Answers
Apparently your laptop still thinks there is a cd to play. Be sure you closed down all your programs. I am assuming that you already logged off and shut your computer down and restarted. It could be something as simple as your sensor that detects the cd being in place and just a little dust. Use some clean compressed air that comes in a can and can be bought like at Radio Shack or electronic supply house. Put the nozzle on and blow out any dust that may be in there. Power down and then restart your computer. That should take care of your problem.
Posted on Jan 13, 2009
How to fix cdrw80 to play
Put the cd back in the computer that made it. Open the software program and look for "close session" . click on that and your cd will play in any other player. You must do this after you finish making a cd every time.
Jul 30, 2013 | TDK 20 Of CD-RW80 Rewriteable CDRs...
My dvd drive don't reading any disks. i put the disk into the driver,but it is not openeing that i listen my music from disk.what's the problem who can help me?
have you set the dvd defaut settings in your operating system? if you havent set this for a program to use to play the dvd's its possible that it doesnt recognize it. go to your start menu then all programs select default programs. then choose change auto play settings. these settings all ahve drop down menus of the available media players on your pc choose the one you want to use. this should help you out
Aug 28, 2010 | HP Computers & Internet
Can't turn off Hard Drive
The error means that you are using a file on the external hard drive and that it can not close that file when it is use. You have to close the program that is using the file first.
Example:
Lets go on the assumption that you have your music collection on the external. If you still have your music player running when you try to disconnect, you will be greeting with the same error message.
If the external contains any files that your Operating System uses, you will get this message anytime the computer is on. An example of this can be your "Page File".
Shutting the computer down correctly is your safest bet until you find exactly what file is being used and what program is using it. During shut down, the computer closes any running programs. With no programs running, it will safely disconnect from the external HD because there will be no files in use.
If you manually disconnect it while the file is in use, you could very easily corrupt the file and make it unusable. This is comparable to an Operating System getting corrupted from a computer not being shut down correctly (pulling the power from wall without doing a shut down).
Hope this helps.
May 02, 2010 | Western Digital My Book Essential Edition...
Sound card won't work with external input
Are you trying to record and listen at the same time? It doesn't usually work that way, the computer has to process and encode the audio signals before they can be listened to. Once you restore the computer, are you able to listen to the recording? If you have onboard sound, rather than a separate sound card, all the audio processing is done by your CPU. If you are trying to listen to the audio as it is being recorded, you are probably overloading the capabilities of the device and its shutting itself down. Try to record without listening. Also make sure you have the latest drivers. If it is onboard audio, check the manufacturer's website for updates. If you know that it is Realtek AC 97 (probably says so your manual), you can download new drivers from the Realtek website.
Dec 09, 2008 | E-Machines emachines (emachinees) CD-ROM...
Dvd drive
You are attempting to download music from a CD to your hard drive? Perhaps it is write protected.
Aug 01, 2008 | Computers & Internet
K17A Pioneer DVD-RW - Won't recognize blank CD
Then might have a problem,if is it still in warranty you should return it to your dealer(have you tried formatted the blank cd first?many programs such nero or alcohol gives that option)
Apr 12, 2008 | Computers & Internet
Overheating with certain programs
Hi jennie,
One of the most common problems with older & a lot of newer notebooks has been battery's over heat & the system shuts down. I suggest you remove the battery & run off the AC power cord. Run the programs you mentioned & see if the notebook shuts down. This is only a test.
Packard Bell has a site where it can Diagnosis & Repair some problems loacated at this link. Try it.
http://support.packardbell.com/uk/item/index.php?m=home&pn=P820000001
Mar 07, 2008 | Computers & Internet
Creative sound blaster x-fi xtreme audio
Windows closing slow means you have a bunch of program that are running in the back ground. Windows has to close each before the system can shut down. To see just what is running in the back ground. Allow windows to completly finish opening. Click the start button, click run. In the window type, msconfig & click ok. System Configuration Utility window will open. Click on the Startup tab. Now you can see just what programs are running in the back ground.
Adding memory can also help speed up a slow pc & keeping the system clean by using the two programs listed next.
First. Run disk cleanup, a windows program found in system tools. Than run Defrag also found in system tools. Restart the pc when finished. This should help your system to run a bit better.
If you have the CD that came with the sound card uninstall the software through Add/ Remove programs found in the control panel. Restart the pc. Reinstall the drivers from the CD & try opening a few programs. Open & run the program your using to play music. Any better? If not try using another music program like iTunes a free download found here. http://www.apple.com/itunes/
You can also try the drivers from creative they may be newer than your CD here: http://us.creative.com/support/downloads/welcome.asp?action=next
Enjoy!
Please vote...
map9966
Jan 29, 2008 | Creative Labs Sound Blaster Live! 5.1...
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Gateway 310S (2900621) PC Desktop Logo
44 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
