Question about Kitchen Ranges
Heartland gas stove model number 7000 oven thermostat is bad. Need a new one.
fridgetech
  • 473 Answers
SOURCE: oven beeping f1 and f3
Here are the error codes for your range:
F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Most likely problem is the oven temp. sensor. Should check around 1100 ohms at room temp. I would replace that first because it is the easiest and cheaper than an oven control.
Posted on Nov 23, 2007
  • 3 Answers
SOURCE: Oven wont light
Mine did that and I found the ignitor for the oven was bad. It was the "glow" type for pilotless ignition and it was burned out. It is supposed to glow bright red and the gas comes on and the oven will light. It was easy to tell that it was bad. But to check it I swapped the broiler ignitor with the oven ignitor and the oven worked.
Posted on Dec 20, 2008
SOURCE: Kenmore Electric Stove - Gourmet Edition
Hello! I have this stove in black where something went bad inside last week (made like a crunching sound). It still runs but seems to only be getting 110 electricity. Clock and lights work and the large oven stays warm. Everything was working fine until this happened. Could be an inexpensive fix- I willing to sell it for repair or parts if you are interested. The griddle alone sells for $170.00 through Sears. Cynthia
Posted on Jan 01, 2009
MNTECH
  • 1543 Answers
SOURCE: brand new gas stove. When oven is turned on there is a heavily gas smell.
There have been reports of gas ranges which have been installed with no leveling legs. (due to various reasons, like a new floor installed, but the counter tops stayed in the same place, so the range surface would be higher than the counter top if the legs were installed) In some cases, this results in an insufficient amount of combustion air for the oven. To test this, put the range up on a set of 3/4 inch or so blocks and try the oven again. Let me know how that went. Thanks.
Posted on Apr 29, 2009
  • 8 Answers
SOURCE: Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
Posted on Jul 30, 2009
How do I turn off the "key" icon on screen display Heartland Stove/Oven ?
The key is a lockout symbol. It appears when you set the oven to child lock mode ( Stops kids from opening the door and getting burnt) or when the oven gets over a certain temperature. (Stops you getting burnt) If you from have the instruction manual, it is xa bit difficult. You usually have to npress and hold 1 or more of the buttons in for a few seconds to unlock. I'm not sure which ones on your oven.
Jan 02, 2016 | Heartland Appliances 30 Inch Dual Fuel...
Kenmore gas stove,oven is not heating properly. I set it for 450 it heats to 250
You probably have a bad thermostat. These usually aren't very expensive or hard to fix.
Mar 02, 2015 | Kenmore Kitchen Ranges
I'm looking a thermostat oven burner for my heartland gas range 9000 model or someone who can rebuild an existing part?
I think you will need to buy the oven burner assembly that includes the thermocouple (thermostat). Refer diagram on page 31 in the manual at this site.
http://www.heartlandapp.com/media/242493/classic_gas_installation_and__operating_instructions.pdf
The part number is available on page 38 and it also has the contact details for Heartland.
Sep 23, 2014 | Kitchen Ranges
Model 7000
Try an appliance parts supplier
Jun 09, 2013 | Heartland Kitchen Ranges
Heartland metro f2 error code
bad sensor or bad computer board or clock assy.read out the sensor and find the tech sheet for your stove and it will tell you what the sensor should read out on,if the sensor is good then you have a bad computer board or clock assy.you can look up the error codes on the tech sheet too,look on the back of the stove,the papers are usually there on the back of the top console.F2 Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature
Nov 08, 2011 | Kitchen Ranges
I have a roper free standing stove. Everything seems to work except the oven. When I turn the thermostat to broiler it works but doesn't when I turn to oven
next time send the model number and say if it's gas or electric?if it's gas you have a bad bake ignitor,if it's electric you have a bad bake element
Apr 22, 2011 | Ovens
The oven door of my heartland stove does not close tightly any more. Is there an easy fix?
i have a 36 in legacy when you replace the door oven strip do not put it on the bottom
Jan 31, 2011 | Heartland 3525SS Dual Fuel (Electric and...
I have a an AMANA gas stove burners work but oven doesn't
First check the book to see if you have a igniter on this stove if so it takes a moment or two to get started, if not you need to light pilot
make sure gas is getting to burner when called for by the thermostat or oven control..
Jun 11, 2009 | Ovens
Kitchen Ranges Logo
229 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
