Question about RCA Thomson Digital Cable Modem (DCM305R)
My speed touch routers internet light is staying red and i cannot set my laptop up on the wirless
  • Frank
    Frank May 11, 2010
    what is red poower or the WAN?
  • 107 Answers
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Posted on May 08, 2010
  • 41 Answers
If the internet light on the router is red, it means the router is not authenticated the your ISP's server. Make sure the router is using the correct PPPoE user id and pw. That is the username and the pw your ISP has provided you. Once the router is authenticated by your ISP's server, your then will be able to access the internet wirelessly provided that you are able to configure the wireless connection /configuration correctly.
Posted on Jul 07, 2009
I have a Netgear DGN1000 Modem Router, and I currently have two PC connected via Ethernet cables. For one, the light is solid green, whereas the light for my laptop is flashing orange/red. I can still surf...
amber light means your only getting 10Mb speed. Your ethernet port could be going bad on the laptop. Go to control panel > Network Settings > right click Your Network (LAN) adapter, properties, click configure, advanced tab and make sure your link speed is set to "auto negotiate" or "auto detect"
Apr 02, 2012 | Computers & Internet
When i plug my wirless xbox 360 internet adapter into my xbox it blinks red one time right when i plug it in then its just blank. wat am i doing wrong?
The adapter is bad it should turn on red and stay red until you set-up the wireless settings and then it will display green. If there is no light at all that usually mean the adapter has gone bad (I have had one go bad on me also). If by some chance you have some old routers laying around you should consider making your own wireless adapter/bridge by flashing dd-wrt (dd-wrt.com) onto both of them and setting one up as a bridge to connect your xbox too.
Mar 07, 2011 | Video Game Consoles & Games
How can i get xbox live wirless working after buying the adapter. I have bought the xbox wirless adapter and i am having trouble getting wirless.
Okay, to connect to Xbox Live using Wireless Internet you will need this:
One Xbox Wireless connection unit, There are two types, the black and white versions. The black one is able to pick up the most diverse signals and has a higher potential for speed so I recommend that one.
You will also need, of course, a high speed internet source (modem) and a wireless router connected to the modem. When looking for wireless routers look for ones with marks claiming to be compatible with Xbox Live or a Windows OS. Those have been tested to work with Xbox.
Before trying to set up your Xbox Live, make sure your Router is set up with your computer, and set to be used as a wireless router. That's another tip all together but just follow your installation CD.
Okay so here we go!
First, Connect the wireless networking adapter to the back of your Xbox.
If you have a network cable plugged into your xbox, unplug it. Check to make sure the adapter's light is on.
Here's what the light's mean:
On the gray adapter:
No light: It's not getting enough power( try plugging it another USB slot)
Green light: It is connected to a wireless router, gateway or wireless access point.
Red light: It is not connected, and is ready for configuration.
Flashing red: There is a malfunction. (try again, if the problem persists return it for a replacement)
On the black adapter:
Green light: It is connected to a wireless router2_bing.gif, gateway or wireless access point.
Flashing green: The adapter is attempting to connect to a wireless router, gateway, or access point.
Now the CONFIGURATION, the reason most of you are reading this:
Turn your Xbox on and go to "My Xbox"
Go to "System Settings"
Go to "Network Settings"
Go to "Configure Network"
On the basic settings tab select "Wireless mode"
Select "Scan for Networks"
Select your Wireless source.
NOTE: If your Network isn't listed you will have to manually enter it.
To do this select "Specify unlisted network"
You will need to enter your SSID
Then choose which security you used to set it up on your Computer (ie: WPA, WEP...) Then enter your security code. If there is no code then select "no security"
Your adapter should have a green light now.
Now go back to "Network Settings" and select "Test Xbox Live2_bing.gif Connection"
If it works your good to go!
If not read visit: http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xlcsv1
Hope this tip helps :).
Dec 31, 2009 | Microsoft Wireless Network Adapter Xbox...
Wireless internet connection
Hi there I would tell you why:
1) your DSL speed band only 1.5M and the upload could be lower then 256K speed. that is not avalible to get good condition for more laptop wireless online at same time
2) other thing, your laptop wieless online in your router situation that depends on the laptop wireless card type, high level (faster)card will get more speed band and aganst other laptop.
so you could not setting any more to get improved.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 28, 2009 | Sony VAIO VGN-FW235J Notebook
How do I get internet on my laptop from my pc not using a cable?
what you would need to get is a wirless router. If you have high speed internet then you can plug the internet modem into the wireless router and then plug your main pc into the router via an ethernet cable and then set up your laptop to pick up the signal wirelessly. If you have dial up internet then you would still need a wireless router but it is a little more complicated. You could hook up the router to your main pc and then set up internet connection sharing so that way your laptop could pick it up wirelessly. hopefully this helps.
Apr 10, 2009 | HP Compaq Presario v3000z Notebook
I had this set up with a cable company yesterday and when i got today i have not been able to get online with my computer hooked up to lindseys router which i was using for months with the other company...
Hii
Just do a powerrecycle for one minute - e.g trun off router then turn off modem - wait for 1 minute then turn ON modem first wait for lights to get stabled , then turn on your wirless router -- i am t will work for you
Mar 12, 2009 | Linksys (WRT54GC) Router
Blinking lights on Belkin F5D7632-4
Check out with ISP Service provider and speed of your internet
Dec 17, 2008 | Belkin (F5D7230-4) Router (587009)
Dell Inspiron B130 problems
so the problem is about the laptop's Wirless try to reinsatll the driver of the wirless card and th ethernet card!! go to ur officila support page area!! and download it
plz rate this post!!
Aug 25, 2008 | Dell Inspiron B130 Notebook
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
RCA Thomson Digital Cable Modem (DCM305R) Logo
627 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
Jose Velazquez
Jose Velazquez
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
