Question about Jenn-Air PRG3000P Gas Kitchen Range
JennAir PRG300P oven and broiler ignitor replacement
I need to replace the ignitors for both the main oven and the broiler in my JennAir PRG3000P gas range. How do I get to the broiler ignitor? It looks like I'll need access from the back of the unit, but I can't see how to expose that part of the unit without taking the thing apart entirely. For the oven ignitor, how do I get the bottom of the oven out? It slides forward to a point, but then I can't work around whatever is stopping it no matter how I try to position it. Thank you for any help.
  • 109 Answers
SOURCE: jgr8855bds range - oven problem
yes, replace ignitor
Posted on Mar 31, 2008
SOURCE: Jennair gas stove
500 dollars shoud do just fine
Posted on Apr 08, 2008
Cory5468
  • 125 Answers
SOURCE: spark ignitor won't stop clicking
Dry the ignitors and see if that works. If not, then get new ignitors.
Posted on Apr 14, 2008
SOURCE: Ignitors won't stop clicking
there is dirt between the ignitor and the burner or the ignitor is to close to the burner
Posted on Feb 15, 2009
SOURCE: jenn air gas range ignitors won't light
My jennair gas range ignitors will not light. Any suggestions?
Posted on May 07, 2009
JennAir Gas Oven won't heat up, it stays at and displays 100 degrees, but it isn't warm. Moedel JGR8885RDP. The gas range works fine and so does the broiler. No error codes pop up on the display.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 24, 2011 | Jenn-Air JGR8885RDP Gas Range
My oven is not working The Broiler works and the stove top works fine but the oven will not heat and when you turn it on no gas comes out I tried turning it on and using a lighter but nothing happens
You gave us good clues in information!-- Thanks!
Most modern gas ovens have a device called a Glow Ignitor to light the burner.
If this ignitor has filed, it will NOT left the gas valve open-- (Good thing, right? :-) )
You say the broiler lights fine-- so let's observe something when the Broiler lights:
Do you see a bright glow near the Broiler burner?
(Usually toward the top rear of the oven--)
Well, you should see a similar bright glowing near the BOTTOM rear of your oven, for the main burner to light off-- If you do NOT see this glowing-- then you need a new ignitor-
You can remove the bottom burner cover, and dig deeper into the repair if you like-
But a new ignitor needs to be exactly like the failed one-- the safety circuit is very fussy about the exact same ignitor-- or it will not allow lighting-- even with a new 'generic' installed.
How deep do you want to go into this repair?-- Maybe it is time to call the service people into do the job?-- You can tell them that you think the ignitor needs replacing-- and approx. what will they charge you for the service call and the ignitor?
I hope this helped.
Mack B
Jan 27, 2011 | GE 30 In Freestanding Gas Range ...
MY MAYTAG OVEN WILL NOT TURN ON WHEN I SET THE ELECTRONIC DIGITAL THERMOSTSTAT LIKE SAY I PROGRAM IT TO 350 DEGREES,,, NOTHING HAPPENS,,, BUT WHEN I GO TO SET THE BROILER THE BROILER WORKS JUST FINE,,, I...
First I want to commend you for your giving us good information to start with!
So-- we know we have gas, and we know the Broiler Valve and ignitor works-- Good observation!
However-- we have no ignitor (No bright red/Yellow glow)-- like you go for the Broiler-- right?
Well, we can NOT get ignition on the main burner-- unless we have the ignitor for the main burner getting hot, and then the gas valve to that burner can light, and give you heat...
Soo-- Likely we have an ignitor failure for the Main burner---
Do you have a warranty on the stove?
Do you have a service person qualified to tackle this job?
There will be electrical work, and parts obtainment issues to deal with now---
I suggest you call the local service people for this stove, and tell that that you need to have the main gas burner ignotor replaced for this stove model number-- and see what they tell you.
Let me know if I can help more--
Mack B
Dec 30, 2010 | Maytag Ovens
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
Dec 30, 2010 | Maytag CWG3100A Gas Single Oven
Jennair gas oven. lower burner won't light, i.e.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Jul 16, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Oven ignitor
is the ignitor getting white hot in the center.it may not be drawing enough current to open the gas flow regulator.the only othe thing foe you to replace is the main control board.or better known as the clock timer
Jun 09, 2010 | Tappan TGF351ES Range
MGR5755QD CleanDesign Gas Kitchen Range: oven wont light. stove and broiler work fine. bad ...
heatman101
dfasfdas
May 17, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
GE gas range model JGBS10BEH2BB oven and broiler
you need to check the ignitor even if the ignitor glows it might not be pulling enough amps to call for gas replace the ignitor and this should take care of the problem
Aug 28, 2009 | GE Kitchen Ranges
GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
Jan 28, 2009 | GE JGRP17 Gas Single Oven
Sf195lehz5 free standing gas oven,
Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
Check oven temp sensor for 1080 ohms.
If above are ok then the problem is either the spark module or the control board.
Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
HS
Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Jenn-Air PRG3000P Gas Kitchen Range Logo
73 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
