Question about Dell Dimension 8400 PC Desktop
Dimension 8400 hard drive won't boot.
I have an 8400. Hard drive won't boot. Connector P-7 is floating loose...is it extra or where does it plug in. Is that even the problem?
  • 1 more comment
  • thomas_hughe Jan 13, 2009
    thomas_hughe
    Update...
    I too have the very loud and cycling fan when I start the 8400. After looking at comments by many others on this site this certainly looks like a Dell-8400 design problem connected to the failure to boot.
  • thomas_hughe Feb 09, 2009
    After some additional poking around I determined that HD was OK and all data was still there. I have concluded that it is a S/W problem. I have not yet reloaded the OS but that is the next step. I hope that solves the problem.
    FYI...this all started when one of our geeks at work loaded an Activcard driver to provide required security for doing work remotely. PC has never worked since and still does not work. If I can ever get it working again I will also deinstall the Activcard driver.
  • Jason Edinger May 11, 2010
    That is for a floppy drive. So no, not a problem. Are there any beeps when you turn it on?
  • 27 Answers
If hdd doesnt boot, there are lot of issues which add up to it, note the four small led's on the back of your comptuer and post them here, resrtart the comptuer and when you see the dell logo, keep tapping f2 on the keyboad, sys will boot to sys setup, under the option DRIVES, check if you are able to see the hard disk listed, restart the comp on dell logo, keep tapping f12 and then you would see boot to utility partition, highlight it using kybd arrow keys and hit enter, then you would see TEST SYSTEM, then run the express test, to make sure that your hdd is working fine, if it reports any error messge, it will display another message with it, note down the message and go to support.dell.com and check which h/w needs to be replaced, if no error message appears, then the issue is only OS related, reinstall the OS issue is resolved,,
THANKS
hope you would try all these steps before purchasing a hard drive
Posted on Feb 07, 2009
    Problem Solver:
  • 11 Answers
Hi, There should be two connections to the hard drive, the SATA power and SATA data. In a dell the data one is blue and the SATA power is black. Make sure they are both connected. If they are not, then connect them and try starting your computer.
If they are already connected then it may be that the operating system is messed up or the boot flags. In this case you need to find the original install CD that came with your dell. It is the one with operating system written on it. Start up from this disk and run install it.
The only other option is that the hard drive is broken.
In your case, its probably best to check the connections and try and find the disk, if you don't have it then you will have to get a PC repair guy to look at it.
Hope this helps. If you need help installing from the disk just let me know and i will be happy to help.
Posted on Jan 13, 2009
Dell 8400 Boots to Black Error Screen in XP States to reinstall System 32
This might be caused by hard-drive failure. You should run hard drive test from BIOS to make sure hard drive is ok. You can access BIOS by pressing F2 during start up, from there start hard disk self test and wait for it to complete.
If hard drive is ok after test, insert in your original Windows installation media and reinstall OS.
Oct 02, 2012 | Dell Dimension 8400 PC Desktop
Dell Dimension 8400 running xp has died. Can I put the hard drive into a spare slot in a Windows 7 PC to get the data off the XP HD?
Two Options:1. Yes you can as long as your Windows 7 PC has the correct connection for your hard drive. Most likely you need an IDE connection. If you have an IDE hard drive and the Windows 7 PC has an IDE connection, then you will need to make sure to "slave" the hard drive by moving the jumper on the hard drive to slave mode.
2. If your Windows 7 pc doesn't have an IDE connection, the purchase a USB to IDE cable adapter:http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2329300&CatId=3770
This way you can plug your hard drive into any computer through USB.
Best regards,AbdielComputer repair plantation
Oct 27, 2011 | Dell Dimension 8400 PC Desktop
My Dell computer was corrupted with a virus. and I went to f12 to re-install it. but it keep saying 'Boot device net available, I have a Dell XP 8400, can u help me? Will there be a charge?
Hi there.
Enter the bios setup menu and make sure in the Boot section under Hard Drive Priority, that the boot device is set FIRST in that area. Just make sure the hard drive that you need to boot from is set at the top of that list.
Let me know what happens.
Thank you!
Aug 08, 2011 | Dell Dimension 8400 PC Desktop
I wanted to wipe my entire hard drive on my old Dimension 8400 that contained windows xp on it and reinstall it with windows vista, which i have the cd for. however, when i did so, each time i try loading...
1. you will need to know 1st that the hard drive you are installing is compatible with the desktop.
2. Is the hard drive compatible with the new Operating system (VISTA).
3. Check to see if you have the hard drive properly inserted that is properly cabled and connected.This will render error in installation.
4. Make sure you are installing the Operating system correctly.
5. Some boot sectors become corrupt during a change in Operating system if the hard drive is not properly formatted.
6. Try formatting the hard drive again and re-installing.
Feb 12, 2011 | Dell Dimension 8400 PC Desktop
I replaced the battery in the dell 8400 pc, tipped it on it's side to open it up. In setup F2, I reset the time and hit escape and the computer says drive 0 not found. If I hit F1 it warns that windows...
You probably have a loose cable. When you had the machine open to change the battery you may have bumped the hard drive data cable and now it's not making good contact at one end or the other. Open the computer again and make sure all the cables are firmly seated at the motherboard and drive ends, and also that the power plugs on all drives are firmly seated. That should take care of the trouble. You can't break your computer by tipping it, but sometimes going in to fix one problem causes another. It's frustrating, but that's part of the (ahem) fun of working on computers.
Dec 05, 2010 | Dell Dimension 8400 PC Desktop
ABC diagnostic lights are green and D is yellow. Ram only works if slot 1 is used. If slot 1 and 3 are used Bios appears on the monitor with a flashing cursor. Dell dimension 8400
A,B,C green and D yellow is indicative of a component failure...in that the system cannot read a device it feels necessary to boot the machine such as a hard drive, floppy or cd/dvd drive. Power down the system, remove the power cord from the back, push the power button in for 10 seconds to bleed off the power. Remove and reseat all cables connecting the system devices. Remove all ram except for one stick and reboot. If you get boot, then try replacing the ram one stick at a time. If you still cannot boot though, try removing the cables from the devices and then plug in one a time until you get the machine to boot. If there is still a problem, the hard drive or its controller maybe the culprit.
Jun 14, 2010 | Dell Dimension 8400 PC Desktop
Dual Boot
I am assuming they are both internal hard drives, If this is the case, on the back of the hard drive itself, there will be a set of pins with a little plastic connector in between two of them. This connector selects the role of the hard drive.
You want to set the Hard drive which has the operating system installed on it to MASTER and set the hard drive you want to use for extra space as SLAVE.
This tells the computer which hard drive to actualy boot from. It is not possible to run to Operating systems at the same time.
Nov 18, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 8400 Start up Fan Noise
Might be a hard drive issue. I had the same problem with one of My desktops. I replaced the hard drive and it worked fine.
Jul 01, 2009 | Dell Dimension 8400 PC Desktop
Dell Dimension 8400 PC Desktop Logo
123 people viewed this question
Alun Cox
