Question about Boating
I have a 50hp Johnson Outboard that wont go into neutral or reverse.How do i fix the problem?1972 modle.
  • 187 Answers
SOURCE: Outboard boat engine shifting problems
Check for a lose or sloppy shift linkage.
Posted on May 14, 2009
  • 86 Answers
SOURCE: we have a 9.5 johnson outboard motor, it works in
I would think that the problem is a worn clutch dog. Drain the gear oil from lower unit. You need to disconnect the shift linkage and pull the lower unit like you would to change the water pump. Then remove waterpump housing and waterpump base. The base will have a seal so you need to be careful and gently and evenly pry the base up until it comes off. Next you need to remove the prop and depending on the year there is a ring screw around the prop shaft that needs removed. Also there is a phillips screw that needs to be removed near the lower gear oil drain plug. That screw holds the shift cradle in place. From here you should be able to slide the drive shaft up and out and the prop shaft should slide out. The clutch dog is the smaller piece in between the two gears that engages fwd and rev. You really should have a mechanic do the work but if you get a book it will help you. Pay very close attention how it comes apart and make sure that you dont mix up the fwd gear with the rev. gear.
Posted on Aug 06, 2009
  • 95 Answers
SOURCE: 1964 johnson 9.5 hp outboard runs but no reverse.
Pull the stablizer pins and row back to shore, lol j/k. Did you check the linkage to make sure it was working properly, look on the motor itself not on the feel of it..
Posted on Aug 11, 2009
  • 6 Answers
SOURCE: 35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Posted on Aug 22, 2009
Testimonial: "Hi, thank you very much for your help, I will strip the carb down and have a look. Once again, many thanks, I am very greatful"
SOURCE: 30 hp johnson outboard motor trys to start. It
1985 30 hp johnson used a cdi system(solid state, no points) check the power pack.
Posted on Mar 09, 2010
Carbies on 50hp Johnson outboard fill with oil when left standing for extended times
2 stroke , excessive oil in mix and it is settling out after the fuel evaporates off
4 strokes the unit should be left in the drive position when not used
Dec 16, 2017 | Johnson Boating
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views ยท 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
Replacement rectifier for 1972 Johnson 100 outboard
If I remember correctly, it does not matter as they are just one way switches. That is why the new one is not color coded.
Apr 04, 2015 | Light Outboard Motor Boat Bass Fishing...
50hp johnson outboard
Look on thin red wire that leads from starter solenoid,holder is normally situated on top of cylinder head
Dec 15, 2013 | Boating
Johnson Outboard Motor Manual
its in the remote control box as you should have a kill lanyard button on the side so if you fall out it stops the engine ! split the box and easy replacement or check , make or brake reading on amulti meter set on ohms !
Jun 09, 2013 | Boating
Johnson outboard 25hp shifting problem
length of the connecting rod isn't set properly
May 28, 2013 | Boating
Wiring diagram needed for my 1972 johnson 50hp hydro-electric drive outboard motor
I don't have the diagram here, but it should be mainly color on color.
I'll look for a diagram if you couldn't get out.
Jan 04, 2013 | Clymer EvinrudeJohnson Outboard Shop...
No reverse. Forward and neutral ok.
you have it right . Take it back and make them fix their messup . shift linkage is too short or long
Apr 19, 2010 | Boating
Aug 22, 2009 | Boating
Boating Logo
377 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
