Question about Maytag Neptune MDE5500AY Electric Dryer
Squeaky loud noise maytag gas dryer
Maytag model MDG508DAWK loud noise coming from dryer, still dries, how do I open it and what do I need to check
  • wartigers Jan 13, 2009
    trying to fix it myself, don't have any idea were to begin
    Sergeant:
    Novelist:
  • 326 Answers
Maytag dryer - common noise problems: See "how to take apart" first. The most common noise maker is the fan blower, it breaks on the motor shaft and makes a loud "rumbling" noise. Other common trouble makers are the rear rollers and idler pulley, they often can make a screeching noise.
A common noise with Maytag dryers is a rumbling noise that often still rumbles for a few seconds even after the dryer shuts off. This usually a broken fan blower, the inside part of the fan blower has rounded out and the fan blower is free wheeling on the motor shaft = new fan blower time. These pliers help make the repair a little easier...Snap Ring pliers.. From Tools Accessories section... How to take the dryer apart. Part is # 303836 for the mytang models. Maytag fan blower order link
Posted on Jan 13, 2009
    Sergeant:
  • 221 Answers
f your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
    Sergeant:
  • 431 Answers
Check the motor coil..
Maytag neptune dryer making loud banging noise mde6700ayw
First, check the vane's (paddles inside the drum) to see if one is loose. Post back the results.
Nov 06, 2012 | Maytag Neptune MDE6700A Electric Dryer
My Maytag Gas Dryer makes a loud buzzing noise when the ignighter and flame come on
thats a good sign the valves that those coils you replaced sit on are getting bad and you will sooner or later need a brand new gas valve
Oct 13, 2012 | Maytag Dryers
When i turn on the dry it is making a loud Squeaky sound. the dry is still heating, just making loud squeaky sound
Hi an welcome to FixYa, I am Kelly.
This squeaky sound your hearing is usually the idler pulley, idler pulley shaft, but also can be the motor or the drum roller bearings. Usually if the drum roller bearings are bad the dryer will thump as it rotates.
The idler pulley and lever is and assembly that is item 8 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194&diagram_id=28598568#d28598568
Since it is squealing at this time when you have the repairs done that you replace the belt that is item 21 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194&diagram_id=28598572#d28598572
The motor is item 7 this link:
I recommend that if you do the repairs that you replace the idler pulley, the drum rollers, and the belt.
Drum rollers are item 17 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194&diagram_id=28598572#d28598572 (make sure to check the drum roller shafts that are item 19 of the same link.)
While repairs are being completed also inspect the drum front and rear seals. Thare are items 14 and 26 (Same part number) of the above link.
By doing all of the above you should be able to get many more years of service out of your dryer.
If you need to purchase a service manual for self repair it can be downloaded here for $9.95:
http://allrepairmanuals.com/maytag-dryer.htm?model_number=MDE308DAYW
Thanks for choosing FixYa,
Kelly
Feb 15, 2011 | Maytag MDE308DAYW Electric Dryer
My dryer makes terrible noise when tumbling. It is a loud squeaking noise. Is it a belt that needs to be replaced?
Loud squeaky noises are usually a dry bearing--in this case, probably the one(s) that hold up the front of the drum. Open the top to inspect, then remove the front panel to replace or repair. Hope this helps!
Oct 23, 2010 | Frigidaire Dryers
I have a maytag dryer model MDE3757AYW that is making a loud squeaking/sqealing noise. the drum still turns and dries the clothes though.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 02, 2010 | Maytag Dryers
My dryer makes a loud sqeeling noise when its drying clothes our maytag neptune is a gas dryer thats about ten years old
heatman101
ghgh
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune dryer increasingly loud.
Sounds like you need new drum rollers installed, when they get old they squeak,squeal, and make loud bumping noises.
Sep 25, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Loud screeching noise at times when in use!
Normally loud screeching noises come from the drum rollers being dry.
They need lubricant, or replacement
Sep 24, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag Neptune Dryer makes loud noise while drying.
heatman101
ergfgfjk
Sep 06, 2009 | LG DLE2514 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
830 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
