I HAVE A PAKARD BELL LABTOP.MY LABTOP SHUT DOWNS AFTER 2 HOURS.AND THEN EVERY FIVE MINUTES.TRIED NEW MEMORY,NEW WINDOWS XP BUT STILL THE SAME PROPLEM.PLEASE HELP ME.
  • twysted May 11, 2010
    Do you have the LAPTOP plugged into the power adapter?
    Does the laptop show that it is charging? (a LED will turn on when you plug it in)
    When it shuts down, does it simply turn off, or does it give a message first? Such as that it is going into hibernation mode?
    How old is this laptop?
    In my opinion, it sounds like one of two things, either a battery issue or a heat issue. The battery may not be holding a charge or the power adapter may not be charging the system. Not charging could be because it in not plugged in, the actual jack where it plugs in is loose (very common), the battery itself is going bad, or there is a short somewhere. Verify that it is plugged in (the LED comes on), turn the computer on and remove the battery. if it turns off, the AC adapter (or the jack) is the problem.
    If it is a heat problem, that means that heat is building up in the system and eventually causing it to shut down to save itself. This could be due to failing fans, or dust clogging the heat sinks. Heat sinks have metal fins to transfer the heat away from important areas, and the fans blow air over the fins to get rid of the heat.
    A typical example of a heat related problem is that the computer will start up and work for a while, then lock up. If you reboot it, it will run for just a short time and lock up again. If you let it sit for a couple of hours, then turn it on, it will run for a longer period again before locking up.
    As it is running, check and make sure you can hear or feel the fan running, and that it is blowing air out somewhere (back usually). It should be warm air, as that is the heat it is getting rid of.
  • 139 Answers
Keep your system in bios for 2 hours and see if the laptop shuts down
Posted on Jan 13, 2009
  • Chetan Gupta Jan 13, 2009
    keep your system in bios for 2 hours and see if the laptop shuts down
2002 vue v6...starts and runs well however when I stop , shut off the engine, then try to start after half hour , it wont start
Lookfor a light on the dash that says SECURITY or ANTITHEFT. If you see this light, that is a sign of a failed or failing antitheft system, which will disable your vehicle. This link explains
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 06, 2011 | 2002 Saturn VUE
FS X shuts down computer after running about 2-3 minutes. I have the program installed on a new Gateway laptop running Windows 7. Acceleration expansion pact has been installed but not service pack 2. So...
FSX needs alote of memory and a good video card to run like it should how much memory do you have in the gateway and how much video memory does it have if its not enough this may couse it check this first then we go from there.
May 14, 2010 | Microsoft Flight Simulator X for Windows
Got pakard bell model:mit-rhea-a and want to connect to internet
you can search the drivers with model of laptop.which is mentioned on laptop.
Aug 20, 2009 | Computers & Internet
Sound loss on Pakard Bell LCD MW19H monitor
Try plugging your sound cable into a different device to see if it works (it probably does work but lets check it anyway). You should also check all of the sound settings by going to control pannel and selecting the audio tab. If the settings weren't screwed up, reinstall the audio driver. I may even try reinstalling the monitor drivers if the audio doesn't work.
Jul 17, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
How can I connect my Pakard Bell 1998 model to the internet?
you cant connect wirelessly because it wasnt program that way.Dear we are in the 21st century try something new or you can connect via cable.
Jul 04, 2009 | Packard Bell (030083) Modem
Windows XP shutdown
The computer is just doing it's internal diagnostics before it shuts down. This uses fairly little amount of physical memory. Every computer handles it differently depending on your configuration. If the computer does shut down on it's own....there is no real problem present.
Feb 22, 2008 | Microsoft Windows XP Professional With...
Power supply
try new video card uypdates and update the game wow use settings on low not hi on labtop way to hot u should geta labtop cooler if u wnan play big game son labtop never set it on a bed always hard serf
Jan 25, 2008 | Gateway MX6421 Notebook
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
