Question about Watches
Clock wont work new battery from energizer to replace panasonic n size place in clockmodel DM 6001 calls for battery size UM-5
Made in shontek taiwan plastic housing separates from crystal glass housing . uses UM-5 battery
4 Suggested Answers
escapement
  • 2334 Answers
SOURCE: Glass that covers the face of the watch is shattered-$ to replace
I am not sure about prices in US, but over here in England we charge £15 - £25 for mineral glass (depending on size, thickness, e.t.c.) and £50 - £120 for sapphire glass. As for today: £1 = 1.60$. Doesn't matter how you name it - glass or crystal, both are right.
Posted on Jan 11, 2010
dunnbiker
  • 8546 Answers
SOURCE: How do I set my
For these types of clocks you just set the Time Zone, place it somewhere it can face Colorado and wait. It will set itself.
http://www.theclockdepot.com/radio_controlled_clocks_information.html
http://www.ehow.com/how_5191489_set-radiocontrolled-clock.html
http://electronics.howstuffworks.com/gadgets/clocks-watches/question461.htm
http://www.nist.gov/pml/div688/grp40/radioclocks.cfm
Posted on Feb 28, 2011
GodBlessU
  • 3513 Answers
SOURCE: I've cracked the plastic crystal
Hi
Since the damage is unusual the replacement is a bit difficult .So it is suggested that you should consult a watch repair person to get it artificially done or contact the dealer.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jul 06, 2011
Fossil battery am-3198
Take your watch to a jeweler to identify type and possibly replace it.
Mar 04, 2014 | Fossil AM Watches
What is the battery size for the wenger 7925x/t
For mine, it took an Energizer 396/397 (same as Renata 397 and Maxell SR726SW). Works just fine now.
Jun 01, 2012 | Watches
I have an old fossil bq-8793, years ago I was going to replace the battery myself. I lost the battery back then, there seems to be no indication on the watch itself as to what size it takes inside or out....
Back Plate:
About 1 1/4'' inches wide. Inside inscription/stamp reads:
FOSSIL INC. HONG KONG 1
Battery:
Energizer 373
Movement plate:
There are 3 inscriptions/stamps
1) S (May be a # 5)
2) 1A
3) TMI TIME MODULE INC. JAPAN VX3J
(The above number stamp may also read UX3J)
Mar 29, 2011 | Watches
I have a Sunbeam Westminster Quartz mantle clock I bought approx 17 yrs ago and after replacing the battery and setting the time again the clock stops after an hour or two. Any ideas of what the problem...
mcdevito75 here, Even a so-called new battery doesn"t really mean it"s NEW!! NEW!! in other words your NEW! battery could have been laying in a store for months before you bought it. Thes ebatteries have a shelf life of a few months, about 1 year with use in a clock / watch.---- Try another battery, also the quartz mechanism could be starting to wear., also double check the battery is installed correctly.
Jun 23, 2010 | Watches
I have lost the battery for my Fossil Blue BQ 9039 watch. What battery number should I get to replace it?
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 24, 2010 | Fossil BQ9184 Wrist Watch
Size 377 battery wont go in - need to unscew something?
I presume that a 377 battery is the same number as what came out. Sometimes there is a small piece of metal that is a strap that helps hold the batter in. Usually, then there is a very small screw that you have to loosen to remove the plate or just move it a bit to get the battery in. Be sure that the battery is not upside down from the way that the original was placed in. Also when putting in a new battery be sure that you don't use metal tweezers to hold the battery as it will short the battery and discharge it. Use your fingers or plastic tweezers.
Oct 30, 2009 | Kenneth Cole KC1104 Wrist Watch
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
May 12, 2009 | Timex Expedition 84601 Wristwatch
I put a fresh battery in my new wall clock and it wont work
had the same problem myself. make sure that the hands of the clock are not bent inwards as to touch each other and get stuck.
my ones wre bent , a simple straighten solved my problem and the clock then worked fine. hope this helps
Apr 05, 2009 | Watches
Which watch battery do I use?
There are lots of different size button batteries for watches. I work in a clock shop where we change batteries in watches and I have had people bring the watches into me without batteries and it is really a guessing game. A lot of watches take a #377 battery. You can try that or take it to a place that changes watch batteries and let them figure it out.
Mar 08, 2008 | Watches
Watches Logo
52 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
