Question about Amana ALW480DA Top Load Washer
Stink When I open the lid there is a stink like moldy water. It is not from the tub. Nothing showing to leak. More like from inside where I can't see. Patty
    President:
  • 1,902 Answers
Run a solution of hot water and vinegar in your tub on a full cycle using the hot and cold use about 1 cup of vinegar. Just stale water that always sits in the bottom of the washer
Posted on Feb 07, 2009
2002 Ford Escape BA Limited leaking inside passenger floor when rains
check drains in bulkhead ,,,,, panel under windscreen ,,, open bonnet and make sure 2 drains are clear
Feb 14, 2012 | Cars & Trucks
Cannot locate pump filter to clean. Trying to eliminate the STINK
The filter if you want to call it one consists of a coin cup inserted inside the most rediculas tub to pump boot everthemobilian_3010.jpg
Affinity Service manual
Sep 12, 2011 | Frigidaire ATF6000ES Front Load Washer
There is a musty smell in the maytag washer even b4 I fill it with water, I've disconneted the hoses & flushed with bleach that did not take care of it,Iv'e run washes without clothes in it...
When a moldy or musty smell develops in a washing machine, many times the smell is coming from the open areas of the agitator. Water along with soap and/or liquid softener sometimes splashes into an open agitator, and when the lid is closed it does not dry out. Instead, mold begins to form, and a musty smell wafts from inside the machine, even after the lid has been opened for an extended period of time. Until the mold is removed the washing machine will continue to smell bad, even if it is used and allowed to air dry with the lid open.The tub can also be the source of the smell. Lint can gather and collect in the holes, and when it does not dry fast enough it ends up smelling musty and moldy. Even the top of the rim can become moldy and musty, but proper cleaning can get rid of the odor.
So that said.To clean the machine,fill to just above the top row of holes in the tub.Add 2 cups of bleach.Let sit for 1-2 hours.Then let the machine run it`s wash cycle.Lastly use bleach water and a rag to wipe the machine down inside and out.If the agitator has a cup on top remove and clean with bleach.Leave the top open so the machine can dry.
Now it should smell better,if so use as normal,and leave the lid open when not in use.
May 15, 2011 | Maytag Washing Machines
A stink bug climbed in the water chamber and we can't get it out. is there a solution?
Slowly fill the water tank with water. The stink bug should rise to the surface. Continue filling slowly and the flow of the water out of the fill hole should force the stink bug out! Remember as you're filling you must use something that will NOT block the fill hole or the water cannot drain and your "little friend" won't be able to be flushed out by the flow of the water.
I hope this helps!
Mar 07, 2011 | Rowenta Professional DX8800 Iron
Smelly clothes
Maytag had a big problem with the rubber boot in the front of the washer.They redesigned it to drain better so water would not remain in the bottom and get moldy smelling.Open the door and look down in the boot with a flashlight.Make sure if there are drain holes in the bottom that they are clear and not clogged with soape or lint.Put a couple of old towels in the machine and a little soap and twice as much clorine bleach as normal and run a cycle.It should help.It is also good to leave the door opened between washes if possible.
Jun 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune TL has a moldy smell that I can't seem to get rid of. I've used a steam cleaner to blast away mold I've found around the rim and other parts I can reach, and I've run cycles of just hot...
Take off the round agitators one at a time, by popping off the center cap and use a hex driver to remove the screw. Tilt out aggitator, and clean back of agitator, hyousing and gear box of the moldy/mildew build up..its kinda gross. That is where the stink comes from.
Jul 28, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Clothes stink after washed in lg front loading machine
You may have already found a solution, but I had this exact same problem. I ran the tub clean cycle with bleach and then switched to a powder HE detergent. I found some other posts that said that liquid HE detergent has some thing in it that causes that smell and the tub build up (not sure what?). I was hesitant that that could really make a difference but it has. It has only been a week, but so far everything smells great. Definitely worth a try.
Jul 20, 2009 | LG WM-2277HW Front Load Washer
Clothes stink!
Odor from your washing machine is being transferred to your clothes.
The washer must be cleaned first or it will "reinfect" your clothing upon washing. The secret is to clean the "splash area" just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this area add a washer cleaner to a full load of laundry and wash in a hot setting. The added bulk of the laundry will raise the water level to include the splash area. During this cleaning intermittent pausing to soak will give the cleaner time to dissolve the moldy mess.
Also, leaving the door open makes the problem worse because it dries out the residue which makes it harder to remove.
Jul 18, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Bad odor
glisten and affreash is the cleaning agents
besides this only way to get smell out is a complete inner and outter tub job but also try leaving both soap dispenser and door open for the air to dry up and vent the washing machine
Feb 24, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Water
Sounds like the water inlet solenoid ie, where the inlet flexible hose connects to, may be leaking. To prove this, close off the external stop tap(s) after use. Then see next day whether any water has entered the tub. If it has, the solenoid valve needs changeing. tip! if its faulty dont risk 'not changeing it' because it may leak FULL BORE & cause a flood sooner or later
Oct 24, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Amana ALW480DA Top Load Washer Logo
89 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
