Question about Amana Dryers
Dryer makes a lot of noise and sometime stops
I have a LG4309W Gas dryer and you can open the door and move the drum from front to back. It seems pretty sloppy. Is there rollers that go bad? Sometimes it sounds like the drum quits turning. It makes a terrible noise when it runs. What could be the problem? Thank you.
    New Friend:
  • 88 Answers
Yes the rollers can wear down and make alot of noise I believe there are 2 on yours.
Posted on Jan 14, 2009
My tumble dryer is making a loud banging noise when it turns. It is on for a few minutes and seems to happen when it switches to turn the opposite way
It will be worn slipper pads that are around the front edge of the drum. If your dryer can run when inverted that will stop the noise until the pads wear down again.
Purchase some new slipper pads and remove the back panel of the dryer moving the drum back about 1 inch. You will now see were the slipper pads are fitted around the inside edge at the front.
There will be about 6 of them, you can take the top ones and move them to the bottom. This will also stop the banging until they also wear down.
Oct 24, 2015 | Dryers
Dryer making chirpy squeaky noises then it stopped. Noise was intermittent
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Mar 10, 2015 | Dryers
How do I fix squealing and scraping noise in my Kenmore gas dryer 110.74812200?
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Sep 21, 2014 | Dryers
Motor making noise
DRYER MAKES NOISES.
The blower:
The bearings:
Apr 15, 2014 | Frigidaire FGQ1442ES Gas Dryer
ASko dryer T761 goes bump bump bump when starting. sometimes we can wiggle drum around and get it to stop. Help!
I believe asko says this is normal at start up and should stop after the drum has been spinning for a bit.
Jun 21, 2011 | Asko T761 Electric Dryer
Drum seems to be rubbing and making noise when turning
the drum does rub ... generally, there is no front or back to a drum. It rides on the rim on the back and on a smaller rim on the door. I normally find a felt "bearing" at these locations. and sometimes, there are wheels at the back on the bottom. Gravity and the drive belt make it work.
I hope this helps you
a
Sep 23, 2009 | GE DBSR453EBWW Electric Dryer
My dryer drum sparks when i push on it
You have loose or shorted wiring in the dryer. Unplug the dryer.Raise the top lid. Remove the screws on the top right and left inside the dryer to remove the front panel. Disconnect the door switch wires and set the panel aside. Reach in under the drum and remove the drive belt from the motor and pulley. Remove the drum. Inspect the wiring visible inside. Remove the rear panel from the dryer and inspect all wiring and thermostats and fuse relays.Remove the terminal cover where the cord connects and inspect all wiring there for broke or loose. Open the control panel and inspect all wires there for broken or loose. Repair any wiring found defective and replace any parts found defective.
Sep 17, 2009 | Kenmore 83142 Electric Dryer
GE Dryer (new) makes noise
few possibilities here,idle pulleys could be wearing,front drum guides could be wearing,back drum bearing,bit early for these problems though,but sometimes coins get lodged at the drum paddles inside located 120degrees apart which wouldnt be anything to worry about if you can verify this,hope this helps
May 12, 2009 | Whirlpool GEW9250 Electric Dryer
Maytag dryer making clanking noise
I had this problem and the cause was a loose screw holding on one of the "paddles" inside the drum. I removed the door, front panel, lifted the top, manually rotated the drum until I saw the screw head which had worked loose and was slapping the side of the dryer. A quick tighten of the screw and the noise was gone.
Jan 10, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Amana gas dryer
You have to take the front off on that model.. to get at the inside.. heres a diagram that may help ya out http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=1268&modelDesc=AMANA%20LAUNDRY&modelNumber=ALE331RAW&documentID=M0411885&documentTypeID=PLDM&documentClassCode=PV&titleType=DOOR%2C%20FRONT%2C%20ACCESS%20AND%20TOP%20PANELS&titleID=00002&
Oct 10, 2007 | Amana ALE331RAW Gas Dryer
Dryers Logo
87 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
