Question about Ryobi Garden
V. POOR BLOW / VAC PERFORMANCE -
I bought this last week and so far, the performance has been extremely disappointing. Generally, it starts OK although it doesn't seem possible to re-start a warm engine from the ''run'' position- it always has to go back to full throttle.
The main problem is the vac & in particular the blower. Advertised as 155mph, I thought there would be a seriously strong gale coming out of the vac. Instead, when I put my hand over the tubes, it is barely stronger than my wifes hairdryer. This is brand new and the tubes are not clogged - I checked. Any suggestions?
  • sparksflyin
    sparksflyin May 11, 2010
    does it run at full throttle or does it sound kinda weak?
  • 4 Answers
Take it back to where you purchased it from
Posted on Feb 13, 2009
Ihave a canister vac. Bought last april low suction
Have you cleared the vacuum hoses
Dec 01, 2016 | Vacuums
High Fuel Consumption FORD Ecosport 1.5 Ambient
recalibration is sometimes caused by manufacturers using previous years ecm / pcm software. the optimum values sometimes differ if upgraded sensors are being used. although sensor values should not change much, sometimes cumulative differences or even differences in one sensor vs computer (ecm/pcm) software can lead to less than optimum performance or fuel economy.
conversely, software updates in the ecm/pcm can cause the same performance issues but are less likely.
rr
Jul 02, 2016 | Ford Cars & Trucks
Samsung ps51d550c1k will not turn on
If the red light flashes for a while, with a clicking noise while trying to turn on. It's either the ysus or xsus board, they are both easy to replace, my xsus board has blown twice, last board I bought off ebay £35 lasted 2 years. Just bought another for £16 + free postage.
If you can use a screwdriver & disconnect/connect a few ribbon cables & connectors, you'll save yourself £££s
google or search youtube for video guides, you won't be disappointed ;)
telltale signs are when the tv starts to make a clicking off/on sound while watching tv, without actually turning off, That's the time to look for a spare ysus or xsus board, before it blows. It could last months or weeks but better to be safe.
Takes me 15mins to take the back off, replace the board & put the back back on. & I'm a novice.
Mar 27, 2014 | Televison & Video
New Poulan Pro blower/vac won't start
I would back the carb screw out 1/4 of a turn. And yes 15 pulls should start it.
Nov 12, 2013 | Poulan 25CC Gas BlowerVac
LG front loading washing machine sucks? why do my clothes come out still dirty? It seems like it doesn't use enough water to barely wet the clothes, poor rinsing, and iI can fill it towhere the door barely...
Clearly your machine isn't performing as promised and perhaps should have been sent back to the supplier as defective within a reasonable time.
Modern cold fill washers use less water but modern detergents are quite effective, though in spite of this the programmes of necessity are extraordinarily long, initially the main complaint of new users who felt something was wrong when the shortest programmes were taking around an hour and longer programmes the equivalent of a short holiday...
I suggest you read the instructions thoroughly to ensure you are doing everything correctly including using enough detergent. When you are certain the machine is faulty you should contact the supplier if still under warranty or the service engineer if not.
Sep 28, 2017 | Washing Machines
I have a Craftsman 794774 leaf blower/vac w/25cc engine that won't start.
Many of these small blowers have an alloy key moulded into the flywheel, if this has sheared it will knock the ignition timing out, and will never run.
Feb 23, 2013 | Garden
Losing pressure more and more often, especially
not quite sure where to get the parts, but if the pressure starts out ok and decreases as it runs, it is generally that the piston rings/seals are worn out, this can happen just from sitting up over the winter.
You can google Honda Pressure Washer Parts to find a supplier for the seals/rings
Jul 05, 2009 | Honda Garden
06 corolla dead in driveway code po607
Just get a refund. The computers are expensive and if it died in 5 days, there had to be a problem that the previous owner knew about. GIVE IT BACK QUICK befor more problems occur!
Jun 29, 2009 | 2006 Toyota Corolla
Have been a big fan of your products but am disappointed in the last 498 that I bought .my boat just went back in the water after repowering it put the unit on ready to go fishing and was unable to find...
BOB you dont say whethert your boat was under repairs or whether the unit was permanently connected.
Soemtimes when the battery terminals are removed on the boat while in storage or reapirs a spike can occur and damage the unit. If the unit has a backup batterty check that its OK. you did not state the brand so its going to be a general answer. If you have spiked the chip then an expensive repair is needed.
Jun 29, 2009 | GPS
Garden Logo
80 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
