Question about Garden
Tune up ryobi ry26520
When trying to speed up the engine, it wants to die.It has been"tuned up" each year for the past two years and runs fine for a while and then starts doing the above again. At thirty dollars a tune up, I'll soon have more in repairs than the original cost.
SOURCE: My Ryobi 15" ElectricTrimmer ZRRY41002 Not Operable
[The previous posted solution was garbled by the forum software.]
I was thinking about purchasing this product from Amazon sometime soon (today being 4-26-2008). However after reading of the above problems I am not so sure anymore. However I did find a discussion about this problem at the Ryobi forums at " http://209.235.218.9/dc/dcboard.php?az=show_topic&forum=112&topic_id=597 ". (If the link does not work go to " http://209.235.218.9/dc/dcboard.php " and do a search for " 597 ". One of the displayed threads will be entitled "weedeater problem?" It will have the proper link to the discussion.) From the multiple postings in that thread it appears that the switch is the problem and it seems to be a consistent problem for many users. The switch itself can be replaced for less than $4, however the shipping seems to drive the cost up to anywhere from $12 to $15, unless one can find a local supplier. I hope that this helps.
v_v
Posted on Apr 26, 2008
  • 599 Answers
SOURCE: idling and running problems, engine stalls when started, backfires thru carb
timing chain/belt ?
Posted on Oct 07, 2008
SOURCE: RX300 Engine Stalls when I take foot off the gas pedal.
The Idle Air Control (IAC) valve is clogged. This part feeds air to the engine at start-up and idle when the throttle bodies are closed. I removed the throttle body assembly from my 2001 RX300 and separated it from the IAC. After a good cleaning with throttle body cleaner the IAC was good as new. I later decided to replace it during routine maintenance. You can pick up a brand new IAC on eBay (genuine Lexus/Toyota part). The dealer will want upwards of $400.00 for a 45 minute job (all you need are basis hand tools).
Posted on Mar 23, 2009
mkv0525
  • 358 Answers
SOURCE: oil sludge buildup in engine; anyone gotten repair for free?
getting harder to lexus and toyota to take care of this problem. I have repaired many of them when i worked for lexus. I would car the 1-800 num. for leaxus support.
Posted on May 21, 2009
  • 10865 Answers
SOURCE: I bought a Sears edger #536 796526. It dies on me.
Hi Tom. You are not doing anything wrong. That being said, your edger has a slightly gummed up carbeurator. I would go to an auto parts store and get a can of a product called seafoam. this is a gasoline additive. Add one ounce per gallon of gas and use this as the fuel for your edger. You will solve your problem in just a few minutes after using this product, I believe. Give it a try and let me know.
Posted on Jun 13, 2009
Engine starts but cannot speed up
sounds like you have a pressure switch sticking or has failed .
Aug 11, 2015 | Cars & Trucks
Vehicle idles poorly. Dies after waiting at stop light. Dies when placed in reverse. Vehicle in the last year has gone through 3sets of spark plugs and wires, 3 distributor caps and rotor buttons, 4...
has fuel filter been changed- try this first if not , then i would look at the catalytic converter- if no exhaust out can cause poor idle,misfiring and burnt up ignition parts
Jun 03, 2011 | Chevrolet 1500 Cars & Trucks
My 2007 Cadillac SRX feels like it needs a tune up. It runs so rough and misses & sputters. Driving at low speeds it barely moves. Yet the check engine light isn't on. The car only has 67000 miles...
First when was last tune up? that's a place to start. But for the sputter/miss sounds like a case of moisture/condensation in your fuel. Not necessarily bad gas but with big temp swings moisture and condensation build up. Try running a bottle of STP gas treatment through and see if that helps.
Jan 04, 2011 | 2007 Cadillac SRX
1987 Ecoline van V-8 engine hasn't been started in about 7 years. It ran good before that. What do I have to do first to start it and get it running?
I would change all the fluids and either try dry gas or i would recommend that the gas tank be thoroughly drained and new gas put in the tank.If you have a hard time getting started try to use starter fluid in carburetor or if you have none just use gas. If the vehicle is equipped with fuel injectors locate air filter and follow air duct to engine that is where starter fluid or gasoline will have to be pored to prime the injectors.if it don't start the engine should be tuned up with a major tune up replace all filters ect even if it starts without tune up i would tune it up asap!
Aug 21, 2010 | 1987 Ford Econoline
Starts and runs like **** then dies
filter maybe very dirty, you may need a new spark plug, you're carberator may have just a spec of debris in it , all things that happened to us also, this man is a wizard with small engines..www.belgiumsmallengine.com
Apr 28, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
2002 Camaro intermittent no-start
Have you replaced the ignition switch? Passkey wire broken can cause no start problem.
Jan 06, 2010 | 2002 Chevrolet Camaro
Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Jun 02, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Garden Logo
109 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
