Question about Yamaha RX-V492 Receiver
Am noise I have a Yamaha tuner about 5yrs. old. I also have a Yamaha amp and cd player, all correctly connected. Have always had weak am and great fm reception because of where the tuner is located. Recently have experienced severe noise in am reception when anything on the same circuit is turned on (lights, dryer, washer) sound improves and noise reduced if i touch any of the three cases. what happened?
    President:
  • 3,130 Answers
In the AM frequency range, it is very hard to stop any type of interference because of the low bandwidth and not a lot can be done to suppress it, and where this band is in the frequency spectrum. There should be an AM loop on the back of your receiver, and if there is not, maybe that is why the AM reception is so poor. You can also be a better AM antenna from an electronics store to hook up to your receiver. Like I said, not a lot that can be done for interference my friend.
Posted on Jun 11, 2007
Sony MHC ec77 CD player works fine, great sound but when I switch to AM/FM, why is there no sound although the display shows that is going through the stations?
Unlike old analog tuners, the new digital tuners will not output any sound or static if they do not lock onto a station.
May 06, 2015 | Sony Audio Players & Recorders
FM Tuner not receiving - Yamaha R7 receiver
Take the cover off and look at the cable that connects the tuner to the main board. Make sure it is connected straight and tight. Make sure all screws in the back are tight, just in case it is a grounding issue. Iff all checks out and you still have issues, replace your tuner.
Apr 30, 2012 | Yamaha Audio Players & Recorders
Amplifier - TA-AX380; CD Player - CDP-C40; AM/FM Tuner - ST-JX380; FM Stereo/FM-AM Receiver - STR-AV570X, and Stereo Cassette Deck - TC-W380.....all Sony. Very old system, do not have the manuals, they...
Since you have 2 receivers, you can either use the Sony STR-AV570X or the TA-AX380. You will need 3 Stereo RCA Cables to connect your CD Player, Tuner, and Tape Player. The speakers connect to the receiver you choose using the speaker input terminals.
Here is the diagram (click on picture to enlarge):
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 22, 2011 | Audio Players & Recorders
My tuner will not work! I've had this unit for 4 years & it's always worked perfectly. Then yesterday, the tuner stopped working. "Tuning" flashes on-screen intermittently & no...
1. Verify the source of the signal - Look for any antennas that may have been hooked up, and verify connection has not been moved or removed.
2. Test with a different output by plugging in some headphones, and recheck the volume through the headphones.
3. Check that the A/B switch for the speakers has not been moved, and that they are switched to the correct speakers.
4. Try AM and FM for any signals both with speakers and then headphones.
Bruce
May 05, 2011 | Audio Players & Recorders
I´ve forgotten in what order I should connect my old (80´s) separate modul hifi system´s remote cables. It shuts down imadiatly when you try to start it with the remote. If I disconnect the...
I would have thought that it should go from the amp to the tuner,then the tape deck and finally the CD deck.
I'm suspecting that your tuner is faulty and thats whats causing the system to shut down
Aug 27, 2010 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
I JUST REPLACED MY OLD RECEIVER WITH A YAMAHA AND DON'T SEE WHERE TO CONNECT THE POWER FOR THE CD AND TAPE PLAYER. DO I PLUG THEM INTO A POWER STRIP?
Yes, that will be fine just make sure its the same AC power as the new Yamaha is using.
Before connecting any AC mains always turn off your Amp, and don't turn back on again until all the signal cables for the new equipment are connected.
When checking if it all works, always start with low volume to check everything is correct.
Hope this helps
Thanks for using FixYa
Aug 09, 2010 | Yamaha RX-V663 Receiver
FM tuner does not play
Hard to say without knowing more, but many tuners have a squelch function that "mutes" the output unless the signal level reaches a certain threshold. You might want to look at the control panel and search for such a switch and de-activate it.
You didnt say if this was connected to an external pre-amp or a power amp. If so, the issue could be simply one of the correct cabling and selector switch setting
Sep 21, 2009 | Yamaha RX-770
Yamaha HTR-6030
There's possibly some leakage internally.
Do you have a normal (Playback only) CD player on the MD/CD-R input? It's supposed to support a RECORDING device as you can see by the OUT (REC) connections. A recorder would have shielded cables there and maybe the circuitry is such that ungrounded/unshielded output to the recorder allows a leak of the FM, which is developed inside the receiver.
Since you know that FM is leaking why don't you just selct some other idle source before selecting MD/CD-R? Have you also heard, say, the DVD, if it is playing when you select MD/CD-R?
Or skip the analog route entirelzy and run digital cables from your CD player to one of the Digital Inputs, if you have a spare one. They're all functionally the same. I guarantee the FM won't get in that way.
Dec 08, 2008 | Yamaha HTR-6030 Receiver
Sony STR-AV770 AM/FM Tuning
If your going to buy an antenna you could do some research at cccrane.com. They might be able to help you with the other problem too.
May 15, 2008 | Audio Players & Recorders
FM RADIO DONT WORK..MODERATE AM
hi sounds like a torn ant wire or bad ant change the ANT with all the length wire till the reciver make sure a good connection in the reciver good luck
Mar 26, 2006 | Jensen 200W AM/FM/CD Car Receiver - CD4610
Yamaha RX-V492 Receiver Logo
93 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
CHP6PH1
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
