Question about Ovens
Uneven cooking problem
My ECK100OP obviously doesn't use the top element for any baking. I have my shelf as high as it can go and the bottom of my food is always dark still
    Sergeant:
  • 462 Answers
Possibly oven switch is not routing power to top burner have it checked or maybe replace but usually not very cheap
Posted on Dec 12, 2012
5 Suggested Answers
SOURCE: Bake element does not heat
After removing the racks, rack rails and the back plate I removed the 2 screws the hold the bake element. Lifting the front of the bake element up and carefully pulling the element out and gently moving the element so the connector clear the hole I was able to disconnect the wire. After testing for continuity with an ohm meter (non found) I determined the element need to be replaced. $37 and 45 minutes total.
Posted on May 29, 2008
MNTECH
  • 1543 Answers
SOURCE: How do you change the top oven bake element.
Should be no problem.
Posted on Jul 17, 2010
  • 244 Answers
SOURCE: Whirlpool Self Cleaning Oven - Model
Your lower element may be burned out. Generally you can firmly grasp and pull it out. Take it to a repair shop and get a replacement unit. Then simply snap it back into the same outlet where you remove the first one. It sound as if you've tried everything else so it must be the unit that is bad.
Posted on Nov 04, 2010
blackmar
  • 235 Answers
SOURCE: How about if the top and bottom elements (bake
It is a bit suspicious if both stopped working at the same time. It has to be a common fault. The first thing I would check is the wiring at both elements. You will have to pull the back of the range off to check this. If okay I would suspect the controller which controls both these elements is faulty. Another solution maybe the oven thermal overload but it isn't that common.
Posted on Feb 13, 2011
There are two elements on oven-both at the top.Grill&Element-I am using the normal oven element but my pizza does not cook through only on the top. How do I bake
Hi Michelle,
You need to preheat a heavy gauge baking tray first and then cook the pizza using the main element only. Also experiment with the position in the oven (eg. high or low).
Also go to. The Kitchn
Jul 19, 2015 | Ovens
How do i fix an oven that bakes unevenly
the cooking I can't help with, but the oven I can.
sounds to me like the bottom element or what controls it is not working. the reason the ones on top are cooking is that the top element is coming on and browning them on top after the heat has made the dow rise and cook.
so essentially everything is cooking from the top down. so when the temp drops its using the top element to heat with and thus browns the top rack.
check ur elements to make sure both work, if so, move on to the thermostat which I have to be the culprit many times.
Feb 26, 2015 | Ovens
First start up
You're actually referring to the "broiler" elements. Most electric ovens have these at the top of the main oven space. (Some gas ovens are set up the same way, but many put the broiler elements in a bottom drawer.)
As their name implies, broiler elements are active only when you're broiling. They will not go on for baking.
Broiling is the process of cooking food by exposing it directly to a high heat source at close range. To broil a steak, for example, you would place the pan holding the steak on an oven rack raised to the top or next to top position in the oven (consult the manual) and set the oven to broil. The top elements will then turn on and cook the meat by direct radiation.
Most people, however, use ovens for baking far more often than for broiling. Baking is the process of cooking food (cakes, casseroles, roasts etc) by indirect heat. In other words you raise the oven to a certain temperature, put the food on a rack more in the middle of the oven, and let the surrounding heat cook it over time. When you bake the top broiler elements usually don't come on at all.
I hope this helps.
Apr 30, 2014 | KitchenAid Ovens
Baking oven
are you having problems with the bottom bread not cooking and the top done?
May 30, 2013 | Ovens
Frigidaire wall oven CPEB30S8CC2 lower element does not work
We have a Frigidaire CPE30S8CC2 with the bottom bake element not working. We tried to replace it with no luck. The old element does not look burnt out at all. The timer, clock and broil all work just fine. The bake button works and you can set the temp. it just doesn't actually heat up at all. There are no knobs on the controls for any cook top. it is all on a circuit board for overn only. help?
Jul 16, 2012 | Frigidaire Ovens
Have just moved from UK and we don't have broil and bake on our ovens - what do they mean/what's the difference as I've been cooking garlic bread on bake but it's taking twice as long to cook?
The broil is the top element and the bake is the bottom element...so with broil you are heating from the top and with bake you are heating from the bottom...if your oven has a fan, turn that on with a bake setting and it will speed up the process..
heatman101
Apr 20, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
The cooking is not even when cooking small items
Often times this isn't something you want to attempt to rectify yourself. If you can find a way to deal with or adjust to this issue it will save you the cost of a repair visit. If the uneven bake is so severe that you cannot cook in the oven and you still wish to attempt repair by yourself you first need to identify which racks aren't cooking correctly and in which pattern is it uneven.
For example is the rack uneven in overall color from top to bottom, meaning are items on the top cooking to quickly where as the items on the bottom are uncooked? Or is the uneveness lateral where the center of a single tray is over/under cooking or the edges of a tray are over/under cooking.
Once you've identified your issues you need to locate your airflow louvers. They are usually located in the back right corner of this oven, it is where the hot air comes out of the heat exchanger chamber. You will notice there are gaps and there are fins. Adjusting the fins changes the way the air flows from side to side across your product, adjusting the gap changes how much hot air reaches the product.
Lets approach side to side uneveness first. To compensate for the center of a tray UNDER cooking take the metal fin lined up with that tray on the RIGHT side and slightly bend it to the left, directing air towards the center of the tray. If the center is over cooking bend it to the right, directing air away from the center of the tray.
For top to bottom uneveness you will need to loose the screws/bolts holding the fins in place and gently increase or decrease the gaps. Be careful here because if you loosen the screws too much the louver can slide out of place and make to large of a gap, potentially making things much worse. A good trick is to take a permanent marker and make a mark to where the louver was before you adjust it incase you need to put it back.
If a single tray is too light in relation to the other trays increase the gap, if it is too dark, decrease the gap. Do this for each tray that is coming out uneven. Make small adjustments and then do a bake to check the results, there may be a lot of trial and error involved.
If this seems overwhelming you're probably better off not attempting this because you can make things worse to the point where NOTHING comes out correctly, if that's the case call your local authorized service provider. Good luck!
Jan 03, 2011 | Baxter BXA2G Stainless Steel Gas Single...
The heating element becomes red hot,but the food doesn't appear to cook in an appropriate time os fashion. Any answers or suggestions
The top of whatever food you're cooking should be in the center of the oven for the most effective cooking. Do you have the oven set on bake or broil? Broil is a direct heat method and if the food is on the lower shelf and the oven is set on broil, the food is not getting enough heat to cook it properly. Baking heats the lower element and the heat rises to surround the food. Broiling heats the top element and since heat rises, it is not getting down to the food to surround it and cook it.
Nov 04, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Heat escaping, uneven baking, longer cooking times
Either the seals need to be replaced, or you may have weak oven door hinges, and the door is not closing properly.
Only solution would be to replace both hinges if this is the case.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
113 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
